Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Stupid (hopefully easy) drag and drop question
Stupid (hopefully easy) drag and drop question [message #436588] Wed, 19 May 2004 23:47 Go to next message
I am implementing drag and drop in some tree based views.
There are essentially two potential drop states when dragging over an item
in my tree:
1. Cannot drop DND.DROP_NONE
2. Drop based on the state of the control key press - Either DND.DROP_MOVE
or DND.DROP_COPY
In my implementation, If I ever set the drop event.detail to DND.DROP_NONE
in my dragOver method then it never get's set back when dragging over an
item that is OK to drop on.
Does my code have to check the state of the ctrl key and set the
event.detail to DND.DROP_MOVE or DND.DROP_COPY appropriately? Seems like
the drag and drop machinery should be able to do that. I tried setting to
DND.DROP_DEFAULT but that always results in a DND.DROP_MOVE even if the ctrl
key is down, indicating it should be DND.DROP_COPYing.
Any ideas,
Mark
Re: Stupid (hopefully easy) drag and drop question [message #436643 is a reply to message #436588] Fri, 21 May 2004 09:11 Go to previous messageGo to next message
Please post your code showing the problem.
The event.detail field only gets changed if the user presses a key. If you
have set it to DND.DROP_NONE then as you move the mouse, it will stay as
DND.DROP_NONE.
When the user presses or releases a key, you will get the
dragOperationChanged notification. In that event callback the event.detail
field is set to match the current user key combination. Note that if the
user has Ctrl down and you do not support DND.DROP_COPY, then the
event.detail will be DND.DROP_NONE. You should not be checking for specific
keys because the meaning of the keys differs from platform to platform.
See:
http://www.eclipse.org/articles/Article-SWT-DND/DND-in-SWT.h tml
"Mark Victory" <MVictory@us.ibm.com> wrote in message
news:c8h8s4$7ck$1@eclipse.org...
> in my tree:
DND.DROP_MOVE
> or DND.DROP_COPY
ctrl
> Any ideas,
> Mark
Re: Stupid (hopefully easy) drag and drop question [message #436797 is a reply to message #436643] Mon, 24 May 2004 11:15 Go to previous messageGo to next message
Hi Veronika,
Here's my code - just the drop listener.
target.addDropListener (new DropTargetAdapter() {
public void dragOver(DropTargetEvent event)
ModelElement destEle = (ModelElement)event.item.getData();
//Different feedback based on the type of object dragged over
if (destEle.getType() == IModelElement.TYPE_BLOCK)
event.feedback = DND.FEEDBACK_EXPAND | DND.FEEDBACK_SCROLL |
DND.FEEDBACK_SELECT;
else
DND.FEEDBACK_INSERT_BEFORE;
//Below is where the problem lies. I want the ELSE clause to set the
detail to be
//whatever the operation should be based on the key state - either
Copy or Move
//If I don't do the event.detail = DND.DROP_DEFAULT then the detail
will never be
//other than DND.DROP_NONE if it was ever set to DND.DROP_NONE
farther down in the code.
//I'm sure I'm just missing something obvious
//If the drag is from a particular view (favorites) then we ONLY copy
from there.
LocalSelectionTransfer lst = (LocalSelectionTransfer)types[0];
MTTransfer transfer = (MTTransfer)lst.getSelection();
if (transfer.getSource() == MTTransfer.FAVORITES)
event.detail = DND.DROP_COPY;
else
event.detail = DND.DROP_DEFAULT;
//Don't allow self dropping or dropping on successors as this causes a
recursive structure
StructuredSelection sourceSel = (StructuredSelection)transfer.getData();
//Iterate over all the selected items to see if the destination is valid
Iterator iter = sourceSel.iterator();
while (iter.hasNext())
ModelElement ele = (ModelElement)iter.next();
//Don't allow dropping if the item dragged over is an ancestor of the
item being dragged
if (ele.isAncestorOf(destEle))
event.detail = DND.DROP_NONE;
return;
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:c8kuo8$die$1@eclipse.org...
you
> DND.DROP_NONE.
event.detail
specific
> See:
item
> > in my tree:
> DND.DROP_MOVE
> > or DND.DROP_COPY
DND.DROP_NONE
like
to
> ctrl
> > Any ideas,
> > Mark
Re: Stupid (hopefully easy) drag and drop question [message #436843 is a reply to message #436797] Tue, 25 May 2004 15:49 Go to previous messageGo to next message
You are not using DND.DROP_DEFAULT correctly. It does not mean, perform the
the default operation for the current key state. It means perform the
operation that occurs when no modifier keys are pressed. The application is
not supposed to set the DND.DROP_DEFAULT into the event.detail field.
Instead, it is supposed to receive an event with the detail field set to
DND.DROP_DEFAULT and it should then change the value of event.detail to what
the application wants the default operation to be (usually DND.DROP_MOVE or
DND.DROP_COPY - if teh application does nothing, it will be set to
DND.DROP_MOVE).
If you want to change the operation depending on what target you are over,
then you will need to remember what the current key operation is in the
dragOperationChanged event:
int currentOp = DND.DROP_NONE;
public void dragEnter(DropTargetEvent event) {
currentOp = event.detail;
public void dragOver(DropTargetEvent event) {
event.detail = DND.DROP_COPY; // this is a bit bogus - you
should really check that the current op is COPY or DEFAULT - if the current
op is MOVE and you don't support MOVE, you should set the event.detail to
NONE
else
event.detail = currentOp;
public void dragOperationChanged(DropTargetEvent event) {
news:c8t2mf$kd7$1@eclipse.org...
> Hi Veronika,
> else
> detail to be
> Copy or Move
detail
> will never be
> from there.
> else
> recursive structure
valid
> item being dragged
> return;
> you
> > DND.DROP_NONE.
> event.detail
the
> specific
> > See:
> item
> > > in my tree:
> > DND.DROP_MOVE
> > > or DND.DROP_COPY
> DND.DROP_NONE
an
> like
setting
> to
the
> > ctrl
> > > Any ideas,
> > > Mark
Re: Stupid (hopefully easy) drag and drop question [message #436949 is a reply to message #436843] Wed, 26 May 2004 10:50 Go to previous message
Thanks Veronika,
I contemplated doing something like that but I was hoping that the DND
mechanism would do the "remembering" for me.
Thanks again,
Mark
news:c907hr$iac$1@eclipse.org...
the
is
what
or
> DND.DROP_MOVE).
current
> NONE
> else
> > Hi Veronika,
> > else
the
> > detail to be
either
> > Copy or Move
> detail
> > will never be
copy
> > from there.
> > else
a
> > recursive structure
> valid
the
> > item being dragged
> > return;
If
> > you
as
> > > DND.DROP_NONE.
> > event.detail
> the
> > specific
platform.
> > > See:
an
> > item
> > > > in my tree:
> > > DND.DROP_MOVE
> > > > or DND.DROP_COPY
> > DND.DROP_NONE
over
> an
> > like
> setting
> > to
> the
> > > ctrl
> > > > Any ideas,
> > > > Mark
Previous Topic:Select events not generated on Mac - 3.0M9
Next Topic:Generic Context Menus for StyledText Control
Current Time: Tue Aug 12 01:53:32 EDT 2025
Powered by FUDForum. Page generated in 0.41415 seconds
