Home » Newcomers » Newcomers » Eclipse and Doja
Eclipse and Doja [message #43272] Wed, 30 March 2005 03:44 Go to next message
Originally posted by: trong.macatung.com
Hello all,
I'm try to install plugin of Doja in eclipse and test with Hello World
example.
Doja plug in => installed
Ant run => error occur :
BUILD FAILED: C:\eclipse\workspace\HelloWorldTest\build.xml:4: Could not
create task or type of type: eclipse.convertPath.
Ant could not find the task or a class this task relies upon.
This is common and has a number of causes; the usual
solutions are to read the manual pages then download and
install needed JAR files, or fix the build file:
- You have misspelt 'eclipse.convertPath'.
Fix: check your spelling.
- The task needs an external JAR file to execute
and this is not found at the right place in the classpath.
Fix: check the documentation for dependencies.
Fix: declare the task.
- The task is an Ant optional task and the JAR file and/or libraries
implementing the functionality were not found at the time you
yourself built your installation of Ant from the Ant sources.
Fix: Look in the ANT_HOME/lib for the 'ant-' JAR corresponding to the
task and make sure it contains more than merely a META-INF/MANIFEST.MF.
If all it contains is the manifest, then rebuild Ant with the needed
libraries present in ${ant.home}/lib/optional/ , or alternatively,
download a pre-built release version from apache.org
- The build file was written for a later version of Ant
Fix: upgrade to at least the latest release version of Ant
- The task is not an Ant core or optional task
and needs to be declared using <taskdef>.
- You are attempting to use a task defined using
<presetdef> or <macrodef> but have spelt wrong or not
defined it at the point of use
Remember that for JAR files to be visible to Ant tasks implemented
in ANT_HOME/lib, the files must be in the same directory or on the
classpath
Please neither file bug reports on this problem, nor email the
Ant mailing lists, until all of these causes have been explored,
as this is not an Ant bug.
Total time: 609 milliseconds
Please let me know what should I do to test this ?
Thanks.
Re: Eclipse and Doja [message #45052 is a reply to message #43272] Fri, 01 April 2005 02:49 Go to previous messageGo to next message
Hi all,
I found how to solve this => External Tool setup => JRE => choose run in the
same JRE as the workspace
It could pass this error but there's another error :
Buildfile: C:\eclipse30\workspace\HelloWorld\build.xml
init:
dist:
[exec] Error preverifying class HelloWorld
[exec] Class loading error: Illegal constant pool index
BUILD FAILED: C:\eclipse30\workspace\HelloWorld\build.xml:38: exec returned:
1
Total time: 1 second
Any ideas ?
Trong ho
"Trong Ho Van" <trong@macatung.com> wrote in message
news:d2dou2$6js$1@news.eclipse.org...
> Hello all,
> example.
> classpath
> Thanks.
Re: Eclipse and Doja [message #45066 is a reply to message #45052] Fri, 01 April 2005 03:05 Go to previous message
I found an option could let eclipse run this :
Window - options - Java - compiler - Compliance and classfile -> change to
generate .class file compatibility = 1.1
Any ways,
Thanks for this news
news:d2iuhr$9k8$1@news.eclipse.org...
> Hi all,
the
> init:
> dist:
returned:
> 1
> Any ideas ?
> Thanks
> Trong ho
> > Hello all,
> > example.
> > classpath
> > Thanks.
Previous Topic:Could not find framework msg when trying to launch Eclipse
Next Topic:Where can I find swt-win32-3064.dll source?
Current Time: Fri Nov 07 08:39:23 EST 2025
Powered by FUDForum. Page generated in 0.10832 seconds
