Home » Eclipse Projects » Rich Client Platform (RCP) » Non Plugin Depeadant Project
Non Plugin Depeadant Project [message #436238] Fri, 02 September 2005 19:02 Go to next message
I have a plugin project (RCP Application) and have set the project
properties to include another project that has all my persistant
classes. Compilation is fine when I reference the classes in my source
but when I run the RCP application from within Eclipse I get class not
found exceptions for any class in the dependent project. Any help
would be appreciated.
Thanks in advance,
Jim
Re: Non Plugin Dependent Project [message #436279 is a reply to message #436238] Mon, 05 September 2005 10:06 Go to previous messageGo to next message
The build path is what Eclipse uses to compile the application.
The runtime classpath is provided by the references in plugin.xml/MANIFEST.MF.
So chances are, you've got an entry wrong in the plugin/MANIFEST.MF file. If you do a PDE Update Classpath, it might fix them automatically; but if not, check those files manually.
Re: Non Plugin Dependent Project [message #436280 is a reply to message #436279] Mon, 05 September 2005 10:11 Go to previous message
Thanks Alex - it was the Manifest file.
Previous Topic:How do i make a search ?
Next Topic:Disable "Open a perspective" in perspective bar
Current Time: Mon Jul 21 00:26:09 EDT 2025
Powered by FUDForum. Page generated in 0.03148 seconds
