Home » Modeling » EMF » Possible to reference a xml simple type`?
Possible to reference a xml simple type`? [message #431665] Tue, 21 July 2009 06:46 Go to next message
Originally posted by: formatzeh.gmx.de
I'm just wondering if it is possible to import anyhow the xml simple
types. I mean I don't want to create them in my metamodel but rather
want to use them in my generated editor as references. In the ecore
diagram editor I tried to load resources... but I only can load ecore
models in the workspace or filesystem and not in the registry. Is it
possible anyhow?
Re: Possible to reference a xml simple type`? [message #431678 is a reply to message #431665] Tue, 21 July 2009 10:12 Go to previous messageGo to next message
Gilbert,
Comments below.
> types.
XMLTypePackage has EDataTypes for the XML Schema built-in simple types...
Perhaps if you use the Sample Ecore Editor to load it and make your
first reference to it, after that the diagram editor will let you work
with it...
> Is it
> possible anyhow?
Re: Possible to reference a xml simple type`? [message #431701 is a reply to message #431678] Wed, 22 July 2009 06:23 Go to previous messageGo to next message
found it
> with it...
Ok so it works. If you add a reference in the sample editor first you
can work with the imported package in the ecore diagram editor as well.
But now I have another problem. In my genmodel the imported package
appears as well - understandable. The generation of the editor worked
fine except an error in one test class. For now I commented the line out
where a not existent method is to be invoked. But in the new eclipse
instance, where I want to work with my editor, I get the following error
when starting the creation wizard:
Plug-in "myplugin.editor" was unable to instantiate class
"myplugin.presentation.ModelWizard".
Could not initialize class myplugin.MyModelPackage
that's caused by the following line in the init method of my package impl:
TypePackageImpl theTypePackage =
(TypePackageImpl)(EPackage.Registry.INSTANCE.getEPackage(Typ ePackage.eNS_URI)
instanceof TypePackageImpl ?
EPackage.Registry.INSTANCE.getEPackage(TypePackage.eNS_URI) :
TypePackage.eINSTANCE);
and by the following line in my imported TypePackageImpl:
XMLTypePackage theXMLTypePackage =
(XMLTypePackage)EPackage.Registry.INSTANCE.getEPackage(XMLTy pePackage.eNS_URI);
What can I do to avoid this?
Re: Possible to reference a xml simple type`? [message #431705 is a reply to message #431701] Wed, 22 July 2009 07:24 Go to previous messageGo to next message
--------------020309040302040608060207
Gilbert,
How exactly do those lines cause a problem? The XMLTypePackage does
exist. When you created your GenModel, did you choose the existing
GenModel for XMLTypePackage in the final wizard or create a new
GenPackage for it?
> found it
>> with it...
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Gilbert,<br>
<br>
GenPackage for it?  <br>
<br>
<br>
<blockquote cite="mid:h46pa9$fpk$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">XMLTypePackage has EDataTypes for the XML Schema built-in simple types...
</pre>
</blockquote>
<pre wrap=""><!---->found it
</pre>
<pre wrap="">Perhaps if you use the Sample Ecore Editor to load it and make your
with it...
</pre>
</blockquote>
<pre wrap=""><!---->Ok so it works. If you add a reference in the sample editor first you
</pre>
</blockquote>
</body>
</html>
--------------020309040302040608060207--
Re: Possible to reference a xml simple type`? [message #431713 is a reply to message #431705] Wed, 22 July 2009 10:58 Go to previous messageGo to next message
Ed Merks wrote:
> Gilbert,
> GenPackage for it?
In my genmodel appeared a new package for the XMLTypePackage
automatically when adding references to it in my metamodel. How can I
specify to choose an existing genmodel and where do I find it?
Re: Possible to reference a xml simple type`? [message #431743 is a reply to message #431713] Thu, 23 July 2009 11:20 Go to previous messageGo to next message
--------------020004050408070001010402
Gilbert,
The bottom 1/2 of the wizard should support that. Have a look at how a
model generated from an XSD looks and try to make it look like that...
> Ed Merks wrote:
>> Gilbert,
>> GenPackage for it?
<html>
<head>
</head>
Gilbert,<br>
<br>
model generated from an XSD looks and try to make it look like that...<br>
<br>
<br>
<blockquote cite="mid:h479f4$fnr$1@build.eclipse.org" type="cite">
</pre>
<pre wrap="">Gilbert,
GenPackage for it?
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------020004050408070001010402--
Re: Possible to reference a xml simple type`? [message #431778 is a reply to message #431743] Sat, 25 July 2009 08:47 Go to previous messageGo to next message
Ed Merks wrote:
> Gilbert,
Ok, it works in that way if you delete the genmodel and generate it
again. But you can't reference the other genmodel if your own genmodel
already exists - or I didn't find it.
But I think my explanation from my first post was a little bit
underinformed (nice word ;) ). I try to explain in other words what I
want to do:
I start from behind. With the generated editor I want to create a model
for my domain. In this domain I need datatypes as well. My idea was that
it would be nice if one can reference existing XML simple datatypes such
as xs:string for example. Or one has the option to create special types
and reference those. That's why I thought that I can create a class
(AbstractDatatype) in my metamodel inheriting from a root class of the
XMLTypes package. I thought there is a class from which all simple xml
types inherit, which I can use as parent class for my AbstractDatatype.
Furthermore my idea was that now I simply can reference the parent class
of all simple XML types in my metamodel. I thought that by that I can
then reference all XML simple types or an own special type (inheriting
from the parent XML simple type). That means I don't want to use the
metaelements from the XMLTypes package and the concrete types in my
generated editor or alternatively some special types. Is it
udnerstandable? And the more important question: is it possible?
best regards,
Gilbert
Re: Possible to reference a xml simple type`? [message #431779 is a reply to message #431778] Sat, 25 July 2009 09:00 Go to previous messageGo to next message
I have another idea. Maybe the following scenario is possible:
in the second Eclipse instance where the generated editor is available:
- create a new XML schema
- create an instance of my metamodel with the generated editor
- in that instance load the created xml schema as resource
- in that instance reference a type contained in the xml schema
Is that possible or is it to freaky?
Re: Possible to reference a xml simple type`? [message #431780 is a reply to message #431779] Sat, 25 July 2009 10:51 Go to previous messageGo to next message
Gilbert,
This article describes some of the steps that occur when converting an
XML Schema to an Ecore model. While the XML Schema simple types indeed
form a hierarchy, it's not possible to reflect that in Java's type
system because the existing Java types don't form the same hierarchy.
Re: Possible to reference a xml simple type`? [message #431879 is a reply to message #431743] Tue, 28 July 2009 11:44 Go to previous messageGo to next message
I'm interested in how to reference an existing genmodel in my own
existing genmodel? If I load a resource in the ecore file I can add
references to the loaded model. But by that my genmodel won't contain a
reference to the genmodel from which the model was loaded. I have real
packages. How do I do this when my genmodel already exists? How do I
reference a genmodel from the emf registry?
Re: Possible to reference a xml simple type`? [message #431886 is a reply to message #431879] Tue, 28 July 2009 12:08 Go to previous messageGo to next message
Gilbert,
The last page of the wizard should allow you to locate GenModels for any
packages being loaded. For packages that are registered, they should be
suggested automatically. For ones in the workspace, you need to use the
Browse... button to locate them...
Re: Possible to reference a xml simple type`? [message #431895 is a reply to message #431886] Tue, 28 July 2009 15:08 Go to previous messageGo to next message
This is right - but the wizard can only be used when I want to create a
new genmodel. My genmodel exists already so I can't use it :/
Re: Possible to reference a xml simple type`? [message #431897 is a reply to message #431895] Tue, 28 July 2009 19:04 Go to previous message
--------------010309040502030107050409
Gilbert,
Reload... uses the same wizard.
<html>
<head>
</head>
Gilbert,<br>
<br>
Reload... uses the same wizard.<br>
<br>
<blockquote cite="mid:h4nibi$4qd$1@build.eclipse.org" type="cite">
</pre>
<pre wrap="">The last page of the wizard should allow you to locate GenModels for any
</pre>
</blockquote>
<pre wrap=""><!---->This is right - but the wizard can only be used when I want to create a
</pre>
</blockquote>
</body>
</html>
--------------010309040502030107050409--
Previous Topic:resource utility example unable to find hibernate
Next Topic:Generating EMF EPackages for all xsd URIs
Current Time: Sun Jul 27 01:59:39 EDT 2025
Powered by FUDForum. Page generated in 0.28070 seconds
