Possible to reference a xml simple type`? [message #431665] |
Tue, 21 July 2009 06:46  |
Originally posted by: formatzeh.gmx.de
I'm just wondering if it is possible to import anyhow the xml simple
types. I mean I don't want to create them in my metamodel but rather
want to use them in my generated editor as references. In the ecore
diagram editor I tried to load resources... but I only can load ecore
models in the workspace or filesystem and not in the registry. Is it
possible anyhow?
Re: Possible to reference a xml simple type`? [message #431705 is a reply to message #431701] |
Wed, 22 July 2009 07:24   |
--------------020309040302040608060207
Gilbert,
How exactly do those lines cause a problem? The XMLTypePackage does
exist. When you created your GenModel, did you choose the existing
GenModel for XMLTypePackage in the final wizard or create a new
GenPackage for it?
Gilbert Mirenque wrote:
> Ed Merks wrote:
>> XMLTypePackage has EDataTypes for the XML Schema built-in simple types...
> found it
>> Perhaps if you use the Sample Ecore Editor to load it and make your
>> first reference to it, after that the diagram editor will let you work
>> with it...
> Ok so it works. If you add a reference in the sample editor first you
> can work with the imported package in the ecore diagram editor as well.
> But now I have another problem. In my genmodel the imported package
> appears as well - understandable. The generation of the editor worked
> fine except an error in one test class. For now I commented the line out
> where a not existent method is to be invoked. But in the new eclipse
> instance, where I want to work with my editor, I get the following error
> when starting the creation wizard:
> Plug-in "myplugin.editor" was unable to instantiate class
> "myplugin.presentation.ModelWizard".
> Could not initialize class myplugin.MyModelPackage
> that's caused by the following line in the init method of my package impl:
> TypePackageImpl theTypePackage =
> (TypePackageImpl)(EPackage.Registry.INSTANCE.getEPackage(Typ ePackage.eNS_URI)
> instanceof TypePackageImpl ?
> EPackage.Registry.INSTANCE.getEPackage(TypePackage.eNS_URI) :
> TypePackage.eINSTANCE);
> and by the following line in my imported TypePackageImpl:
> XMLTypePackage theXMLTypePackage =
> (XMLTypePackage)EPackage.Registry.INSTANCE.getEPackage(XMLTy pePackage.eNS_URI);
> What can I do to avoid this?
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Gilbert,<br>
<br>
GenPackage for it? <br>
<br>
<br>
<blockquote cite="mid:h46pa9$fpk$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">XMLTypePackage has EDataTypes for the XML Schema built-in simple types...
</pre>
</blockquote>
<pre wrap=""><!---->found it
</pre>
<pre wrap="">Perhaps if you use the Sample Ecore Editor to load it and make your
with it...
</pre>
</blockquote>
<pre wrap=""><!---->Ok so it works. If you add a reference in the sample editor first you
</pre>
</blockquote>
</body>
</html>
--------------020309040302040608060207--
Re: Possible to reference a xml simple type`? [message #431897 is a reply to message #431895] |
Tue, 28 July 2009 19:04  |
--------------010309040502030107050409
Gilbert,
Reload... uses the same wizard.
> Ed Merks wrote:
>> The last page of the wizard should allow you to locate GenModels for any
>> packages being loaded.
> This is right - but the wizard can only be used when I want to create a
> new genmodel. My genmodel exists already so I can't use it :/
<html>
<head>
</head>
Gilbert,<br>
<br>
Reload... uses the same wizard.<br>
<br>
<blockquote cite="mid:h4nibi$4qd$1@build.eclipse.org" type="cite">
</pre>
<pre wrap="">The last page of the wizard should allow you to locate GenModels for any
</pre>
</blockquote>
<pre wrap=""><!---->This is right - but the wizard can only be used when I want to create a
</pre>
</blockquote>
</body>
</html>
--------------010309040502030107050409--
FUDForum. Page generated in 0.06407 seconds
