Home » Eclipse Projects » Dali » Dali Disappeared?
Dali Disappeared? [message #434276] Thu, 02 November 2006 03:14 Go to next message
I'm not sure exactly when it went away so it's a little difficult to guess
what may have caused it, but Dali has disappeared on my system.
I tried reinstalling it and running eclipse with --clean again, but no
dice. Eclipse just doesn't see Dali anymore.
I have double-checked that all the dependencies are installed, and I
checked the log for errors and didn't find any. After removing my
plugins directory from my workspace, it got recreated when I restarted
Eclipse, but the directories for Dali are not created.
I am using Eclipse 3.2.1, EMF SDO v 2.2.0 200609210005, GEF 3.2.1
20060921, JEM 1.2.2 20061027 and WST 1.5.2 200610140800. Some of these
are newer versions than those bundled with the "all in one"... are there
known compatibility issues? Will I need to downgrade to use Dali? Are
there other things I can do to try to discover the nature of the problem
and/or get more detail?
Re: Dali Disappeared? [message #434278 is a reply to message #434276] Fri, 03 November 2006 13:44 Go to previous message
I don't think there should be any problems with running these newer
versions with Dali.
Go to the Help menu-> About Eclipse-> Configuration Details... copy the
text and paste it here so I can take a closer look at your configuration.
This should help us get to the bottom of the problem.
Neil
Re: Dali Disappeared? [message #591007 is a reply to message #434276] Fri, 03 November 2006 13:44 Go to previous message
versions with Dali.
Neil
Previous Topic:Testing Strategy
Next Topic:mappedBy reference superclass properties
Current Time: Wed Jul 23 11:45:00 EDT 2025
Powered by FUDForum. Page generated in 0.06917 seconds
