Dali plugin problem [message #433780] |
Sat, 22 April 2006 08:04  |
Originally posted by: jakieskonto1.wp.pl
I use Eclipse SDK 3.2.0 with Build id: I20060223-1656 with dali-R-0.5M2
plugin. I also have installed all necessary prerequisites, so everything
looks ok when I check my eclipse configuration in manager configuration.
When I open persistence perspective everything looks also ok, but when I
star to work I receive the following exceptions:
Problems occurred when invoking code from plug-in: "org.eclipse.jface"
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:3333)
at org.eclipse.swt.SWT.error(SWT.java:3272)
at org.eclipse.swt.SWT.error(SWT.java:3243)
at org.eclipse.swt.widgets.Widget.error(Widget.java:432)
at org.eclipse.swt.widgets.Combo.add(Combo.java:144)
at
org.eclipse.dali.ui.PersistenceProjectPropertiesPage.populat eSchemaNameCombo(PersistenceProjectPropertiesPage.java:133)
at
org.eclipse.dali.ui.PersistenceProjectPropertiesPage.createC ontents(PersistenceProjectPropertiesPage.java:92)
at
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:232)
at
org.eclipse.jface.preference.PreferenceDialog.createPageCont rol(PreferenceDialog.java:1351)
at
org.eclipse.jface.preference.PreferenceDialog$12.run(Prefere nceDialog.java:1118)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:816)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1112)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:429)
at
org.eclipse.jface.preference.PreferenceDialog$8.selectionCha nged(PreferenceDialog.java:630)
at
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:802)
at
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:800)
at
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1513)
at
org.eclipse.jface.preference.PreferenceDialog.selectSavedIte m(PreferenceDialog.java:920)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sel ectSavedItem(FilteredPreferenceDialog.java:472)
at
org.eclipse.jface.preference.PreferenceDialog$3.run(Preferen ceDialog.java:334)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.jface.preference.PreferenceDialog.createContents (PreferenceDialog.java:330)
at org.eclipse.jface.window.Window.create(Window.java:420)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1101)
at
org.eclipse.ui.internal.dialogs.PropertyDialog.createDialogO n(PropertyDialog.java:76)
at
org.eclipse.ui.dialogs.PropertyDialogAction.createDialog(Pro pertyDialogAction.java:174)
at
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:155)
at
org.eclipse.ui.internal.ide.actions.ProjectPropertyDialogAct ion.run(ProjectPropertyDialogAction.java:76)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:492 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:480)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3287)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2907)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:417)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
and another:
"org.eclipse.ui.workbench"
at
org.eclipse.dali.ui.views.TableComposite.populateTableCombo( TableComposite.java:191)
at
org.eclipse.dali.ui.views.TableComposite.populate(TableCompo site.java:174)
at
org.eclipse.dali.ui.views.EntityComposite.populateTablePanel (EntityComposite.java:350)
at
org.eclipse.dali.ui.views.EntityComposite.populate(EntityCom posite.java:324)
at
org.eclipse.dali.ui.views.PersistentTypeComposite.populate(P ersistentTypeComposite.java:173)
at
org.eclipse.dali.ui.views.PersistentTypeComposite.populate(P ersistentTypeComposite.java:156)
at
org.eclipse.dali.ui.views.PersistencePropertiesView.populate (PersistencePropertiesView.java:69)
at
org.eclipse.dali.ui.views.PersistencePropertiesView.setPersi stenceFile(PersistencePropertiesView.java:97)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.setPersiste nceFile(PersistenceOutlineView.java:335)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.setActiveIn put(PersistenceOutlineView.java:297)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.handlePartR ef(PersistenceOutlineView.java:125)
at
org.eclipse.dali.ui.views.PersistenceOutlineView.access$0(Pe rsistenceOutlineView.java:118)
at
org.eclipse.dali.ui.views.PersistenceOutlineView$1.partBroug htToTop(PersistenceOutlineView.java:85)
at
org.eclipse.ui.internal.PartListenerList2$2.run(PartListener List2.java:83)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at
org.eclipse.ui.internal.PartListenerList2.fireEvent(PartList enerList2.java:54)
at
org.eclipse.ui.internal.PartListenerList2.firePartBroughtToT op(PartListenerList2.java:81)
at
org.eclipse.ui.internal.PartService.firePartBroughtToTop(Par tService.java:90)
at
org.eclipse.ui.internal.WorkbenchPagePartList.firePartBrough tToTop(WorkbenchPagePartList.java:75)
at
org.eclipse.ui.internal.WorkbenchPagePartList.fireActiveEdit orChanged(WorkbenchPagePartList.java:51)
at org.eclipse.ui.internal.PartList.setActiveEditor(PartList.ja va:143)
at
org.eclipse.ui.internal.WorkbenchPage.makeActiveEditor(Workb enchPage.java:1128)
at
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2903)
at
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:2512)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:249)
at org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:88)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:295)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 116)
at
org.eclipse.ui.internal.PartStack.presentationSelectionChang ed(PartStack.java:788)
at org.eclipse.ui.internal.PartStack.access$0(PartStack.java:77 1)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.jav a:119)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:126)
at
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:267)
at
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:276)
at
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
at
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$2.handleEvent(DefaultTabFolder.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 60)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3138)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:19 22)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:288)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
The last problem is that some annotations are marked as not resolved, eg:
Column 'ID' can't be resolved
Table 'name' can't be resolved
etc.
Can anybody help me with this.
Re: Dali plugin problem [message #583193 is a reply to message #433782] |
Mon, 24 April 2006 18:29  |
I'm connecting to MySQL 4.1. I have connection to my database server that
I can explore in a database explorer ( I see tables etc. ). This
connection is set in Project->Properties->Java Persistence->(database
connection, schema). When I use Generate DDL tool I'm able to genate sql
script but when I choose option Run DDL on server I can't choose my
existing connection, all I can do is to choose Create a New Connection.
When I pick Create a New Connection in section Select a database manager
there is only "SQL Server", I can't see MySQL server and any others.
However I set all connection URL details to MySQL server and Test
Connection reports OK. After that sql script is run on database server,
all tables etc. are created.
So this is all I can say about database connection.
Re: Dali plugin problem [message #584819 is a reply to message #433783] |
Tue, 25 April 2006 14:59  |
Do you happen to see a duplicate connection in the Database Connection
combo?
-Neil
Dali user wrote:
FUDForum. Page generated in 0.05126 seconds
