Home » Modeling » EMF » Dynamic subclassing of static model classes
Dynamic subclassing of static model classes [message #431909] Wed, 29 July 2009 04:52 Go to next message
Hi!
I've played around with dynamic models recently and discovered some
flaws when I've tried to dynamically subclass a static (generated) model
class. Please let me know if I should file bugs for that issues!
(1) It is not possible to instantiate a non-abstract dynamic subclass of
an abstract static base class, as the EFactory-instance tries to create
an instance of the 'nearest' static base class on instantiation which
fails due to it is abstract.
(A possible solution is discussed in 3)
(2) If a dynamic class is defined and added to a static package, the
package factory will still not be able to instantiate the dynamic class,
because the factory is generated too and only checks the static classes.
Although adding dynamic classes to static packages seems to be dirty,
maybe super.create(EClass) should be called instead of throwing an
IllegalArgumentException.
(3) When I use multiple inheritance to subclass two static Ecore classes
Rectangle and Clickable in one single dynamic class Button, the instance
b of class Button is java-instanceof Rectangle.instanceClass but not
java-instanceof Clickable.instanceClass, because - as mentioned 1) - the
factory instantiates the 'nearest' static base class and chooses the
first one in case of multiple base classes (which is S1 in our example).
This issue could be fixed by using the Java Proxy API to dynamically
instatiate a proxy that implements the instance classes (the interfaces)
of all direct static base classes.
(Note that this would also fix the issue mentioned in 1)
Mario
Re: Dynamic subclassing of static model classes [message #431922 is a reply to message #431909] Wed, 29 July 2009 12:46 Go to previous message
Mario,
Comments below.
Mario Winterer wrote:
> Hi!
> model class. Please let me know if I should file bugs for that issues!
> of an abstract static base class, as the EFactory-instance tries to
> create an instance of the 'nearest' static base class on instantiation
> which fails due to it is abstract.
Yes, this is a limitation. Clearly it's impossible to instantiate an
abstract class and yet it's needed to act as the base in order for the
dynamic instance to behave exactly like the existing implementation...
> class, because the factory is generated too and only checks the static
> classes.
You can't change generated meta data at all.
No, it's just not supported.
> classes Rectangle and Clickable in one single dynamic class Button,
> the instance b of class Button is java-instanceof
> Rectangle.instanceClass but not java-instanceof
> Clickable.instanceClass, because - as mentioned 1) - the factory
> instantiates the 'nearest' static base class and chooses the first one
> interfaces) of all direct static base classes.
I played a bit with Java dynamic proxies but in the end, it's not
possible for them to reuse an existing base class like BasicEObjectImpl
so one ends up having to delegate from the proxy to something that
duplicates all the basic implementation behavior and even then you end
up with problems where the "this" of the proxy is not the same object as
that being delegated to.
The simplest approach is simply to not make the base class abstract.
> Mario
Previous Topic:Dissolving References?
Next Topic:[CDO] SQL Exception: Failed to create database
Current Time: Sun Jul 27 14:27:23 EDT 2025
Powered by FUDForum. Page generated in 0.03511 seconds
