Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Multithreading and Widgets
Multithreading and Widgets [message #433553] Sat, 10 April 2004 12:51 Go to next message
I wrote a chat program in Swing and I have worked for the last couple days
to convert it to SWT. Unfortunately, I have discovered a big problem with
the design of SWT that prevents me from updating the output text area from
another thread when the server sends text back.
After reading the documentation, I thought that changing this:
new Thread(this).start();
in my main class to:
Display.getCurrent().syncExec(this);
would fix the problem, but all it seems to do is put the socket listener
and the GUI controls in the same thread! Once I connect, the whole
program hangs until I kill the connection from the server.
The only solution I could think of is to declare a String variable in my
GUI class, and have the connection thread write all of its updates to it.
Then my GUI thread would have to keep strobing the variable to figure out
when it changes.
There has to be a better solution, right?
BTW, the connection listener (run() method) and the GUI controls are in
the same class.
Re: Multithreading and Widgets [message #433670 is a reply to message #433553] Sun, 11 April 2004 16:47 Go to previous messageGo to next message
1. keep a reference to the display (display) and to your text area
(text) then all you need to do is :
private void updateText(final String newText) {
//Always test for null or disposal
if(display == null || display.isDisposed()) return;
display.aSyncExec(new Runnable() {
public void run() {
//Test AGAIN for disposal on any used SWT elements here.
if(text == null || text.isDisposed()) return;
text.setText(newText);
I'm not sure it'll conpile, just typed it here ...
Basically you 'post' runnable to the the GUI Thread (the one which is
doing the loop :
if(!display.readAndDispach()) display.sleep;
Good luck, SWT rocks.
Olivier Chalouhi.
> it. Then my GUI thread would have to keep strobing the variable to
> figure out
> when it changes.
> the same class.
Re: Multithreading and Widgets [message #433678 is a reply to message #433670] Sun, 11 April 2004 23:17 Go to previous messageGo to next message
Originally posted by: news.vadalus.com
Also -- you should be doing something similar in SWING as well. SWING is
not thread safe, and unlike SWT will not force you use the UI thread
when updating the UI.
This is one of the reasons people get unexpected behaviour in their
swing apps.
> public void run() {
> doing the loop :
> Olivier Chalouhi.
>> days
>> with
>> from
>> figure out
>> when it changes.
>> the same class.
Re: Multithreading and Widgets [message #439754 is a reply to message #433678] Thu, 15 July 2004 15:00 Go to previous messageGo to next message
I need to do the same thing, but from inside of the plugin. How can I
get a reference to the display variable from inside the plugin, say
ViewPart ?
Oleg
> swing apps.
>> public void run() {
>> doing the loop :
>> Olivier Chalouhi.
>>> days
>>> with
>>> from
>>> figure out
>>> when it changes.
>>> the same class.
Re: Multithreading and Widgets [message #439755 is a reply to message #439754] Thu, 15 July 2004 15:01 Go to previous message
OOps, diregard this -- I am an idiot -- parent.getDisplay() does this.
Oleg
> ViewPart ?
> Oleg
>> is not thread safe, and unlike SWT will not force you use the UI
>> thread when updating the UI.
>> swing apps.
>>> public void run() {
>>> doing the loop :
>>> Olivier Chalouhi.
>>>> couple days
>>>> problem with
>>>> area from
>>>> listener
>>>> in my
>>>> to it. Then my GUI thread would have to keep strobing the variable
>>>> to figure out
>>>> when it changes.
>>>> the same class.
Previous Topic:Help needed embedding edtiors in a SashForm
Next Topic:Rebuilding a Table Viewer on-the-fly
Current Time: Sat Jul 19 00:33:09 EDT 2025
Powered by FUDForum. Page generated in 0.21706 seconds
