[TENEO] mapping problem [message #431669] |
Tue, 21 July 2009 08:19  |
Originally posted by: krdbrm.gmail.com
Hallo,
i have following problem if i mapp my ecore model,
org.hibernate.MappingException: Could not determine type for: org.eclipse.emf.teneo.hibernate.mapping.ENumUserType, at table: ecore_eobject, for columns: [org.hibernate.mapping.Column(measurementunit)]
at org.hibernate.mapping.SimpleValue.getType(SimpleValue.java:2 92)
at org.hibernate.mapping.SimpleValue.isValid(SimpleValue.java:2 76)
at org.hibernate.mapping.Property.isValid(Property.java:207)
at org.hibernate.mapping.PersistentClass.validate(PersistentCla ss.java:458)
at org.hibernate.mapping.SingleTableSubclass.validate(SingleTab leSubclass.java:66)
at org.hibernate.cfg.Configuration.validate(Configuration.java: 1135)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1320)
at org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:171)
at org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:83)
at org.efixes.dataaccess.db.EfStoreController.initializeDataSto re(EfStoreController.java:159)
i use
EMf 2.4
teneo 1.0.4
Eclipse 3.4
anybody has an idea?
thank you very much.
Bahram
Re: [TENEO] mapping problem [message #431674 is a reply to message #431671] |
Tue, 21 July 2009 09:13   |
Hi Bahram,
The eclipse buddy policy dependent should be in the hibernate plugin (in your case I think it is the
org.efixes.hibernate.distribution plugin).
gr. Martin
Bahram Kord wrote:
> hi martin,
> yes following entries are in my MANIFEST.MF.
> org.eclipse.emf.teneo.hibernate;bundle-version="1.0.1";visibility:=reexport,
> org.efixes.hibernate.distribution;bundle-version="1.0.0";visibility:=reexport,
> Eclipse-BuddyPolicy: dependent
> br
> Bahram
> Martin Taal schrieb:
>> Hi Bahram,
>> This is often a classloading issue. Hibernate does not have access to
>> the org.eclipse.emf.teneo.hibernate.mapping.ENumUserType class.
>> Did you set the eclipse buddy policy to dependent?
>> gr. Martin
>> Bahram Kord wrote:
>>> Hallo,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> i use
>>> EMf 2.4
>>> teneo 1.0.4
>>> Eclipse 3.4
>>> Bahram
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] mapping problem [message #431675 is a reply to message #431674] |
Tue, 21 July 2009 09:34  |
thank you very much it works for me.
br
Bahram
> Hi Bahram,
> your case I think it is the org.efixes.hibernate.distribution plugin).
> gr. Martin
> Bahram Kord wrote:
>> hi martin,
>> br
>> Bahram
>>> Hi Bahram,
>>> gr. Martin
>>> Bahram Kord wrote:
>>>> Hallo,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> i use
>>>> EMf 2.4
>>>> teneo 1.0.4
>>>> Eclipse 3.4
>>>> Bahram
FUDForum. Page generated in 1.47426 seconds
