Home » Modeling » EMF » When to use "is abstract" and when "is interface"
When to use "is abstract" and when "is interface" [message #431647] Mon, 20 July 2009 11:53 Go to next message
Originally posted by: formatzeh.gmx.de
A simple question. When modeling an ecore model I have several classes
from which other classes inherit. Now I'm asking myself when to use
which option. Maybe it is better to use both? As I'm a beginner with EMF
I don't know what makes the difference, for example in the generated
editor. I mean for every class an interface will be generated. So what
makes the difference?
best regards
Gilbert
Re: When to use "is abstract" and when "is interface" [message #431648 is a reply to message #431647] Mon, 20 July 2009 12:31 Go to previous messageGo to next message
I could answer one question: a class marked as interface must also be
marked as abstract.
Re: When to use "is abstract" and when "is interface" [message #431651 is a reply to message #431647] Mon, 20 July 2009 14:51 Go to previous messageGo to next message
Gilbert,
No AbcImpl is generated for something that's marked as an interface,
which implies you can't create instance, hence it must be abstract as
well, and it implies that if you extend it, you have to implement the
interface completely rather than extend a class with a shared/existing
implementation.
> best regards
> Gilbert
Re: When to use "is abstract" and when "is interface" [message #431655 is a reply to message #431651] Mon, 20 July 2009 16:33 Go to previous messageGo to next message
Thanks Ed.
Re: When to use "is abstract" and when "is interface" [message #431672 is a reply to message #431651] Tue, 21 July 2009 08:55 Go to previous messageGo to next message
> implementation.
that also means that it is efficient to define those classes, not
containing any attributes, as interfaces and those, containing
attributes, only as abstract? The reason is that the
attributeGetters/-Setters only are defined in the abstract class and not
in every interface-implementing subclass?
Re: When to use "is abstract" and when "is interface" [message #431673 is a reply to message #431672] Tue, 21 July 2009 09:01 Go to previous message
Well inheritance is not really fast in java so having a too deep class
hierarchy is not always the best and further not really easy to understand.
Tom
>> implementation.
Previous Topic:Storing xml commets in emf object
Next Topic:[TENEO] mapping problem
Current Time: Sun Jul 27 06:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.04183 seconds
