Home » Modeling » EMF » [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType
[CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431731] Thu, 23 July 2009 08:08 Go to next message
As I mentioned in my previous message I switched from CDO 2.0 to the current CVS Head as target for
my RCP app.
When starting my app I get the below exception.
So it seems the mapping doen't like some type in my EMF model (it worked perfectly with 2.0).
But the error message is so unhandy that no one could tell what exactly the cause is. At least the
feature structure should be also named.
Also I am not sure why the EMF type "CUSTOM" is used. I am not using any special in my EMF models.
Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431732 is a reply to message #431731] Thu, 23 July 2009 08:09 Go to previous messageGo to next message
Forgot the trace:
Rollback in DBStore: java.lang.IllegalArgumentException: No suitable mapping found from EMF type
at
org.eclipse.emf.cdo.server.internal.db.mapping.TypeMappingFa ctory.createTypeMapping(TypeMappingFactory.java:255)
at
org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.createValueMapping(AbstractMappingStrategy.java:3 88)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping.createValueMappings(AbstractHor izontalClassMapping.java:119)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping.initFeatures(AbstractHorizontal ClassMapping.java:107)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping. <init>(AbstractHorizontalClassMapping.java:76)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ho rizontalNonAuditClassMapping. <init>(HorizontalNonAuditClassMapping.java:90)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ho rizontalNonAuditMappingStrategy.doCreateClassMapping(Horizon talNonAuditMappingStrategy.java:29)
at
org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.createClassMapping(AbstractMappingStrategy.java:3 55)
at
org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.mapClasses(AbstractMappingStrategy.java:325)
at
org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.mapPackageInfos(AbstractMappingStrategy.java:314)
at
org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.mapPackageUnits(AbstractMappingStrategy.java:336)
at
org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.createMapping(AbstractMappingStrategy.java:297)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write PackageUnits(DBStoreAccessor.java:501)
at org.eclipse.emf.cdo.spi.server.StoreAccessor.write(StoreAcce ssor.java:132)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.acces s$4(DBStoreAccessor.java:1)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:80)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr ogressDistributor.java:96)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write (DBStoreAccessor.java:299)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext Impl.write(TransactionCommitContextImpl.java:273)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication$1.runLoop(CommitTransactionIndication.jav a:72)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication$1.runLoop(CommitTransactionIndication.jav a:1)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicatingCommit(CommitTransactionIndicat ion.java:280)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:173)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:139)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
at org.pubcurator.core.managers.ServerManager.connectToServer(S erverManager.java:228)
at org.pubcurator.core.managers.ServerManager.connectToLocalSer ver(ServerManager.java:186)
at org.pubcurator.core.ApplicationWorkbenchAdvisor$1$1.run(Appl icationWorkbenchAdvisor.java:87)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
> current CVS Head as target for my RCP app.
> the cause is. At least the feature structure should be also named.
> Regards,
> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431734 is a reply to message #431732] Thu, 23 July 2009 08:30 Go to previous messageGo to next message
Ok, here lies the problem.
My model has indeed a custom field (EJavaObject), but I never commit any of those objects with this
feature structure into the database.
CDO 2.0 could live with that and was never interested in that never persisted object. In contrast
CDO CVS Head now is interested in those objects when setting up the database and throws the below
exception.
In my opinion we should make CDO Head behave as CDO 2.0. Only do mappings when needed.
Kai
Kai Schlamp wrote:
> Forgot the trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> exactly the cause is. At least the feature structure should be also
>> named.
>> Regards,
>> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431735 is a reply to message #431734] Thu, 23 July 2009 08:35 Go to previous messageGo to next message
Shouldn't the field be transient?
Tom
> of those objects with this feature structure into the database.
> persisted object. In contrast CDO CVS Head now is interested in those
> objects when setting up the database and throws the below exception.
> Regards,
> Kai
> Kai Schlamp wrote:
>> Forgot the trace:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> named.
>>> Regards,
>>> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431736 is a reply to message #431731] Thu, 23 July 2009 08:36 Go to previous messageGo to next message
Here is a little patch for a more detailed error message. Please don't ask me to add a bugzilla for
that little line ;-)
### Eclipse Workspace Patch 1.0
#P org.eclipse.emf.cdo.server.db
Index: src/org/eclipse/emf/cdo/server/internal/db/mapping/TypeMappi ngFactory.java
RCS file:
/cvsroot/modeling/org.eclipse.emf/org.eclipse.emf.cdo/plugin s/org.eclipse.emf.cdo.server.db/src/org/eclipse/emf/cdo/serv er/internal/db/mapping/TypeMappingFactory.java,v
retrieving revision 1.2
diff -u -r1.2 TypeMappingFactory.java
--- src/org/eclipse/emf/cdo/server/internal/db/mapping/TypeMappi ngFactory.java 17 Jul 2009
09:05:02 -0000 1.2
+++ src/org/eclipse/emf/cdo/server/internal/db/mapping/TypeMappi ngFactory.java 23 Jul 2009 12:32:50
-0000
@@ -253,7 +253,8 @@
if (concreteFactory == null)
throw new IllegalArgumentException("No suitable mapping found from EMF type " +
cdoType.getName()
- + " to DB type " + dbType.getClass().getSimpleName());
+ + " to DB type " + dbType.getClass().getSimpleName() + " for feature " +
feature.getName() + " of "
+ + feature.getEContainingClass().getName());
return concreteFactory.doCreateTypeMapping(mappingStrategy, feature, dbType);
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431737 is a reply to message #431735] Thu, 23 July 2009 08:43 Go to previous messageGo to next message
Tom, you are correct. Transient indeed works (I already solved it that way). But in my opinion it's
more a conceptual question of how CDO works. Why does CDO bother with type mappings when nothing is
intended to be committed. But I am still not sure for myself ... is it intended or even a feature?!
As I said, it behave differently when using CDO 2.0 that's why it attracted my attention.
Kai
> Tom
>> Regards,
>> Kai
>> Kai Schlamp wrote:
>>> Forgot the trace:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> named.
>>>> Regards,
>>>> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431738 is a reply to message #431736] Thu, 23 July 2009 08:49 Go to previous messageGo to next message
There's no other possibility to bring in code into the Eclipse Repo
because all projects need to maintain an IP-Log.
Tom
>> named.
> ask me to add a bugzilla for that little line ;-)
> Index:
> RCS file:
> 17 Jul 2009 09:05:02 -0000 1.2
> 23 Jul 2009 12:32:50 -0000
> @@ -253,7 +253,8 @@
> from EMF type " + cdoType.getName()
> feature " + feature.getName() + " of "
> feature, dbType);
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431739 is a reply to message #431738] Thu, 23 July 2009 09:07 Go to previous messageGo to next message
Ah, yes ... the IP thing ;-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284412
> Tom
>>> named.
>> Index:
>> RCS file:
>> @@ -253,7 +253,8 @@
>> feature, dbType);
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431754 is a reply to message #431732] Thu, 23 July 2009 13:11 Go to previous messageGo to next message
Kai,
The exception message looks odd. Please file a bugzilla and prefix the
summary with "[DB] ...".
It should be: "No suitable mapping found from CDOType CUSTOM to
DBType.BLABLA" or just "No suitable mapping found from CDOType CUSTOM"...
Cheers
/Eike
> Forgot the trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> named.
>> Regards,
>> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431755 is a reply to message #431734] Thu, 23 July 2009 13:11 Go to previous messageGo to next message
> any of those objects with this feature structure into the database.
Can you file a bugzilla so that we can discuss that with Stefan?
Cheers
/Eike
> Regards,
> Kai
> Kai Schlamp wrote:
>> Forgot the trace:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> named.
>>> Regards,
>>> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431756 is a reply to message #431735] Thu, 23 July 2009 13:12 Go to previous messageGo to next message
Indeed, that's what I think, too.
Cheers
/Eike
> Tom
>> Regards,
>> Kai
>> Kai Schlamp wrote:
>>> Forgot the trace:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> named.
>>>> Regards,
>>>> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431757 is a reply to message #431737] Thu, 23 July 2009 13:17 Go to previous messageGo to next message
> way). But in my opinion it's more a conceptual question of how CDO
> works. Why does CDO bother with type mappings when nothing is intended
> or even a feature?!
I'd say it's intended. From a conceptual point of view it sounds odd to
allow things that are known to violate assumptions and hope that it will
not occur. Technically it's next to impossible to lazily create missing
mappings. SQL does not seem to define a standard way how to execute DDL.
Some vendors do it in the normal transaction, some do it outside, others
implicitely commit the ongoing transaction before and after DDL.
Maybe it's related with different handling of the mapping inside the
DBStore. Stefan, is there something that pops into your mind?
Cheers
/Eike
> Regards,
> Kai
>> Tom
>>> any
>>> Regards,
>>> Kai
>>> Kai Schlamp wrote:
>>>> Forgot the trace:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> named.
>>>>> Regards,
>>>>> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #431781 is a reply to message #431755] Sun, 26 July 2009 13:30 Go to previous messageGo to next message
But it's not only the type mapping, it's also the way the complete database is created by the DB
store. In CDO 2.0 a database table was created on demand (if something was commited). With CDO Head
all database tables are created the first time the database is accessed.
The problem is that I mostly mix my models with classes that should be persisted to database and
classes that are not intendet for persistence. Now with CDO Head many tables are created that are
never used.
May we should add an annotation option to suppress a table creation for a specific class.
What do you think?
Discussion here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=284680
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Regards,
>> Kai
>> Kai Schlamp wrote:
>>> Forgot the trace:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> named.
>>>> Regards,
>>>> Kai
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #435435 is a reply to message #431731] Thu, 30 July 2009 17:00 Go to previous messageGo to next message
I got the same error today and could track it down with your little patch
(I don't know if you're getting it for the same reason, but maybe it will
help):
I am using an xsd based model and the error occurs on the first String
typed feature in a class. The problem that occurs is the following:
CDOModelUtil.getType(EClassifier classifier) is used to determin the type
which looks like that:
public static CDOType getType(EClassifier classifier)
if (classifier instanceof EClass)
return CDOType.OBJECT;
if (classifier instanceof EEnum)
return CDOType.ENUM_ORDINAL;
if (isCorePackage(classifier.getEPackage()))
EDataType eDataType = (EDataType)classifier;
CDOType type = getCoreType(eDataType);
if (type != null)
return type;
return CDOType.CUSTOM;
The problem is that neither of the three condition is fulfilled because
String is a base type and no EClass BUT in the package
http://www.eclipse.org/emf/2003/XMLType. isCorePackage() returns only true
if it's http://www.eclipse.org/emf/2002/Ecore (and mappings are only
defined for those types).
Possible solution: Add type mappings for XMLType types
I'm not really sure, if I have interpreted that correctly, so I haven't
yet created a bugzilla entry. Please let me know what you think about it.
regards,
Chris
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #435643 is a reply to message #435435] Thu, 30 July 2009 17:22 Go to previous messageGo to next message
Update: I forgot to generate an xsd-ecore mapping file, when I did that,
the problem disappeared as the types are now mapped to core types.
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #436717 is a reply to message #435643] Thu, 30 July 2009 20:10 Go to previous messageGo to next message
Hi Christopher.
Good that you found your problem. I only run into that problem when using non EMF data types. Those
must be set to transient as CDO can't know how to store them.
Kai
>> because String is a base type and no EClass BUT in the package
>> true if it's http://www.eclipse.org/emf/2002/Ecore (and mappings are
>> only defined for those types).
>> haven't yet created a bugzilla entry. Please let me know what you
>> think about it.
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #439224 is a reply to message #436717] Fri, 31 July 2009 01:48 Go to previous messageGo to next message
Christopher, Kai,
That sounds like a regression in CDO. Unknown EDataTypes should be
represented by CDOType.CUSTOM. Can you file a bugzilla?
Cheers
/Eike
> Hi Christopher.
> using non EMF data types. Those must be set to transient as CDO can't
> Regards,
> Kai
>>> only true if it's http://www.eclipse.org/emf/2002/Ecore (and
>>> mappings are only defined for those types).
>>> think about it.
>> that, the problem disappeared as the types are now mapped to core types.
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #441010 is a reply to message #439224] Fri, 31 July 2009 05:22 Go to previous messageGo to next message
Eike Stepper wrote:
> Christopher, Kai,
I think that those are represented by CDOType.CUSTOM, but the DB Store simply doesn't know what to
do with that type (and throws an exception). Or do you mean something other?
> Cheers
> /Eike
>> Hi Christopher.
>> Regards,
>> Kai
>>>> think about it.
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #441011 is a reply to message #441010] Fri, 31 July 2009 05:34 Go to previous messageGo to next message
> Eike Stepper wrote:
>> Christopher, Kai,
> simply doesn't know what to do with that type (and throws an
Probably I just lost track in this long thread. If there is a problem
anywhere please file a bugzilla with a stack trace ;-)
Cheers
/Eike
>> Cheers
>> /Eike
>>> Hi Christopher.
>>> Regards,
>>> Kai
>>>>> think about it.
>>>> types.
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #441057 is a reply to message #441011] Fri, 31 July 2009 05:39 Go to previous messageGo to next message
Hi Eike,
I don't think there's a problem because one simply can't persist an
arbitrary JavaObject whether it is CDO, Teneo or the "simple" XMI
persistance.
IMHO CDO is completely right in throwing an Exception if someone to has
a none transient arbitrary JavaObject in his/her model.
Tom
>> Eike Stepper wrote:
>>> Christopher, Kai,
> Cheers
> /Eike
>>> Cheers
>>> /Eike
>>>> Hi Christopher.
>>>> Regards,
>>>> Kai
>>>>>> think about it.
>>>>> types.
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #441195 is a reply to message #441057] Fri, 31 July 2009 05:50 Go to previous messageGo to next message
> Hi Eike,
> persistance.
I'm not sure, though. This changed since we have the EPackage available
on the server. Now we have the EDataType on both client and server side
and we should use its String conversion methods. I know that the
CDOProtocol does that already via CDOType.CUSTOM. Maybe the DBStore did
not catch up with this change but continues to expect a String in the
CDORevision / delta. It that case we'd just need an additional
TypeMapping for CDOType.CUSTOM / String. Stefan?
Cheers
/Eike
> Tom
>>> Eike Stepper wrote:
>>>> Christopher, Kai,
>> Cheers
>> /Eike
>>>> Cheers
>>>> /Eike
>>>>> Hi Christopher.
>>>>> Regards,
>>>>> Kai
>>>>>>> think about it.
>>>>>> types.
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #441216 is a reply to message #441195] Fri, 31 July 2009 06:05 Go to previous messageGo to next message
Comments below...
>> Hi Eike,
>> persistance.
> I know that the
Yes and no. It is true that we have EDataType on the Server and it would
be no problem to create a TypeMapping which maps CUSTOM to String
calling the String conversion methods.
However, we don't have the *generated* or *user-defined* packages on the
server - we use reflective models there.
So, if a user creates a custom data type together with
createXYfromString)= and convertXYtoString() implementation, we still
don't have those on the server.
Even if the custom object would implement Serializable we still would
not be able to handle it on the server, because the custom class might
not be known on the server and, thus, can't be deserialized there.
So, if I have
public class Duck implements Serializable {
String name;
int gender;
and have a corresponding EDataType with instance class name = Duck, we
can't deserialize Duck on the server unless we put Duck into the server
class path.
I think, if we want to support CUSTOM-To-String mappings we need to do
the conversion where it can be done: on the client.
However, this might also be problematic, if different clients have
different mapping methods (e.g. due to versioning conflicts ...).
Stefan
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #441244 is a reply to message #441216] Fri, 31 July 2009 06:08 Go to previous messageGo to next message
>> I know that the
If they are deployed on the server they're now available. The new
CDOPackageRegistry is smart enough to handle this ;-)
Cheers
/Eike
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #442268 is a reply to message #441244] Fri, 31 July 2009 08:41 Go to previous messageGo to next message
CB (*C*omments *B*elow -- we should make this abbreviation
newsgroup-standard ;-))
>>> I know that the
Hmm... ok in the one case the server has to be start-time configured and
in the other case it can run out of the box and custom types are
converted on the client.
I think both scenarios have their rationale.
E.g., in a bigger setting, where the server is shared among different
applications, the latter case would be more operations-friendly...
Stefan
Re: [CDO] No suitable mapping found from EMF type CUSTOM to DB type DBType [message #451768 is a reply to message #442268] Sat, 01 August 2009 07:32 Go to previous message
Maybe we can do both:
if (packageUnit.getType == NATIVE)
revision.setValue(EDataType.createFromString(value));
else
revision.setValue(value);
The DBStore would have to do the opposite:
writeAttribute(EDataType.convertToString(revision.getValue() ));
else
writeAttribute(revision.getValue());
Cheers
/Eike
Previous Topic:custom drawn property sheet cells
Next Topic:Re: Duplicate case error in generated model
Current Time: Sat Jul 26 20:06:31 EDT 2025
Powered by FUDForum. Page generated in 0.07369 seconds
