Home » Modeling » EMF » [CDO] Thread race condition with two transactions.
[CDO] Thread race condition with two transactions. [message #431618] |
Sat, 18 July 2009 20:03  |
Hello.
I have the following problem.
I have two threads with each having a CDO transaction of the same session accessing the same
resource. In thread B I imported an object of thread A by using transaction.getObject(). In thread B
I manipulate the object, commit and fire a separate event (with that object attached). That event is
consumed by thread A again which imports the event attached object by it's transaction.getObject().
The problem is now that sometimes the modifications of thread B are visible in thread A, and
sometimes not.
Is there a way to make sure that all updates from the other thread have arrived?
Kai
Re: [CDO] Thread race condition with two transactions. [message #431635 is a reply to message #431634] |
Sun, 19 July 2009 10:27   |
Kai,
Yes, I'll also use CDOViewInvalidationEvent for the new convenience methods.
Cheers
/Eike
Kai Schlamp schrieb:
>>>> It's not the default because CDOSessionInvalidationEvent often is a
>>>> better alternative, like in this case.
>>> I just tried it with CDOSessionInvalidationEvent instead, and guess
>>> what ... the same problem of not visible updates in transaction A.
>>> If I listen to CDOSessionInvalidationEvent in thread A, it is not
>>> guaranteed that the updates of transaction B in thread B have already
>>> arrived.
>>> With CDOViewInvalidationEvent that works (at least I have not had a
>>> problem so far).
>>> Is that really the way it should be?
>> Sorry, my fault ;-(
>> Yes, it's meant to be like that: CDOSessionInvalidationEvent indicates
>> avaiability of new revisions. The same internal code that fires these
>> events also calls the internal view methods that emit the EMF
>> notifications and finally fire the CDOViewInvalidationEvent. But the
>> last two happen asynchronously.
> Just for clarification ... when I use CDOViewInvalidationEvent in my
> example I can always assume that the object in transaction A of thread
> A is completely updated (with the modifications from transaction B),
> and so CDOViewInvalidationEvent is the way to go for me.
> Right?
> Thanks in advance,
> Kai
Re: [CDO] Thread race condition with two transactions. [message #431636 is a reply to message #431633] |
Sun, 19 July 2009 10:28   |
Oh thanks for the hint, Simon. I also must update the FAQ then, as I just added the
CDOViewInvalidationEvent there.
By the way, may I ask you, if you could take a short look in bug 279982
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=279982) some time in the next days.
It would mean much to me and my project.
Simon McDuff wrote:
> Small comments:
> CDOViewInvalidationEvent will always be trigger as soon as you have
> objects in your view that are invalidate. You do not control that.
> This is different than from the
> view.options().isInvalidationNotificationEnabled().
> isInvalidationNotificationEnabled will enabled EMF notifications.
> Simon
>>> In the meantime I am listening to changes with the help of
>>> CDOViewInvalidationEvent and CDOTransactionHandler, but I still think
>>> that this would be a good enhancement.
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=283947
>> Thx.
>>> Another question. Is enabling CDOViewInvalidationEvent a big overhead?
>>> (I guess that's why it is no enabled by default).
>> It's not too big, although it can involve some extra threads and EMF
>> adapter notification.
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
>>> Eike Stepper wrote:
>>>> Kai,
>>>> I fear we must apologize because the reload() methods, i.e.
>>>> CDOObject.cdoReload() and CDOView.reload() are meant to be removed:
>>>> 274111: Remove CDOView.reload
>>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=274111
>>>> It seems to be a historical relict and we even could not find out
>>>> why it
>>>> was provided initially (crippeled CVS history after move) ;-(
>>>> As an alternative solution in your scenario we could consider adding a
>>>> utility method that blocks until a given commit operation of
>>>> transaction
>>>> A is visible in transaction B:
>>>> transactionA.commit();
>>>> long commitTime = transactionA.getLastCommitTime();
>>>> viewB.waitForCommit(commitTime);
>>>> Would that help? Please file file an enhancement request ;-)
>>>> Cheers
>>>> /Eike
>>>>> Something I should have mentioned. In thread A I use object.cdoReload
>>>>> when that event occurs. I assumed that by object.cdoReload the
>>>>> repository is checked if there are any updates (and thread B already
>>>>> committed at that time). But the committed changes are still not there
>>>>> after cdoReload.
>>>>> So it seems that cdoReload does not do what I expect from it.
>>>>> Kai Schlamp wrote:
>>>>>> Hello.
>>>>>> session accessing the same resource. In thread B I imported an object
>>>>>> of thread A by using transaction.getObject(). In thread B I
>>>>>> object attached). That event is consumed by thread A again which
>>>>>> visible in thread A, and sometimes not.
>>>>>> have arrived?
>>>>>> Regards,
>>>>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431637 is a reply to message #431636] |
Sun, 19 July 2009 10:35   |
The following is working
public void testLengthAnnotationPositive() throws Exception
disableConsole();
msg("Opening session");
CDOSession session = openModel1Session();
msg("Opening transaction");
CDOTransaction transaction1 = session.openTransaction();
msg("Creating resource");
CDOResource resource = transaction1.createResource("/test1");
List<Product1> products = new ArrayList<Product1>();
for (int i = 0; i < 1000; i++)
Product1 product = Model1Factory.eINSTANCE.createProduct1();
product.setName("unmodified");
products.add(product);
resource.getContents().add(product);
transaction1.commit();
final CDOTransaction transaction2 = session.openTransaction();
final ConcurrentValue<Boolean> changed = new
ConcurrentValue<Boolean>(Boolean.FALSE);
transaction1.addListener(new IListener()
public void notifyEvent(IEvent event)
if (event instanceof CDOViewInvalidationEvent)
changed.set(Boolean.TRUE);
for (Product1 product : products)
Product1 importedProduct = transaction2.getObject(product);
importedProduct.setName("modified");
transaction2.commit();
changed.acquire(Boolean.TRUE);
changed.set(Boolean.FALSE);
Product1 reimportedProduct = transaction1.getObject(importedProduct);
assertEquals("modified", reimportedProduct.getName());
> just added the CDOViewInvalidationEvent there.
> next days.
> Simon McDuff wrote:
>> Small comments:
>> Simon
>>> Thx.
>>> Cheers
>>> /Eike
>>>> Eike Stepper wrote:
>>>>> Kai,
>>>>> why it
>>>>> transaction
>>>>> Cheers
>>>>> /Eike
>>>>>> there
>>>>>> after cdoReload.
>>>>>> Kai Schlamp wrote:
>>>>>>> Hello.
>>>>>>> object
>>>>>>> have arrived?
>>>>>>> Regards,
>>>>>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431638 is a reply to message #431637] |
Sun, 19 July 2009 10:37  |
The only things that is missing is the following:
CDOViewInvalidationEvent.getView() (TO know from which source is come from).
Simon
> disableConsole();
>> 279982 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=279982) some
>> Simon McDuff wrote:
>>> Small comments:
>>> Simon
>>>> Thx.
>>>> Cheers
>>>> /Eike
>>>>> Eike Stepper wrote:
>>>>>> Kai,
>>>>>> why it
>>>>>> adding a
>>>>>> transaction
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> object.cdoReload
>>>>>>> there
>>>>>>> after cdoReload.
>>>>>>> Kai Schlamp wrote:
>>>>>>>> Hello.
>>>>>>>> object
>>>>>>>> have arrived?
>>>>>>>> Regards,
>>>>>>>> Kai
Current Time: Sat Jul 19 03:54:25 EDT 2025
Powered by FUDForum. Page generated in 0.06238 seconds
