Home » Eclipse Projects » Dali » UNCONFIRMED bug reports?
UNCONFIRMED bug reports? [message #433715] Thu, 13 April 2006 08:49 Go to next message
I opened a new bugzilla report yesterday (136379) and for some reason it
went to an UNCONFIRMED state instead of the NEW state. Reading what this
state means, it sounds like a reasonable state. But, all of my other bug
reports that I have opened went immediately to the NEW state. And, I have
noticed other bug reports being opened since mine that are also in the NEW
state. Did I do something "wrong" when opening this bug report that
caused this UNCONFIRMED state? I'd like to get it to the NEW state, if
possible. Actually, I would like to get it to a "resolved" state, but
I'll let the Dali team determine their work priorities... :-)
Thanks!
Kevin
Re: UNCONFIRMED bug reports? [message #433717 is a reply to message #433715] Thu, 13 April 2006 09:43 Go to previous messageGo to next message
Kevin,
Not sure how a bug winds up in UNCONFIRMED status, but I changed it to NEW.
Karen
Re: UNCONFIRMED bug reports? [message #433721 is a reply to message #433717] Thu, 13 April 2006 12:45 Go to previous messageGo to next message
Karen wrote:
> Kevin,
Well, someone must have enabled the UNCONFIRMED state in Bugzilla. If
you don't actually use it it should be turned off.
Cu, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: UNCONFIRMED bug reports? [message #433722 is a reply to message #433721] Thu, 13 April 2006 13:26 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Indeed, the UNCONFIRMED options were enabled for the Dali product. I've
disabled them, as they are not default behaviours.
When creating a new bug, the initial state will be NEW, and no drop-down
will be available from now on.
D.
Gunnar Wagenknecht wrote:
> Karen wrote:
>>Kevin,
> Cu, Gunnar
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: UNCONFIRMED bug reports? [message #581748 is a reply to message #433715] Thu, 13 April 2006 09:43 Go to previous message
Kevin,
Karen
Re: UNCONFIRMED bug reports? [message #581827 is a reply to message #433717] Thu, 13 April 2006 12:45 Go to previous message
Karen wrote:
> Kevin,
Cu, Gunnar
Gunnar Wagenknecht
Re: UNCONFIRMED bug reports? [message #581845 is a reply to message #433721] Thu, 13 April 2006 13:26 Go to previous message
D.
> Karen wrote:
>>Kevin,
> Cu, Gunnar
Previous Topic:NullPointerException when opening DDL wizard.
Next Topic:persistence.xml management
Current Time: Sat Jul 26 12:53:16 EDT 2025
Powered by FUDForum. Page generated in 0.05778 seconds
