dali getting started page using Dali 0.5 [message #434035] |
Tue, 03 October 2006 12:49  |
Hi on the Getting Started Page
(http://www.eclipse.org/dali/gettingstarted.html) it says:
To make an existing POJO an Entity:
* Right-click on your Class in the Package Explorer and choose
Persistence -> Make Java Persistence Entity
When I right-click the Pojo in Package Explorer as directed, their is no
item "Persistence -> Make Java Persistence Entity" available in the
popup menu? I was successfully able to add persistence to the Java
Project. Any ideas?
thx
Ali
Re: dali getting started page using Dali 0.5 [message #434038 is a reply to message #434037] |
Wed, 04 October 2006 07:49  |
many thx Neil. That worked.
Neil Hauge wrote:
> Make sure you are right-clicking on the actual Type node in the
> Explorer, as opposed to the .java file node. Expand the .java node to
> see the Type node.
> Neil
>> no item "Persistence -> Make Java Persistence Entity" available in
>> the popup menu? I was successfully able to add persistence to the
>> Java Project. Any ideas?
Re: dali getting started page using Dali 0.5 [message #589272 is a reply to message #434035] |
Tue, 03 October 2006 17:35  |
Make sure you are right-clicking on the actual Type node in the Explorer,
as opposed to the .java file node. Expand the .java node to see the Type
node.
Neil
> Project. Any ideas?
Re: dali getting started page using Dali 0.5 [message #589282 is a reply to message #434037] |
> see the Type node.
> Neil
FUDForum. Page generated in 0.03963 seconds
