Eclipse: debuging the mountain-climbing-way [message #436335] |
Tue, 06 September 2005 07:50  |
Originally posted by: dutz.c-ware.de
I am working on a RCP application for quite a while now and have run
into the same problem several times now. What is the reason for using
these anoying try-finally blocks without even one catch? This is realy
anoying when debuging an application. There seems to be no way of
finding the reason for an exception if it is simply thrown away. At the
moment I step through the entire code seting breakpoints at the current
position and removing the ones bevore. This is sort of
Mointain-Climbing-Debugging and it realy suxx.
Is there any way to debug a plugin in a more professional way?
Christofer Dutz
FUDForum. Page generated in 0.05896 seconds
