Home » Modeling » EMF » Controlling XML URI resolution
Controlling XML URI resolution [message #431825] Mon, 27 July 2009 17:26 Go to next message
I am loading XML files with EMF and need to control the URI resolution for
the namespace URIs. Without EMF I am used to using an EntityResolver for
this by directly registering it with the Xml parser API. I see that
org.eclipse.emf.xmi.XMEDefaultHandler seems to handle this and other related
functions. However, it is not clear what the right way to install my own
EntityResolver is. I suspect others have done this many times.
What is the typical approach for installing an EntityResolve or just hooking
URI resolution with EMF?
Thanks in advance,
Derek
Re: Controlling XML URI resolution [message #431830 is a reply to message #431825] Mon, 27 July 2009 17:43 Go to previous messageGo to next message
Hi Derek!
Have a look at the two load/save options
XMLResource.OPTION_RESOURCE_ENTITY_HANDLER and
XMLResource.OPTION_URI_HANDLER.
The values of these two options must be of type XMLResource.URIHandler and
XMLResource.ResourceEntityHandler. They allow a finde grained control over
uri resolution and entity handling. If you need both, you can implement both
interfaces in one class and provider an instance via option
OPTION_RESOURCE_ENTITY_HANDLER - XMLResource uses it as uri handler too.
Mario
"Derek Palma" <derek.palma@gmail.com> schrieb im Newsbeitrag
news:h4l631$mpb$1@build.eclipse.org...
> related functions. However, it is not clear what the right way to install
> my own EntityResolver is. I suspect others have done this many times.
> hooking URI resolution with EMF?
> Thanks in advance,
> Derek
Re: Controlling XML URI resolution [message #431875 is a reply to message #431830] Tue, 28 July 2009 11:22 Go to previous message
Note also that the URI converter of the resource set is consulted
InputStream inputStream = getURIConverter().createInputStream(uri,
options);
So with things like URI mappings or specialized URI handlers you might
be able to accomplish what you want...
Mario Winterer wrote:
> Hi Derek!
> and XMLResource.ResourceEntityHandler. They allow a finde grained
> control over uri resolution and entity handling. If you need both, you
> can implement both interfaces in one class and provider an instance
> via option OPTION_RESOURCE_ENTITY_HANDLER - XMLResource uses it as uri
> handler too.
> Mario
>> Hi,
>> resolution for the namespace URIs. Without EMF I am used to using an
>> EntityResolver for this by directly registering it with the Xml
>> parser API. I see that org.eclipse.emf.xmi.XMEDefaultHandler seems to
>> handle this and other related functions. However, it is not clear
>> what the right way to install my own EntityResolver is. I suspect
>> Thanks in advance,
>> Derek
Previous Topic:Archived resource
Next Topic:Cannot create duplicate references in non-containment list
Current Time: Sat Jul 26 23:45:45 EDT 2025
Powered by FUDForum. Page generated in 0.05944 seconds
