Home » Eclipse Projects » Standard Widget Toolkit (SWT) » is Table.deselectAll() missing ignoreSelect?
is Table.deselectAll() missing ignoreSelect? [message #433291] |
Tue, 06 April 2004 15:20  |
using eclipse 2.1.3
Should Table.deselectAll() set the ignoreSelect flag to true/false when
calling OS.SendMessage?
like:
ignoreSelect = true;
OS.SendMessage (handle, OS.LVM_SETITEMSTATE, -1, lvItem);
ignoreSelect = false;
Looking at the other "select" methods in Table, the call to OS.SendMessage
is surrounded by ignoreSelect=true/ignoreSelect=false. So I was wondering
why deselectAll() does not do the same.
I ask because I am running into a problem where the lack of ignoreSelect
may be causing me to go into an infinite loop with my tableViewer.
I have a composite that contains a TableViewer. I have added a
selectionChangedListener to the TableViewer. When selectionChanged, I
perform some actions that may involve changing the labels on the items in
my TableViewer, so I then call tableViewer.refresh(true). Before calling
refresh, I set a ignoreSelectionChanged flag I have to true, so that any
selection changes made during refresh will be ignored. This almost seems
to work fine except for when someone hits space then enter real quick on
the TableViewer. For some reason this sends things into an infinite loop.
I traced through the code and it looked like an additional
selectionChanged event was being placed onto the event queue during the
TableViewer refresh (by Table.deselectAll()). And by the time the event
on the event queue is run, my ignoreSelectionChanged flag is already set
back to false, so selectionChanged is being run again. Then refresh is
called, etc, etc..
I don't know why space, enter is the special key sequence to trigger this
infinite loop. I don't have any other listeners and I just want to update
the labels in my TableViewer. I tried putting ignoreSelect in
Table.deselectAll() and it seemed to fix my problem. So is that a bug?
Thanks.
Re: is Table.deselectAll() missing ignoreSelect? [message #433349 is a reply to message #433291] |
Wed, 07 April 2004 15:13   |
Yes! The code is wrong. I have fixed it and released it. Thanks a million.
"amy" <amywu@us.DELETETHISPART.ibm.com> wrote in message
news:c4uvum$p3c$1@eclipse.org...
> using eclipse 2.1.3
> like:
> called, etc, etc..
> Thanks.
Re: is Table.deselectAll() missing ignoreSelect? [message #433462 is a reply to message #433349] |
Thu, 08 April 2004 11:27   |
Great! Is there a bugzilla bug number for this defect? And was the fix
released for v3 or v2.1.3?
> > using eclipse 2.1.3
> > like:
> > called, etc, etc..
> > Thanks.
Re: is Table.deselectAll() missing ignoreSelect? [message #433467 is a reply to message #433462] |
Thu, 08 April 2004 16:29  |
It is only in 3.0. There is no bug report. The code was released just
before I answered your message so it's there now. Try it.
news:c53r1v$k4i$1@eclipse.org...
million.
> > > using eclipse 2.1.3
when
> > > like:
OS.SendMessage
wondering
ignoreSelect
in
calling
any
seems
on
loop.
the
event
set
is
> > > called, etc, etc..
this
update
bug?
> > > Thanks.
Current Time: Sat Sep 20 14:23:48 EDT 2025
Powered by FUDForum. Page generated in 0.04458 seconds
