Toolbar GroupMarker problem [message #437616] |
Thu, 29 September 2005 20:19 |
Originally posted by: mcheng.cisco.com
I added the following code in fillActionBars() in MyWorkbenchAdvisor:
ToolBarManager toolbar = new ToolBarManager(SWT.FLAT);
toolbar.add(new
GroupMarker(IWorkbenchActionConstants.TOOLBAR_FILE));
toolbar.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
<----A
toolbar.add(new GroupMarker("group.actions"));
toolbar.add(ActionFactory.SAVE.create(window));
toolbar.add(ActionFactory.PRINT.create(window));
toolbar.add(new Separator());
I also specified actions in the toolbar by setting toolbarPath in actionsets
of plugin.xml.
Action A -> toolbarPath="org.eclipse.ui.workbench.file/additions"
Action B -> toolbarPath="org.eclipse.ui.workbench.file/additions"
Action C -> toolbarPath="group.actions/additions"
Action D -> toolbarPath="group.actions/additions"
Action E -> toolbarPath="group.actions/additions"
The toolbar looks like this now:
| A B | SAVE PRINT | C | D | E
The problems are:
1) Why C, D and E are not in the same group (each is separated by the
separator) since they are using the same group marker ?
2) Why C, D and E appear after SAVE and PRINT
3) If I remove line A after TOOLBAR_File group marker and specify
toolbarPath="org.eclipse.ui.workbench.file", then A and B won't be in the
first group, it will be mingled with C, D and E each with its own separator.
I can tell GroupMarker("group.actions") not working, but don't know why? Is
anything else I need to do to create the GroupMarker?
Also why do we need the additions (Line A) in order for file group to work
(for question 3)?
Mike
FUDForum. Page generated in 0.04308 seconds
