Home » Eclipse Projects » Dali » New NPE when opening Project?
New NPE when opening Project? [message #433966] Tue, 23 May 2006 16:29 Go to next message
I didn't find this in the forum or bug database... Bug 143301 looks to be
very similar, but the line numbers were different, so I'm not positive
it's the same problem. I'll let the experts decide...
I decided to try to import the Kodo tutorial classes (Animal, Dog, Rabbit,
etc) into my Dali environment. I am getting several NPE's and
IndexOutOfRange errors. To easily reproduce, if I close my Project and
re-open it (while connected to my Derby database), I get the following
NPE. If we can get by this one, then maybe the others will resolve
themselves. If not, I know how to append to this forum... :-)
at
org.eclipse.dali.orm.impl.EntityImpl.setSpecifiedName(Entity Impl.java:244)
at
org.eclipse.dali.orm.adapters.java.JavaEntityModelAdapter$1. setPersValue(JavaEntityModelAdapter.java:100)
at
org.eclipse.dali.orm.adapters.java.AbstractAnnotationElement Adapter.updatePersElement(AbstractAnnotationElementAdapter.j ava:76)
at
org.eclipse.dali.orm.adapters.java.JavaEntityModelAdapter.up datePersSpecifiedName(JavaEntityModelAdapter.java:165)
at
org.eclipse.dali.orm.adapters.java.JavaEntityModelAdapter.up datePersModel(JavaEntityModelAdapter.java:133)
at
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.updatePersTypeMapping(JavaPersistentTypeModelAdapter.j ava:167)
at
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.updatePersModel(JavaPersistentTypeModelAdapter.java:11 5)
at
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.addPersistentType(JavaPersistenceFileModelAdapter.jav a:166)
at
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.updatePrimaryType(JavaPersistenceFileModelAdapter.jav a:143)
at
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.updateModel(JavaPersistenceFileModelAdapter.java:71)
at
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.updatePersModel(JavaPersistenceFileModelAdapter.java: 60)
at
org.eclipse.dali.orm.impl.PersistenceFileImpl.engageModel(Pe rsistenceFileImpl.java:97)
at
org.eclipse.dali.orm.impl.PersistenceContainerImpl.getPersis tenceFile(PersistenceContainerImpl.java:316)
at
org.eclipse.dali.orm.impl.PersistenceContainerImpl$2.visit(P ersistenceContainerImpl.java:212)
at
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:67)
at
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:76)
at
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:48)
at
org.eclipse.dali.orm.impl.PersistenceContainerImpl.synchInte rnalResources(PersistenceContainerImpl.java:244)
at
org.eclipse.dali.orm.impl.PersistenceContainerImpl$2.visit(P ersistenceContainerImpl.java:231)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.dali.orm.impl.PersistenceModelManager$ResourceCh angeProcessor.checkForPersistenceFilesBeingAddedOrRemoved(Pe rsistenceModelManager.java:244)
at
org.eclipse.dali.orm.impl.PersistenceModelManager$ResourceCh angeProcessor.checkForPersistenceFilesBeingAddedOrRemoved(Pe rsistenceModelManager.java:255)
at
org.eclipse.dali.orm.impl.PersistenceModelManager$ResourceCh angeProcessor.resourceChanged(PersistenceModelManager.java:2 14)
at
org.eclipse.dali.orm.impl.PersistenceModelManager$ResourceCh angeListener.resourceChanged(PersistenceModelManager.java:17 1)
at
org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:280)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:274)
at
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:148)
at
org.eclipse.core.internal.resources.Workspace.broadcastPostC hange(Workspace.java:256)
at
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:958)
at
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:45)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Re: New NPE when opening Project? [message #433967 is a reply to message #433966] Tue, 23 May 2006 18:03 Go to previous messageGo to next message
Hey Kevin,
Looks like the same problem, have you tried removing the name annotation
element from each Entity? So change @Entity(name="Animal") to just
@Entity, that's the same as the default setting anyway. I'd say we need
to fix this one for M4, since I think it was broken in M3.
Karen
Re: New NPE when opening Project? [message #433969 is a reply to message #433967] Wed, 24 May 2006 09:53 Go to previous messageGo to next message
Karen,
You are impressive. Removing the "name" parameter allowed me to open the
project and actually do some persistence activity. I still have some
bugs, but I will open separate forum entries to track those.
My question to you is how did you know that I had "@Entity(name="Animal")"
in my code? Are you familiar with these samples? Or, did the callstack
just clue you into the fact that I *must* have that to cause the error
reported? Just curious.
Thanks again,
Kevin
Re: New NPE when opening Project? [message #433973 is a reply to message #433969] Wed, 24 May 2006 11:59 Go to previous message
Well, the bug you pointed out was for having the entity name annotation
element set and then I googled for the Kodo tutorial classes. I wasn't
reading your mind or anything :)
Karen
Re: New NPE when opening Project? [message #585552 is a reply to message #433966] Tue, 23 May 2006 18:03 Go to previous message
Hey Kevin,
Karen
Re: New NPE when opening Project? [message #588770 is a reply to message #433967] Wed, 24 May 2006 09:53 Go to previous message
Karen,
Thanks again,
Kevin
Re: New NPE when opening Project? [message #588817 is a reply to message #433969] Wed, 24 May 2006 11:59 Go to previous message
Karen
Previous Topic:0.5M3a: Default FetchType for *ToMany
Next Topic:Viewlet Demos Update for M3
Current Time: Fri Jul 25 23:53:30 EDT 2025
Powered by FUDForum. Page generated in 0.04754 seconds
