first create classes then move them into package [message #431622] |
Sun, 19 July 2009 05:10  |
Originally posted by: formatzeh.gmx.de
I'm speaking about the Ecore Diagram Editor. I created some ecore
classes and put them into relation. Now I decided that it would be
better to add some packages just because of SoC. Well it's not so easy
as I thought. I added the package in the diagram but I couldn't find a
way to move some classes into it. My first try was to select the package
-> format -> order -> send to back. But the result was only visual.
Another try was to drag&drop the classes into the package but the result
was that in the package only references of the classes appeared and the
classes stayed in its old place. How is it possible?
What else is interesting for me is what is the purpose of packages in an
ecore model? I mean there is the SoC purpose. But what else? My aim is
to generate an editor. Is it possible to generate several editors? For
every package its own? And they must work on the same model i.e. on the
same file. It would be nice because than every gmf editor can have its
own graphical notations.
regards
Gilbert
Re: first create classes then move them into package [message #431623 is a reply to message #431622] |
Sun, 19 July 2009 05:42   |
--------------050406020805070104060507
Content-Type: text/plain; charset=UTF-8
Gilbert,
Comments below...
That makes me think that the EMFT newsgroup is more likely to give good
support on EcoreTools.
Technically it's possible to add subpackages to an EPackage but the cool
guys don't do it. Often it's better to factor out separate modules, i.e.
own model plugins.
This looks like an EcoreTools question and should be asked in the EMFT
newsgroup.
A pity that a (package) tree is not particularly well-suited for the
separation of multiple concern dimensions.
IIRC. editors are generated for models and not for single packages
therein. But I always recommend against generating model-specific
editors at all! IMHO model-specifics should be isolated in the generated
model plugin or in the generated edit plugin. Editors should be
UI-specific, if that's needed at all. If you compare any two generated
editors you'll notice that they really only differ in the registration
of package-specific ItemProviderAdapterFactories in the
initializeEditingDomain() method. With the following replacement of that
code you get a truely generic editor:
| ComposedAdapterFactory.Descriptor.Registry registry = EMFEditPlugin.getComposedAdapterFactoryDescriptorRegistry();
adapterFactory = *new *ComposedAdapterFactory(registry);
adapterFactory.addAdapterFactory(*new *ResourceItemProviderAdapterFactory());
adapterFactory.addAdapterFactory(*new *ReflectiveItemProviderAdapterFactory());|
Generally EMF Transaction or the CDO Model Repository offer
transactionality and multi user characteristics, although they do it
quite differently. It could make sense to ask the GMF newsgroup for more
infos on how they do it.
Cheers
/Eike
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Gilbert,<br>
<br>
Comments below...<br>
<br>
<br>
<blockquote cite="mid:h3unuu$4vo$1@build.eclipse.org" type="cite">
<pre wrap="">I'm speaking about the Ecore Diagram Editor. </pre>
</blockquote>
support on EcoreTools.<br>
<br>
<pre wrap="">I created some ecore
better to add some packages just because of SoC. </pre>
</blockquote>
cool guys don't do it. Often it's better to factor out separate
modules, i.e. own model plugins.<br>
<br>
<pre wrap="">Well it's not so easy
</pre>
</blockquote>
newsgroup.<br>
<br>
<pre wrap="">What else is interesting for me is what is the purpose of packages in an
ecore model? I mean there is the SoC purpose. </pre>
</blockquote>
separation of multiple concern dimensions. <br>
<br>
<pre wrap="">But what else? My aim is
every package its own? </pre>
</blockquote>
generated model plugin or in the generated edit plugin. Editors should
be UI-specific, if that's needed at all. If you compare any two
generated editors you'll notice that they really only differ in the
registration of package-specific ItemProviderAdapterFactories in the
that code you get a truely generic editor:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff"> </font><font
color="#000000"> ComposedAdapterFactory.Descriptor.Registry registry = EMF EditPlugin.getComposedAdapterFactoryDescriptorRegistry </font><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#000000">adapterFactory = </font><font
color="#7f0055"><b>new </b></font><font color="#000000">ComposedAdapterFactory</font><font
color="#000000">(</font><font color="#000000">registry</font><font
color="#000000">)</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#000000">adapterFactory.addAdapterFactory</font><font
color="#000000">(</font><font color="#7f0055"><b>new </b></font><font
color="#000000">ResourceItemProviderAdapterFactory</font> <font
color="#000000">())</font><font color="#000000">;</font><br>
color="#000000">ReflectiveItemProviderAdapterFactory</font ><font
color="#000000">())</font><font color="#000000">;</font></code> </td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<!-- ======================================================== --><br>
<br>
<pre wrap="">And they must work on the same model i.e. on the
</pre>
</blockquote>
more infos on how they do it.<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
</body>
</html>
--------------050406020805070104060507--
FUDForum. Page generated in 0.25421 seconds
