Home » Eclipse Projects » Rich Client Platform (RCP) » open perspective menu: add all perspectives
open perspective menu: add all perspectives [message #437133] Thu, 22 September 2005 05:21 Go to next message
hi,
i would like to have all available perspectives as shortcuts in the "open
perspective"
menu.
with the PerpectiveRegistry i get descriptors for all perspectives -- but
how do i add the shortcuts?
in the WorkbenchWindowAdvisor i can't access the perspectives themselves
and their layouts (no layout.addPerspectiveShortcut()) and in the
Perspective's createInitialLayout() i can't access the PerspectiveRegistry
so i don't know about other perspectives :-(
any hint appreciated.
Re: open perspective menu: add all perspectives [message #437135 is a reply to message #437133] Thu, 22 September 2005 06:31 Go to previous messageGo to next message
Originally posted by: fleque.users.nospam.sf.net
we wanted to have all perspectives available from all perspectives as
well and do it the following way. We have the following util method:
public static void addAllPerspectiveShortcuts(IPageLayout layout)
IConfigurationElement[] configPerspectives =
Platform.getExtensionRegistry().getConfigurationElementsFor( "org.eclipse.ui.perspectives");
for(int i = 0; i < configPerspectives.length; i++)
layout.addPerspectiveShortcut(configPerspectives[i].getAttri bute( "id"));
and we do the following in our IPerspectiveFactory(s)
public void createInitialLayout(IPageLayout layout)
RCPUtil.addAllPerspectiveShortcuts(layout);
So we access the extension directly via the ExtensionRegistry. Might not
be the best way (hardcoded extension point String) but works.
Regards Alex
arne anka wrote:
> hi,
> "open perspective"
> menu.
> but how do i add the shortcuts?
> themselves and their layouts (no layout.addPerspectiveShortcut()) and
> in the Perspective's createInitialLayout() i can't access the
> PerspectiveRegistry so i don't know about other perspectives :-(
Re: open perspective menu: add all perspectives [message #437136 is a reply to message #437135] Thu, 22 September 2005 07:50 Go to previous messageGo to next message
hi,
finally i came to nearly the same solution (albeit a static method in
WorkbenchWindowADvisor rather then an entire new class), but instead of
i use
PlatformUI.getWorkbench().getPerspectiveRegistry().getPerspe ctives();
and thus ...
.... prevent hardcoding (albeit i don't expect any problems -- the
extensionpoint's name should be virtually immutable).
regards
Re: open perspective menu: add all perspectives [message #437137 is a reply to message #437136] Thu, 22 September 2005 08:04 Go to previous message
I've changed this in our RCPUtil as well to use
IWorkbench.getPerspectivceRegistry()
Regards Alex
arne anka wrote:
> hi,
> i use
> and thus ...
>> not be the best way (hardcoded extension point String) but works.
> regards
Previous Topic:How to invoke a RCP Standalone APP with JAVA Code
Next Topic:stickyView -- how to?
Current Time: Wed Sep 17 00:44:42 EDT 2025
Powered by FUDForum. Page generated in 0.02921 seconds
