Home » Eclipse Projects » Standard Widget Toolkit (SWT) » why the toolbar can move to the bottom of the window?
why the toolbar can move to the bottom of the window? [message #436033] Sun, 09 May 2004 22:12 Go to next message
Originally posted by: Hongu.accelcion.com
ToolBar toolBar = new ToolBar(avp.getShell(), SWT.VERTICAL);
Originally I put the toolbar on the left of the window.But if keep
the window running for a long time,the toolbar move to the bottom of the
window .
what is the reason?
in addition,In my programm,it open a child window when the main
window opened.But after a long time ,the two windows merge into only a
window,the child window at the bottom of the main window too?why?
Re: why the toolbar can move to the bottom of the window? [message #436207 is a reply to message #436033] Wed, 12 May 2004 19:22 Go to previous message
Sounds like a problem with the layout manager you're using. If it's a
custom layout manager, check over your code carefully. I'd set some
break points and monitor the values passed into the layout(Composite,
boolean) method very closely. If it is a layout which comes with SWT
(i.e. a member of the org.eclipse.swt.layout package), then check your
configuration.
Daniel
>window .
>what is the reason?
Previous Topic:Cursors, Texts, and GTK
Next Topic:about event patch
Current Time: Sat Jul 19 04:00:30 EDT 2025
Powered by FUDForum. Page generated in 0.04104 seconds
