Home » Archived » OHF » STEM : Exception launching the Eclipse Platform
STEM : Exception launching the Eclipse Platform [message #43287] Tue, 01 July 2008 08:20 Go to next message
Hi All,
I have been trying to use STEM as a developer.
I downloaded the source code, set up eclipse and was trying to run the
application through eclipse now.
I got a successful build.
But when I try to run the application by running feature.product from
org.eclipse.ohf.stem.ui, I get the following message:
!SESSION Tue Jul 01 12:49:49 BST 2008
!ENTRY org.eclipse.equinox.launcher 4 0 2008-07-01 12:49:49.298
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException:
org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 546)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
I did everything as was mentioned in the installation guide except for one
part in eclipse installation about Installing Additional Eclipse Features.
Here I skipped the eclipse-contrib part as I dont intend to install a new
version of Eclipse. Also, I could not find the HelpšSoftware
UpdatesšManage Configuration in the Eclipse Ganymede version.
Could some one please help with solving this problem.
Amit
Re: STEM : Exception launching the Eclipse Platform [message #43518 is a reply to message #43287] Mon, 07 July 2008 11:59 Go to previous message
Amit,
sorry for the tardy reply, I've just returned from vacation....
You can create a good launch configuration by running from stem.product in
the org.eclipse.ohf.stem.ui plugin
Daniel Ford
IBM Almaden Research Center
San Jose, CA
"Amit Parwani" <aparwani@gmail.com> wrote in message
news:3741152ba1c5e6980c368f5066539289$1@www.eclipse.org...
> Hi All, I have been trying to use STEM as a developer. I downloaded the
> source code, set up eclipse and was trying to run the application through
> eclipse now. I got a successful build. But when I try to run the
> application by running feature.product from org.eclipse.ohf.stem.ui, I
> 2008 ------------------------------------------
> !STACK
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
Re: STEM : Exception launching the Eclipse Platform [message #585765 is a reply to message #43287] Mon, 07 July 2008 11:59 Go to previous message
Amit,
Daniel Ford
San Jose, CA
> !STACK
Previous Topic:Error testing SubmitTest
Next Topic:New stable build of IHE and Bridge components now available
Current Time: Sun Jul 27 06:38:04 EDT 2025
Powered by FUDForum. Page generated in 0.03599 seconds
