Home » Eclipse Projects » Rich Client Platform (RCP) » Groups and scrolling
Groups and scrolling [message #436492] Fri, 09 September 2005 09:32 Go to next message
Originally posted by: bdberry.us.ibm.com
I have created a composite and set the layout to FillLayout. This
composite contains three Groups vertically and each groups contains a
variety of user input fields. However, as inputs are added to each
group the group does not expand as new inputs are added. I tried adding
V_SCROLL and H_SCROLL to the composite and although the scroll bars
appear - they have no effect. So what I have is useless scrollbars and
inputs that are rendered outside each groups viewable area so you cant
see them - help!
Re: Groups and scrolling [message #436495 is a reply to message #436492] Fri, 09 September 2005 09:58 Go to previous messageGo to next message
Hi Brian,
If you're adding input fields to the Groups after they have been laid out
then you need to invoke layout() on your Composite, which will update the
sizes of each of its Group children to their desired sizes based on their
contents.
Also, if you want to create a Composite with an active scrollbar then it's
easiest to use a ScrolledComposite.
Grant
"Brian Berry" <bdberry@us.ibm.com> wrote in message
news:dfs2tb$btr$1@news.eclipse.org...
> see them - help!
> Thanks
Re: Groups and scrolling [message #436498 is a reply to message #436495] Fri, 09 September 2005 11:10 Go to previous messageGo to next message
Grant Gayed wrote:
> Hi Brian,
> contents.
> Grant
>>Hi,
>>see them - help!
>>Thanks
ok that does not seem to have any effect. Here is what i have (keep in
mind that i am new at this).
protected void createTab (TabFolder folder){
TabItem item = null;
ScrolledComposite parent = null;
Group groupAttributes = null;
Group groupCustomerInfo = null;
Group groupDeliveryGeo = null;
Group groupEngagementManagement = null;
Group groupServicePlanning = null;
item = new TabItem(folder, SWT.BORDER);
item.setText("Details");
parent = new ScrolledComposite (folder, SWT.BORDER | SWT.V_SCROLL);
parent.setLayout(new FillLayout(SWT.VERTICAL));
groupAttributes = new Group (parent, SWT.SHADOW_ETCHED_IN);
groupAttributes.setText("Engagement Attributes");
groupCustomerInfo = new Group (parent, SWT.SHADOW_ETCHED_IN);
groupCustomerInfo.setText("Customer Information");
groupDeliveryGeo = new Group (parent, SWT.SHADOW_ETCHED_IN);
groupDeliveryGeo.setText("Delivery Geographics");
groupEngagementManagement = new Group (parent, SWT.SHADOW_ETCHED_IN);
groupEngagementManagement.setText("Delivery Geographics");
groupServicePlanning = new Group (parent, SWT.SHADOW_ETCHED_IN);
groupServicePlanning.setText("Delivery Geographics");
buildAttributes(groupAttributes);
buildCustomerInfo(groupCustomerInfo);
buildGeo(groupDeliveryGeo);
buildEngagementManagement(groupDeliveryGeo);
buildServicePlanning(groupDeliveryGeo);
folder.layout();
parent.layout();
item.setControl(parent);
here is a sample of a build method...
protected void buildServicePlanning(Composite parent) {
parent.setLayout(new GridLayout(4, true));
Label label = null;
GridData gridData = null;
label = new Label(parent, SWT.None);
label.setText("Service Planning:");
gridData = new GridData();
gridData.horizontalAlignment = SWT.RIGHT;
label.setLayoutData(gridData);
Any ideas?
Re: Groups and scrolling [message #436501 is a reply to message #436498] Fri, 09 September 2005 11:35 Go to previous messageGo to next message
Hi Brian,
It looks like the problem that you're having with the scrolled composite
is that you're using the SC as a parent for your group items. Try
instead using a regular composite as a child of the scrolled composite
and then setting the contents of the scrolled composite to be the
underlying composite. There is a really good snippet of how to use
scrolled composites on the api at
http://download.eclipse.org/eclipse/downloads/documentation/ 2.0/html/plugins/org.eclipse.platform.doc.isv/reference/api/ org/eclipse/swt/custom/ScrolledComposite.html
Yesh, thats a long URL
Hope that helps,
Ben
Brian Berry wrote:
> Grant Gayed wrote:
>> Hi Brian,
>> contents.
>> it's
>> Grant
>>> Hi,
>>> see them - help!
>>> Thanks
> folder.layout();
> parent.layout();
> Label label = null;
> Any ideas?
Re: Groups and scrolling [message #436502 is a reply to message #436495] Fri, 09 September 2005 11:57 Go to previous messageGo to next message
Grant Gayed wrote:
> Hi Brian,
> contents.
> Grant
>>Hi,
>>see them - help!
>>Thanks
folder.layout();
parent.layout();
Label label = null;
Any ideas?
Re: Groups and scrolling [message #436505 is a reply to message #436501] Fri, 09 September 2005 15:35 Go to previous message
Ben Brown wrote:
> Hi Brian,
> Hope that helps,
> Ben
> Brian Berry wrote:
>> Grant Gayed wrote:
>>> Hi Brian,
>>> out
>>> the
>>> their
>>> contents.
>>> it's
>>> Grant
>>>> Hi,
>>>> adding
>>>> see them - help!
>>>> Thanks
>> in mind that i am new at this).
>> SWT.V_SCROLL);
>> folder.layout();
>> parent.layout();
>> Label label = null;
>> GridData gridData = null; label = new
>> label.setText("Service Planning:"); gridData =
>> new GridData();
>> Any ideas?
That worked great - thanks!
another change I had to make was item.setControl(scrolledParent);
I had it sent to the old parent and that was giving errors.
Previous Topic:Deployed RCP Enteprise Applications
Next Topic:user-addable plugins
Current Time: Mon Sep 15 14:43:16 EDT 2025
Powered by FUDForum. Page generated in 0.03674 seconds
