Home » Eclipse Projects » Dali » @ManyToMany kind of working...
@ManyToMany kind of working... [message #433971] Wed, 24 May 2006 10:33 Go to next message
The @ManyToMany relationship is sort of being recognized. The following
code snippet (part of the Kodo tutorial) is properly recognized when
generating the ddl. That is, it created the RABBIT_CHILDREN table just
fine.
@ManyToMany
@JoinTable(name="RABBIT_CHILDREN",
joinColumns=@JoinColumn(name="PARENT_ID"),
inverseJoinColumns=@JoinColumn(name="CHILD_ID"))
private Set<Rabbit> children = new HashSet<Rabbit> ();
But, the Persistence Properties panel is still confused. That panel
doesn't show the name of any join table and, of course, it doesn't show
any of the join columns. (One time, the Persistence Panel actually came
up as Transient. When I changed it to ManyToMany, the panels came back to
"normal" -- minus the join table information mentioned earlier.)
If I try to type in the values on the Persistence Properties panel, I get
an NPE when I click to add a join column...
at
org.eclipse.dali.ui.views.JoinColumnInJoinTableDialog.popula teNameCombo(JoinColumnInJoinTableDialog.java:101)
at
org.eclipse.dali.ui.views.JoinColumnInJoinTableDialog.create DialogArea(JoinColumnInJoinTableDialog.java:76)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java: 802)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1124)
at org.eclipse.jface.window.Window.open(Window.java:785)
at
org.eclipse.dali.ui.views.JoinTableComposite.addJoinColumnFr omDialog(JoinTableComposite.java:427)
at
org.eclipse.dali.ui.views.JoinTableComposite.addJoinColumn(J oinTableComposite.java:423)
at
org.eclipse.dali.ui.views.JoinTableComposite.access$2(JoinTa bleComposite.java:421)
at
org.eclipse.dali.ui.views.JoinTableComposite$2.widgetSelecte d(JoinTableComposite.java:177)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:615)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Thanks for any insights,
Kevin
Re: @ManyToMany kind of working... [message #433972 is a reply to message #433971] Wed, 24 May 2006 11:46 Go to previous messageGo to next message
We noticed this one after we put out the M3a build and actually put up a
new weekly build in case anyone came across this. Take a look at the
downloads page and get the latest build.
Karen
Re: @ManyToMany kind of working... [message #433974 is a reply to message #433972] Wed, 24 May 2006 12:15 Go to previous message
Once again, you are on the money. This "dali-N-dali-200605191816.zip"
drop did the trick with the @ManyToMany Persistence panel. Thanks!
Kevin
Re: @ManyToMany kind of working... [message #588810 is a reply to message #433971] Wed, 24 May 2006 11:46 Go to previous message
Karen
Re: @ManyToMany kind of working... [message #588823 is a reply to message #433972] Wed, 24 May 2006 12:15 Go to previous message
Kevin
Previous Topic:Couple of problems with generated ddl
Next Topic:problems with jdt...
Current Time: Fri Jul 25 23:44:24 EDT 2025
Powered by FUDForum. Page generated in 0.04546 seconds
