Home » Modeling » EMF » [CDO] Thread race condition with two transactions.
[CDO] Thread race condition with two transactions. [message #431618] Sat, 18 July 2009 20:03 Go to next message
Hello.
I have the following problem.
I have two threads with each having a CDO transaction of the same session accessing the same
resource. In thread B I imported an object of thread A by using transaction.getObject(). In thread B
I manipulate the object, commit and fire a separate event (with that object attached). That event is
consumed by thread A again which imports the event attached object by it's transaction.getObject().
The problem is now that sometimes the modifications of thread B are visible in thread A, and
sometimes not.
Is there a way to make sure that all updates from the other thread have arrived?
Kai
Re: [CDO] Thread race condition with two transactions. [message #431619 is a reply to message #431618] Sat, 18 July 2009 20:35 Go to previous messageGo to next message
Something I should have mentioned. In thread A I use object.cdoReload when that event occurs. I
assumed that by object.cdoReload the repository is checked if there are any updates (and thread B
already committed at that time). But the committed changes are still not there after cdoReload.
So it seems that cdoReload does not do what I expect from it.
Kai Schlamp wrote:
> Hello.
> session accessing the same resource. In thread B I imported an object of
> thread A by using transaction.getObject(). In thread B I manipulate the
> That event is consumed by thread A again which imports the event
> visible in thread A, and sometimes not.
> arrived?
> Regards,
> Kai
Re: [CDO] Thread race condition with two transactions. [message #431620 is a reply to message #431619] Sat, 18 July 2009 21:45 Go to previous messageGo to next message
Forget all those thread things, here is a little test case that demonstrates my problem.
I would have expected that the cdoReload method call would sync the objects between both
transactions, but it doesn't :-(
package org.eclipse.emf.cdo.tests.db;
import org.eclipse.emf.cdo.CDOObject;
import org.eclipse.emf.cdo.eresource.CDOResource;
import org.eclipse.emf.cdo.session.CDOSession;
import org.eclipse.emf.cdo.tests.AbstractCDOTest;
import org.eclipse.emf.cdo.tests.model1.Model1Factory;
import org.eclipse.emf.cdo.tests.model1.Product1;
import org.eclipse.emf.cdo.transaction.CDOTransaction;
import java.util.ArrayList;
import java.util.List;
public class RaceConditionTest extends AbstractCDOTest
public void testLengthAnnotationPositive() throws Exception
disableConsole();
msg("Opening session");
CDOSession session = openModel1Session();
msg("Opening transaction");
CDOTransaction transaction1 = session.openTransaction();
msg("Creating resource");
CDOResource resource = transaction1.createResource("/test1");
List<Product1> products = new ArrayList<Product1>();
for (int i = 0; i < 1000; i++)
Product1 product = Model1Factory.eINSTANCE.createProduct1();
product.setName("unmodified");
products.add(product);
resource.getContents().add(product);
transaction1.commit();
CDOTransaction transaction2 = session.openTransaction();
for (Product1 product : products)
Product1 importedProduct = transaction2.getObject(product);
importedProduct.setName("modified");
transaction2.commit();
Product1 reimportedProduct = transaction1.getObject(importedProduct);
((CDOObject)reimportedProduct).cdoReload();
assertEquals("modified", reimportedProduct.getName());
Re: [CDO] Thread race condition with two transactions. [message #431621 is a reply to message #431619] Sun, 19 July 2009 03:17 Go to previous messageGo to next message
Kai,
I fear we must apologize because the reload() methods, i.e.
CDOObject.cdoReload() and CDOView.reload() are meant to be removed:
274111: Remove CDOView.reload
https://bugs.eclipse.org/bugs/show_bug.cgi?id=274111
It seems to be a historical relict and we even could not find out why it
was provided initially (crippeled CVS history after move) ;-(
As an alternative solution in your scenario we could consider adding a
utility method that blocks until a given commit operation of transaction
A is visible in transaction B:
transactionA.commit();
long commitTime = transactionA.getLastCommitTime();
viewB.waitForCommit(commitTime);
Would that help? Please file file an enhancement request ;-)
Cheers
/Eike
> when that event occurs. I assumed that by object.cdoReload the
> repository is checked if there are any updates (and thread B already
> after cdoReload.
> Kai Schlamp wrote:
>> Hello.
>> of thread A by using transaction.getObject(). In thread B I
>> object attached). That event is consumed by thread A again which
>> have arrived?
>> Regards,
>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431624 is a reply to message #431621] Sun, 19 July 2009 07:28 Go to previous messageGo to next message
In the meantime I am listening to changes with the help of CDOViewInvalidationEvent and
CDOTransactionHandler, but I still think that this would be a good enhancement.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283947
Another question. Is enabling CDOViewInvalidationEvent a big overhead? (I guess that's why it is no
enabled by default).
Eike Stepper wrote:
> Kai,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> after cdoReload.
>> Kai Schlamp wrote:
>>> Hello.
>>> have arrived?
>>> Regards,
>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431625 is a reply to message #431624] Sun, 19 July 2009 07:40 Go to previous messageGo to next message
> CDOViewInvalidationEvent and CDOTransactionHandler, but I still think
Thx.
> (I guess that's why it is no enabled by default).
It's not too big, although it can involve some extra threads and EMF
adapter notification.
It's not the default because CDOSessionInvalidationEvent often is a
better alternative, like in this case.
Cheers
/Eike
> Eike Stepper wrote:
>> Kai,
>> Cheers
>> /Eike
>>> after cdoReload.
>>> Kai Schlamp wrote:
>>>> Hello.
>>>> have arrived?
>>>> Regards,
>>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431628 is a reply to message #431625] Sun, 19 July 2009 08:03 Go to previous messageGo to next message
I just tried it with CDOSessionInvalidationEvent instead, and guess what ... the same problem of not
visible updates in transaction A.
If I listen to CDOSessionInvalidationEvent in thread A, it is not guaranteed that the updates of
transaction B in thread B have already arrived.
With CDOViewInvalidationEvent that works (at least I have not had a problem so far).
Is that really the way it should be?
Re: [CDO] Thread race condition with two transactions. [message #431630 is a reply to message #431628] Sun, 19 July 2009 08:31 Go to previous messageGo to next message
Here is a test snippet that demonstrates the problem with CDOSessionInvalidationEvent. You have to
look at the output. Sometimes it is "modified" and sometimes "unmodified". Strangely the assertion
gets always true, I don't know why!?
import org.eclipse.emf.cdo.common.id.CDOIDAndVersion;
import org.eclipse.emf.cdo.session.CDOSessionInvalidationEvent;
import org.eclipse.net4j.util.event.IEvent;
import org.eclipse.net4j.util.event.IListener;
disableConsole();
final CDOTransaction transaction1 = session.openTransaction();
session.addListener(new IListener()
public void notifyEvent(IEvent event)
if (event instanceof CDOSessionInvalidationEvent)
CDOSessionInvalidationEvent invalidationEvent = (CDOSessionInvalidationEvent)event;
for (CDOIDAndVersion cdoIdAndVersion : invalidationEvent.getDirtyOIDs())
CDOObject obj = transaction1.getObject(cdoIdAndVersion.getID());
if (obj instanceof Product1)
Product1 product = (Product1)obj;
String name = product.getName();
System.out.println(name);
// assertEquals("modified", name); // strange ... why does it not fail?? look at the
output!?
SecondThread second = new SecondThread(session, products);
Thread thread = new Thread(second);
thread.start();
thread.join();
public class SecondThread implements Runnable
private CDOTransaction transaction2;
private List<Product1> products;
public SecondThread(CDOSession session, List<Product1> products)
this.products = new ArrayList<Product1>();
this.products.add(transaction2.getObject(product));
public void run()
product.setName("modified");
Re: [CDO] Thread race condition with two transactions. [message #431631 is a reply to message #431630] Sun, 19 July 2009 08:57 Go to previous messageGo to next message
Here also a version where the assertion fails (had to do with the threading):
private static boolean allModified = true;
disableConsole();
System.out.println("- " + name);
if (name.equals("unmodified"))
allModified = false;
thread.start();
thread.join();
assertTrue(allModified);
public void run()
Re: [CDO] Thread race condition with two transactions. [message #431632 is a reply to message #431628] Sun, 19 July 2009 09:43 Go to previous messageGo to next message
> what ... the same problem of not visible updates in transaction A.
> guaranteed that the updates of transaction B in thread B have already
> arrived.
> problem so far).
Sorry, my fault ;-(
Yes, it's meant to be like that: CDOSessionInvalidationEvent indicates
avaiability of new revisions. The same internal code that fires these
events also calls the internal view methods that emit the EMF
notifications and finally fire the CDOViewInvalidationEvent. But the
last two happen asynchronously.
Cheers
/Eike
Re: [CDO] Thread race condition with two transactions. [message #431633 is a reply to message #431625] Sun, 19 July 2009 10:16 Go to previous messageGo to next message
Small comments:
CDOViewInvalidationEvent will always be trigger as soon as you have
objects in your view that are invalidate. You do not control that.
This is different than from the
view.options().isInvalidationNotificationEnabled().
isInvalidationNotificationEnabled will enabled EMF notifications.
Simon
> Thx.
> Cheers
> /Eike
>> Eike Stepper wrote:
>>> Kai,
>>> Cheers
>>> /Eike
>>>> after cdoReload.
>>>> Kai Schlamp wrote:
>>>>> Hello.
>>>>> have arrived?
>>>>> Regards,
>>>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431634 is a reply to message #431632] Sun, 19 July 2009 10:19 Go to previous messageGo to next message
>> arrived.
>> problem so far).
> Sorry, my fault ;-(
Just for clarification ... when I use CDOViewInvalidationEvent in my example I can always assume
that the object in transaction A of thread A is completely updated (with the modifications from
transaction B), and so CDOViewInvalidationEvent is the way to go for me.
Right?
Thanks in advance,
Kai
Re: [CDO] Thread race condition with two transactions. [message #431635 is a reply to message #431634] Sun, 19 July 2009 10:27 Go to previous messageGo to next message
Kai,
Yes, I'll also use CDOViewInvalidationEvent for the new convenience methods.
Cheers
/Eike
>>> arrived.
>>> problem so far).
>> Sorry, my fault ;-(
> example I can always assume that the object in transaction A of thread
> A is completely updated (with the modifications from transaction B),
> Right?
> Thanks in advance,
> Kai
Re: [CDO] Thread race condition with two transactions. [message #431636 is a reply to message #431633] Sun, 19 July 2009 10:28 Go to previous messageGo to next message
Oh thanks for the hint, Simon. I also must update the FAQ then, as I just added the
CDOViewInvalidationEvent there.
By the way, may I ask you, if you could take a short look in bug 279982
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=279982) some time in the next days.
It would mean much to me and my project.
Simon McDuff wrote:
> Small comments:
> Simon
>> Thx.
>> Cheers
>> /Eike
>>> Eike Stepper wrote:
>>>> Kai,
>>>> why it
>>>> transaction
>>>> Cheers
>>>> /Eike
>>>>> after cdoReload.
>>>>> Kai Schlamp wrote:
>>>>>> Hello.
>>>>>> have arrived?
>>>>>> Regards,
>>>>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431637 is a reply to message #431636] Sun, 19 July 2009 10:35 Go to previous messageGo to next message
The following is working
disableConsole();
final CDOTransaction transaction2 = session.openTransaction();
final ConcurrentValue<Boolean> changed = new
ConcurrentValue<Boolean>(Boolean.FALSE);
transaction1.addListener(new IListener()
if (event instanceof CDOViewInvalidationEvent)
changed.set(Boolean.TRUE);
changed.acquire(Boolean.TRUE);
changed.set(Boolean.FALSE);
> just added the CDOViewInvalidationEvent there.
> next days.
> Simon McDuff wrote:
>> Small comments:
>> Simon
>>> Thx.
>>> Cheers
>>> /Eike
>>>> Eike Stepper wrote:
>>>>> Kai,
>>>>> why it
>>>>> transaction
>>>>> Cheers
>>>>> /Eike
>>>>>> there
>>>>>> after cdoReload.
>>>>>> Kai Schlamp wrote:
>>>>>>> Hello.
>>>>>>> object
>>>>>>> have arrived?
>>>>>>> Regards,
>>>>>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431638 is a reply to message #431637] Sun, 19 July 2009 10:37 Go to previous message
The only things that is missing is the following:
CDOViewInvalidationEvent.getView() (TO know from which source is come from).
Simon
> disableConsole();
>> 279982 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=279982) some
>> Simon McDuff wrote:
>>> Small comments:
>>> Simon
>>>> Thx.
>>>> Cheers
>>>> /Eike
>>>>> Eike Stepper wrote:
>>>>>> Kai,
>>>>>> why it
>>>>>> adding a
>>>>>> transaction
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> object.cdoReload
>>>>>>> there
>>>>>>> after cdoReload.
>>>>>>> Kai Schlamp wrote:
>>>>>>>> Hello.
>>>>>>>> object
>>>>>>>> have arrived?
>>>>>>>> Regards,
>>>>>>>> Kai
Previous Topic:first create classes then move them into package
Next Topic:[CDO] CDOID changes when CDOObject is moved - bug or not?
Current Time: Fri Jul 18 20:47:49 EDT 2025
Powered by FUDForum. Page generated in 0.06426 seconds
