resource utility example unable to find hibernate [message #431894] |
Tue, 28 July 2009 14:58 |
Hello
I am trying to follow the resource-utility example at
http://www.elver.org/hibernate/resource_utility.html
and get the following exception when I try to open
the .ehb file with "teneo->open resource"
java.lang.NoClassDefFoundError: org/hibernate/property/PropertyAccessor
at
org.eclipse.emf.teneo.hibernate.eclipse.OpenResource.openDat aStore(OpenResource.java:33)
at
org.eclipse.emf.teneo.eclipse.resourcehandler.StoreOpenResou rce.run(StoreOpenResource.java:68)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
As this error has been reported before, I double checked, that
hibernate is available.
I created my own hibernate plugin which consists of the jar files from
the hibernate package. (And I also set Eclipse-BuddyPolicy: dependent)
This seems to work fine with teneo (1.1.1) in principle.
At least, I managed to access a mysql database via teneo with this
configuration.
Any ideas, please?
Kind regards Harald
Please find the relevant version-information of my target platform below:
Hibernate 3.3.2.GA
../plugins/org.eclipse.emf.converter_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.ecore.editor.source_2.5.0.v200906 151043.jar
../plugins/org.eclipse.emf.teneo_1.1.1.v200907272354.jar
../plugins/org.eclipse.emf.ecore.edit_2.5.0.v200906151043.ja r
../plugins/org.eclipse.emf.codegen.ecore_2.5.0.v200906151043 .jar
../plugins/org.eclipse.emf.teneo.eclipse_1.1.0.v200907272354 .jar
../plugins/org.eclipse.emf.mapping.xsd2ecore.editor_2.4.0.v2 00906151043.jar
../plugins/org.eclipse.emf.databinding_1.1.0.v200906151043.j ar
../plugins/org.eclipse.emf.teneo.eclipse.source_1.1.0.v20090 7272354.jar
../plugins/org.eclipse.emf.ecore.xmi.source_2.5.0.v200906151 043.jar
../plugins/org.eclipse.emf.ecore.change_2.5.0.v200906151043. jar
../plugins/org.eclipse.emf.ecore.edit.source_2.5.0.v20090615 1043.jar
../plugins/org.eclipse.emf.mapping.ui.source_2.5.0.v20090615 1043.jar
../plugins/org.eclipse.emf.teneo.hibernate_1.1.1.v2009072723 54
../plugins/org.eclipse.emf.teneo.hibernate_1.1.1.v2009072723 54/org.eclipse.emf.teneo.hibernate.extra.jar
../plugins/org.eclipse.emf.teneo.hibernate_1.1.1.v2009072723 54/org/eclipse/emf
../plugins/org.eclipse.emf.teneo.hibernate.mapper_1.1.1.v200 907272354.jar
../plugins/org.eclipse.emf.mapping.source_2.5.0.v20090615104 3.jar
../plugins/org.eclipse.emf.common.ui.source_2.5.0.v200906151 043.jar
../plugins/org.eclipse.emf.teneo.annotations.source_1.1.1.v2 00907272354.jar
../plugins/org.eclipse.emf.codegen.source_2.5.0.v20090615104 3.jar
../plugins/org.eclipse.emf.importer_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.edit.ui.source_2.5.0.v20090615104 3.jar
../plugins/org.eclipse.emf.exporter_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.importer.ecore.source_2.4.0.v2009 06151043.jar
../plugins/org.eclipse.emf.codegen_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.teneo.hibernate.eclipse.source_1. 1.0.v200907272354.jar
../plugins/org.eclipse.emf.ant.source_2.4.0.v200906151043.ja r
../plugins/org.eclipse.emf.ecore.change.edit.source_2.5.0.v2 00906151043.jar
../plugins/org.eclipse.emf.cheatsheets_2.5.0.v200906151043.j ar
../plugins/org.eclipse.emf.importer.source_2.5.0.v2009061510 43.jar
../plugins/org.eclipse.emf.importer.rose_2.5.0.v200906151043 .jar
../plugins/org.eclipse.emf.codegen.ecore.source_2.5.0.v20090 6151043.jar
../plugins/org.eclipse.emf.mapping_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.ecore.change.edit_2.5.0.v20090615 1043.jar
../plugins/org.eclipse.emf.common.ui_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.teneo.hibernate.eclipse_1.1.0.v20 0907272354.jar
../plugins/org.eclipse.emf.mapping.ecore_2.5.0.v200906151043 .jar
../plugins/org.eclipse.emf.databinding.edit.source_1.1.0.v20 0906151043.jar
../plugins/org.eclipse.emf.teneo.doc_1.1.0.v200907272354.jar
../plugins/org.eclipse.emf.mapping.xsd2ecore.source_2.5.0.v2 00906151043.jar
../plugins/org.eclipse.emf.mapping.ui_2.5.0.v200906151043.ja r
../plugins/org.eclipse.emf.converter.source_2.5.0.v200906151 043.jar
../plugins/org.eclipse.emf.databinding.edit_1.1.0.v200906151 043.jar
../plugins/org.eclipse.emf.codegen.ui.source_2.5.0.v20090615 1043.jar
../plugins/org.eclipse.emf.teneo.hibernate.mapper.source_1.1 .1.v200907272354.jar
../plugins/org.eclipse.emf.ecore.xmi_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.importer.ecore_2.4.0.v20090615104 3.jar
../plugins/org.eclipse.emf.mapping.ecore2ecore.editor_2.4.0. v200906151043.jar
../plugins/org.eclipse.emf.mapping.ecore2ecore_2.5.0.v200906 151043.jar
../plugins/org.eclipse.emf.mapping.ecore2xml_2.5.0.v20090615 1043.jar
../plugins/org.eclipse.emf.ecore.source_2.5.0.v200906151043. jar
../plugins/org.eclipse.emf.ecore_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.ecore.editor_2.5.0.v200906151043. jar
../plugins/org.eclipse.emf.mapping.ecore2ecore.source_2.5.0. v200906151043.jar
../plugins/org.eclipse.emf.edit.ui_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.mapping.ecore2xml.ui_2.5.0.v20090 6151043.jar
../plugins/org.eclipse.emf.mapping.xsd2ecore_2.5.0.v20090615 1043.jar
../plugins/org.eclipse.emf.mapping.ecore2xml.source_2.5.0.v2 00906151043.jar
../plugins/org.eclipse.emf.teneo.annotations_1.1.1.v20090727 2354.jar
../plugins/org.eclipse.emf.common.source_2.5.0.v200906151043 .jar
../plugins/org.eclipse.emf.mapping.xsd2ecore.editor.source_2 .4.0.v200906151043.jar
../plugins/org.eclipse.emf.doc_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.teneo.source_1.1.1.v200907272354. jar
../plugins/org.eclipse.emf.codegen.ecore.ui.source_2.5.0.v20 0906151043.jar
../plugins/org.eclipse.emf.codegen.ui_2.5.0.v200906151043.ja r
../plugins/org.eclipse.emf.databinding.source_1.1.0.v2009061 51043.jar
../plugins/org.eclipse.emf.edit_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.mapping.ecore2ecore.editor.source _2.4.0.v200906151043.jar
../plugins/org.eclipse.emf.mapping.ecore2xml.ui.source_2.5.0 .v200906151043.jar
../plugins/org.eclipse.emf.source_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.codegen.ecore.ui_2.5.0.v200906151 043.jar
../plugins/org.eclipse.emf.ecore.change.source_2.5.0.v200906 151043.jar
../plugins/org.eclipse.emf.importer.java.source_2.5.0.v20090 6151043.jar
../plugins/org.eclipse.emf.edit.source_2.5.0.v200906151043.j ar
../plugins/org.eclipse.emf.common_2.5.0.v200906151043.jar
../plugins/org.eclipse.emf.importer.java_2.5.0.v200906151043 .jar
../plugins/org.eclipse.emf.teneo.ui.capabilities_1.1.0.v2009 07272354.jar
../plugins/org.eclipse.emf.teneo.hibernate.source_1.1.1.v200 907272354.jar
../plugins/org.eclipse.emf.example.installer_1.1.0.v20090615 1043.jar
../plugins/org.eclipse.emf.importer.rose.source_2.5.0.v20090 6151043.jar
../plugins/org.eclipse.emf.cheatsheets.source_2.5.0.v2009061 51043.jar
../plugins/org.eclipse.emf.mapping.ecore.editor_2.5.0.v20090 6151043.jar
../plugins/org.eclipse.emf.ant_2.4.0.v200906151043.jar
../plugins/org.eclipse.emf.exporter.source_2.5.0.v2009061510 43.jar
../features/org.eclipse.emf.databinding_1.1.0.v200906151043
../features/org.eclipse.emf.codegen_2.5.0.v200906151043
../features/org.eclipse.emf.converter_2.5.0.v200906151043
../features/org.eclipse.emf.edit_2.5.0.v200906151043
../features/org.eclipse.emf.databinding.edit_1.1.0.v20090615 1043
../features/org.eclipse.emf.codegen.ui_2.4.0.v200906151043
../features/org.eclipse.emf.ecore_2.5.0.v200906151043
../features/org.eclipse.emf.teneo.doc_1.1.0.v200907272354-20 -7w311A18383465
../features/org.eclipse.emf.common.ui_2.5.0.v200906151043
../features/org.eclipse.emf.ecore.edit_2.5.0.v200906151043
../features/org.eclipse.emf.mapping.ecore_2.5.0.v20090615104 3
../features/org.eclipse.emf.edit.ui_2.5.0.v200906151043
../features/org.eclipse.emf.source_2.5.0.v200906151043
../features/org.eclipse.emf.ecore.editor_2.5.0.v200906151043
../features/org.eclipse.emf.doc_2.5.0.v200906151043
../features/org.eclipse.emf_2.5.0.v200906151043
../features/org.eclipse.emf.mapping_2.5.0.v200906151043
../features/org.eclipse.emf.codegen.ecore_2.5.0.v20090615104 3
../features/org.eclipse.emf.common_2.5.0.v200906151043
../features/org.eclipse.emf.sdk_2.5.0.v200906151043
../features/org.eclipse.emf.codegen.ecore.ui_2.5.0.v20090615 1043
../features/org.eclipse.emf.mapping.ui_2.5.0.v200906151043
../features/org.eclipse.emf.mapping.ecore.editor_2.5.0.v2009 06151043
../features/org.eclipse.emf.teneo.sdk_1.1.1.v200907272354-42 188FAGLgdL_JUAGZDIge0ESEFC
../features/org.eclipse.emf.teneo.source_1.1.1.v200907272354 -7863DZRDEBDz-Rz-RYle
../features/org.eclipse.emf.teneo_1.1.1.v200907272354-7863DZ RDEBDz-Rz-RYle
FUDForum. Page generated in 0.03760 seconds
