Home » Eclipse Projects » Rich Client Platform (RCP) » How to add menus programmatically?
How to add menus programmatically? [message #435648] Sat, 20 August 2005 16:47 Go to next message
How can I add menus programmatically in my plugin?
Re: How to add menus programmatically? [message #435649 is a reply to message #435648] Sat, 20 August 2005 17:10 Go to previous messageGo to next message
In your WorkbenchAdvisor get the MenuManager in fillActionBars and use
the add-method to put them in the menu.
Cheers
Marc
Re: How to add menus programmatically? [message #435654 is a reply to message #435649] Sun, 21 August 2005 04:57 Go to previous messageGo to next message
As far as I understand, this method is applicable with RCP application,
but what should I do if I have only a plugin class? How should I call
WorkbenchAdvisor? Or how could I get reference to MenuManager of the
main menu within plugin class?
Andrey.
Marc Heimann пишет:
> Cheers
> Marc
Re: How to add menus programmatically? [message #435661 is a reply to message #435654] Mon, 22 August 2005 04:38 Go to previous messageGo to next message
AFAIK the RCP framework extensions of the workbench classes are the
only objects capable of contributing to the workbench menu and toolbar
programmatically. If you need to contribute from within a plugin
you'll have to extend the corresponding extension points in your
plugin manifest (plugin.xml).
We're currently struggling with this basically very flexible concept
because we have no control which contribution that has been described
using the static way via the manifest (XML) shall be active at
runtime (dynamically) implementing a kind of role based contribution
filter ("user X in role Y shall see contribution A but not B").
If you don't need to filter the contributions extending the
corresponding extension points is the way to go.
In your workbench ActionBarAdvisor implementation you should set up
your basic menu and toolbar structure (File, Edit, Window Help etc.)
programmatically. All remaining contributions can be described very
conveniently using XML (plugin.xml).
Hope that helps,
Marcus
Re: How to add menus programmatically? [message #435714 is a reply to message #435661] Mon, 22 August 2005 09:37 Go to previous message
Thank you for the answer, but the real problem is that I need a some
dynamic menu items contributed through plugins.
May be the solution could be in creation of new extension point for that
purpose.
Andrey.
Marcus Olk пишет:
>> application, but what should I do if I have only a plugin class? How
>> should I call WorkbenchAdvisor? Or how could I get reference to
>> MenuManager of the main menu within plugin class?
> Hope that helps,
> Marcus
Previous Topic:Modality of detached views
Next Topic:extends org.eclipse.search
Current Time: Sat Aug 30 19:33:18 EDT 2025
Powered by FUDForum. Page generated in 0.03406 seconds
