Home » Modeling » EMF » Persisting ecore instance as XML only persists first node of model
Persisting ecore instance as XML only persists first node of model [message #431928] Wed, 29 July 2009 15:16 Go to next message
I have been persisting my models with XMI and it has been working fine. I
wanted to start using XML to make the models easier to parse for some
usages.
When I persist with GenericXMLResourceFactory only the first (or root I
guess) object gets written to the xml file.
My models are generated using dynamic EMF, the EObjects copied to a resource
created with GenericXMLFactory, and then written.
Below is a simple example I created which demonstrates this problem. It
creates a single EObject which contains a containment reference to a second
EObject.
After stepping into XMLResourceImpl it looks like the code writes the first
EOjbect in the Resource and never wants to later write the rest. I presume I
must have some option not set correctly or such.
Any insight is greatly appreciated.
Thanks in advance.
Derek
Resulting XML:
<de:ContainingClass xmlns:de="http://test/dynamic/EMF" myAttr2="containing
class attribute value">
<myRef2 href="out.xml#/1"/>
</de:ContainingClass>
public class DynamicEMFPersistenceTest {
private EcoreFactory ecoreFactory = EcoreFactory.eINSTANCE;
private EPackage ePackage = ecoreFactory.createEPackage();
private void createEcoreModel() {
ePackage.setName("dynamicEMF");
ePackage.setNsPrefix("de");
ePackage.setNsURI("http://test/dynamic/EMF");
// Create a contained class
String containedClassName = "ContainedClass";
EClass containedEClass = this.ecoreFactory.createEClass();
containedEClass.setName(containedClassName);
EAttribute eAttr = ecoreFactory.createEAttribute();
final String myAttrName = "containedClassAttr";
eAttr.setName(myAttrName);
eAttr.setEType(EcorePackage.Literals.ESTRING);
containedEClass.getEStructuralFeatures().add(eAttr);
ePackage.getEClassifiers().add(containedEClass);
// Create the containing class
String containingClassName = "ContainingClass";
EClass containingEClass = this.ecoreFactory.createEClass();
containingEClass.setName(containingClassName);
EAttribute eAttr2 = ecoreFactory.createEAttribute();
final String myAttrName2 = "myAttr2";
eAttr2.setName(myAttrName2);
eAttr2.setEType(EcorePackage.Literals.ESTRING);
containingEClass.getEStructuralFeatures().add(eAttr2);
EReference eRef = ecoreFactory.createEReference();
String myRefName = "myRef2";
eRef.setName(myRefName);
eRef.setEType(containedEClass);
eRef.setContainment(true);
containingEClass.getEStructuralFeatures().add(eRef);
ePackage.getEClassifiers().add(containingEClass);
EObject containedClassObject =
ePackage.getEFactoryInstance().create(containedEClass);
EStructuralFeature attrFeature =
containedEClass.getEStructuralFeature(myAttrName);
containedClassObject.eSet(attrFeature, "contained class attribute value");
EObject containingClassObject =
ePackage.getEFactoryInstance().create(containingEClass);
EStructuralFeature attrFeature2 =
containingEClass.getEStructuralFeature(myAttrName2);
containingClassObject.eSet(attrFeature2, "containing class attribute
value");
EStructuralFeature refFeature =
containingEClass.getEStructuralFeature(myRefName);
containingClassObject.eSet(refFeature, containedClassObject);
EPackage.Registry.INSTANCE.put(ePackage.getNsURI(), ePackage);
URI uri = URI.createFileURI("out.xml");
Resource resource = createXmlResource(uri);
resource.getContents().add(containingClassObject);
resource.getContents().add(containedClassObject);
saveResource(resource);
public static void saveResource(Resource resource) {
try {
resource.save(null);
} catch (IOException e) {
e.printStackTrace();
private Resource createXmlResource(URI uri) {
// createGlobalEPackageRegistry();
// EMFUtil.dumpGlobalEPackageRegistry();
ResourceSet resourceSet = new ResourceSetImpl();
final ExtendedMetaData extendedMetaData = new BasicExtendedMetaData(
resourceSet.getPackageRegistry());
resourceSet.getLoadOptions().put(XMLResource.OPTION_EXTENDED _META_DATA,
extendedMetaData);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put("xml", new GenericXMLResourceFactoryImpl());
Resource resource = resourceSet.createResource(uri);
return resource;
* @param args
// TODO Auto-generated method stub
DynamicEMFPersistenceTest inst = new DynamicEMFPersistenceTest();
inst.createEcoreModel();
Re: Persisting ecore instance as XML only persists first node of model [message #431935 is a reply to message #431928] Thu, 30 July 2009 01:52 Go to previous messageGo to next message
Derek,
In contrast to XMI you can only store a single root object in an XML
document. I guess EMF just takes resource.getContents().get(0). With XML
you need to explicitely add your (former) root objects to a container
object (an instance of one of your modeled classes) and make that the
new, single root object of the resource.
Cheers
/Eike
Derek Palma schrieb:
> fine. I wanted to start using XML to make the models easier to parse
> for some usages.
> I guess) object gets written to the xml file.
> resource created with GenericXMLFactory, and then written.
> It creates a single EObject which contains a containment reference to
> a second EObject.
> first EOjbect in the Resource and never wants to later write the rest.
> I presume I must have some option not set correctly or such.
> Thanks in advance.
> Derek
> Resulting XML:
> myAttr2="containing class attribute value">
> value");
> value");
> try {
> extendedMetaData);
> return resource;
> * @param args
> public static void main(String[] args) {
Re: Persisting ecore instance as XML only persists first node of model [message #431952 is a reply to message #431935] Thu, 30 July 2009 10:09 Go to previous message
Eike,
That's right. One should use XMIResourceFactoryImpl to create an
XMIResourceImpl to serialize multiple roots.
Eike Stepper wrote:
> Derek,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi,
>> for some usages.
>> a second EObject.
>> Thanks in advance.
>> Derek
>> Resulting XML:
>> <?xml version="1.0" encoding="UTF-8"?>
>> value");
>> value");
>> try {
>> extendedMetaData);
>> return resource;
>> * @param args
Previous Topic:Getter/Setter methods when dynamically build the model
Next Topic:EMF Meta Tooling
Current Time: Sun Jul 27 14:12:30 EDT 2025
Powered by FUDForum. Page generated in 0.03210 seconds
