Home » Modeling » EMF » Resolving proxies
Resolving proxies [message #431733] Thu, 23 July 2009 08:11 Go to next message
I'm trying to get details of packages refered to from the contents
of a Ecore resource. I've tried the following code
final Map<EObject, Collection<EStructuralFeature.Setting>> externals
= EcoreUtil.ExternalCrossReferencer.find(this);
for (EObject eObject : externals.keySet()) {
final URI uri = EcoreUtil.getURI(eObject);
final EPackage ePackage =
EPackage.Registry.INSTANCE.getEPackage(uri.trimFragment().to String()));
This works when the elements of the key set are not proxies. However,
sometimes the key set contains proxies. I've tried getting the resolution
of the proxy using all three of the resolve method in EcoreUtil, but none
of them return the resolved object. Does anyone know how to get the
details of referened packages or resolve these proxies? If it makes
any difference, the proxies that I have in my test case are to elements
in the Ecore model.
thanks, Andy.
Re: Resolving proxies [message #431749 is a reply to message #431733] Thu, 23 July 2009 12:19 Go to previous messageGo to next message
Andy,
Comments below.
Hmmm...
That likely means the object can't be resolved.
I don't understand the code. What exactly are you hoping to achieve?
> If it makes
> in the Ecore model.
It sounds more like you should be walking up the containment tree of
each eObject to find the containing EPackage...
> thanks, Andy.
Re: Resolving proxies [message #431768 is a reply to message #431749] Fri, 24 July 2009 07:37 Go to previous messageGo to next message
Ed,
I'm generating the Emfatic import statements needed when
I do a Ecore xmi to Emfatic convert. Previously I was using code
that did walk the containment tree:
EObject eContainer = eObject;
while(!(eContainer instanceof EPackage)) {
eContainer = eContainer.eContainer();
final EPackage ePackage = (EPackage) eContainer;
The problem that I had was that some of the eObjects in
the externals ket set were not objects in referenced packages, but
proxies for these objects. Calling eContainer() on these
proxies returned null rather than the containing object.
The test case that I was using was the GenModel copied
to a test workspace. I've now worked out that the references
in the GenModel are relative and did not work from the
location to which I copied it. The solution is to simply
detect the presence of unresolvable proxies, output a sensible
message and to not attempt the conversion.
Thanks for your help.
Andy.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:h4a2hp$l99$2@build.eclipse.org...
> Andy,
> Comments below.
> Hmmm...
>> If it makes
>> in the Ecore model.
> It sounds more like you should be walking up the containment tree of each
>> thanks, Andy.
Re: Resolving proxies [message #431773 is a reply to message #431768] Fri, 24 July 2009 11:17 Go to previous message
Andy,
Comments below.
> Ed,
Again, proxies should be getting resolved. If that fails, something is
wrong...
Yes, that's better.
> Andy.
>> Andy,
>> Comments below.
>> Hmmm...
>>> resolution
>>> none
>>> If it makes
>>> in the Ecore model.
>>> thanks, Andy.
Previous Topic:ResourceSetImpl.createResource(URI) does not work with content type binding
Next Topic:Dynamic insertion of a Attribute
Current Time: Fri Jul 18 07:21:20 EDT 2025
Powered by FUDForum. Page generated in 0.09970 seconds
