Export plugin build problem [message #43318] |
Fri, 30 January 2009 10:22  |
I am trying to export my feature. The problem I have is I added a test
package and when I export I cannot build since the test libraries ( junit
and jmock) are not included or the test dir is in the build. When I
compile the project in Eclipse it is fine.
I suppose that I have to do something in my plugin.xml? Do I filter out
the test directory or do I have to add the libs somewhere to get this
working?
I am using Eclipse 3.4.0 on Windows.
cheers,
//mike
Re: Export plugin build problem [message #44994 is a reply to message #43536] |
Wed, 04 February 2009 15:30  |
Did you see my comment? Seems to solve your issue?
On 02.02.2009 07:29, Mikael Petterson wrote:
> I only need these for testing. The junit and jmock are added to the
> classpath in my project. I have not added them anywhere else.
> //mikael
Re: Export plugin build problem [message #590841 is a reply to message #43318] |
Fri, 30 January 2009 11:28  |
> junit and jmock) are not included or the test dir is in the build. When
> I compile the project in Eclipse it is fine.
> working?
How are you including Junit / Jmock? Are they plug-ins somewhere in your
target? Or are you including the library and listing it on your
Bundle-ClassPath?
~ Chris
Re: Export plugin build problem [message #590854 is a reply to message #43318] |
Sat, 31 January 2009 07:47  |
I've seen certain test folder excluded from copying in build.xml. This
should work as long as the junit plugin dependency is optional and the
excluded folders are not mentioned in the classpath (i.e. reside unser
../src instead of their own ./test).
Andi
Re: Export plugin build problem [message #591386 is a reply to message #43536] |
> //mikael
FUDForum. Page generated in 0.63992 seconds
