Home » Eclipse Projects » Dali » Thoughts on JPA 2.0 metamodel generation in Dali 3.0
Thoughts on JPA 2.0 metamodel generation in Dali 3.0 [message #435552] Tue, 21 July 2009 11:28 Go to next message
Hi team, I missed the planning meeting but did see the minutes and this
item was listed. Perhaps it is too early to get more details, but would
like to know your thoughts on how this is being planned to be addressed in
3.0:
1) Will there be way to hook in provider specific annotation processors,
perhaps based on the platform set in the JPA facet?
2) How should the generated metamodel classes be treated if the annotation
processor runs as part of a build (i.e. builder): as derived? If derived,
then what if the user wants to modify/add to the generated metamodel
classes during development (i.e. his changes will get overwritten). If
not derived, there might be issues with source control constantly asking
to check in/out the files.
3) Will there be issues with Java 6's auto discovery mechanism of
annotation processors that happen to be on the build path? i.e. the
annotation processor running for JPA bean classes that do not need
metamodel generation.
4) Should there be an option to explicity run a metamodel generation
operation or is this best left for adopters to add if they choose to?
5) Refactoring of jpa class elements and the re-generation of metamodel
classes and then refactoring the queries: guess this is an opportunity for
more tooling too.
Just some of the starter issues that pop into my head :), this whole
concept of generation of artifacts *during* the development cycle which
can possibly be modified by the user opens up a whole new can of worms :)
Re: Thoughts on JPA 2.0 metamodel generation in Dali 3.0 [message #435553 is a reply to message #435552] Wed, 22 July 2009 17:38 Go to previous messageGo to next message
Hi Len,
I'll answer your questions inline. Our direction on this front has
changed a bit since the meetings, but of course things are not yet set in
stone.
> 3.0:
We are actually moving in a non-APT direction for this at the moment. The
reason being that activating this type of processing could be a painful
thing in the UI for large projects. We can much more efficiently listen
to our own JPA model and make more granular updates to the canonical
meta-model, as opposed to doing wholesale generation on compilation. We
think the effort to do this is probably worth the possible performance
depredation we would expect to see by including additional compile time
processing.
This all assumes that we want an "automated" solution, as opposed to just
a (generate once in a while) user directed solution, although there would
still be problems with cleaning up deleted entities in this case. The
non-APT solution offers a number of advantages.
We currently don't see any use cases for the user modifying the generated
canonical metamodel. The classes will be marked @Generated and any user
changes will be overwritten by our updates.
Yes, this could be a problem, depending on how Eclipse handles this
auto-discovery mechanism. I'm not sure how this is handled so there will
need to be more investigation done here. I don't think this is
necessarily a Dali issue, but one that could impact JPA Tooling.
Based on our current design, the metamodel generation would either be on
or off, so not sure having an explicit generation option would make sense.
> more tooling too.
Yep. We are certainly looking at this refactoring as something to go
along with this functionality. It is in our tentative plans at the moment.
There are definitely several worm cans being opened with this new JPA 2.0
requirement. If you have any thoughts on user modification scenarios,
that would be helpful.
Neil
Re: Thoughts on JPA 2.0 metamodel generation in Dali 3.0 [message #468441 is a reply to message #435553] Wed, 05 August 2009 10:30 Go to previous message
Thanks for the info Neil, I will get back to this thread later with some
Re: Thoughts on JPA 2.0 metamodel generation in Dali 3.0 [message #616667 is a reply to message #435552] Wed, 22 July 2009 17:38 Go to previous message
Hi Len,
stone.
> 3.0:
processing.
> more tooling too.
Neil
Re: Thoughts on JPA 2.0 metamodel generation in Dali 3.0 [message #617456 is a reply to message #435553] Wed, 05 August 2009 10:30 Go to previous message
Previous Topic:JPA dali, moving the persistence.xml
Next Topic:How do I turn off JPA validation?
Current Time: Wed Jul 23 19:54:49 EDT 2025
Powered by FUDForum. Page generated in 0.05825 seconds
