Home » Modeling » EMF » [CDO] query server for existing repository
[CDO] query server for existing repository [message #431515] Tue, 14 July 2009 13:30 Go to next message
hi folks,
how can I check if a cdo server already contains a repository?
my scenario is the following:
1. start server
2. create repository "repo1"
3. shutdown server
4. restart server
5. open "repo1"
I tried the following:
IRepository repository = CDOServerUtil.getRepository(container,
repositoryName);
if(repository == null){
//create repo
}else{
//use existing repo
but I get an exception:
org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not
found: org.eclipse.emf.cdo.server.repositories[default]
cheers,
steven
Re: [CDO] query server for existing repository [message #431518 is a reply to message #431515] Wed, 15 July 2009 03:26 Go to previous messageGo to next message
Steven,
There's no single and mandatory way to create repositories or make them
available on a server. They are no operating services by themselves so
they do not automatically appear after a server restart, unless you
ensure that the repository is started again, too.
If, after starting a repository, you put it into an IManagedContainer
you can query the container, as you try it below. But a repository does
not automatically end up registered with such a container. You'd have to
register it there for example with
CDOServerUtil.addRepository(IManagedContainer, IRepository).
You could also use the OSGi service registry or a Spring application
context or your own mechanism...
Cheers
/Eike
steven schrieb:
> hi folks,
> 1. start server
> 3. shutdown server
> 4. restart server
> 5. open "repo1"
> repositoryName);
> //create repo
> }else{
> //use existing repo
> cheers,
> steven
Re: [CDO] query server for existing repository [message #431532 is a reply to message #431518] Wed, 15 July 2009 05:19 Go to previous messageGo to next message
eike,
comments below ..
Eike Stepper wrote:
> Steven,
that's what I want .. how I can start a repository again; respectively,
how can I restart all previously created repositories after a server
restart?
cheers,
steven
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> steven schrieb:
>> hi folks,
>> 1. start server
>> 3. shutdown server
>> 4. restart server
>> 5. open "repo1"
>> repositoryName);
>> //create repo
>> }else{
>> //use existing repo
>> cheers,
>> steven
Re: [CDO] query server for existing repository [message #431533 is a reply to message #431532] Wed, 15 July 2009 09:17 Go to previous messageGo to next message
Steven,
There is no magic in CDO that does this automatically. *You* must do
that by executing the same Java statements that you initially executed.
Cheers
/Eike
steven schrieb:
> eike,
> comments below ..
> Eike Stepper wrote:
>> Steven,
> restart?
> cheers,
> steven
>> Cheers
>> /Eike
>> steven schrieb:
>>> hi folks,
>>> 1. start server
>>> 3. shutdown server
>>> 4. restart server
>>> 5. open "repo1"
>>> repositoryName);
>>> //create repo
>>> }else{
>>> //use existing repo
>>> cheers,
>>> steven
Re: [CDO] query server for existing repository [message #431545 is a reply to message #431533] Wed, 15 July 2009 06:26 Go to previous messageGo to next message
eike,
I am executing the same java statements, but if I stop the server
in the osgi console and start it again, I get the exception I appended
at the end.
the exception is thrown when I check if my repository's structure has
already been created:
protected void createRepositoryStructure() {
CDOTransaction transaction = null;
if(!view.hasResource(SOL_ARCH_FOLDER_NAME)){//exception thrown here
transaction = session.openTransaction();
CDOResourceFolder solArchfolder =
EresourceFactory.eINSTANCE.createCDOResourceFolder();
solArchfolder.setName(SOL_ARCH_FOLDER_NAME);
EList<EObject> rootContent =
transaction.getRootResource().getContents();
rootContent.add(solArchfolder);
transaction.commit();
transaction.close();
so, initially the method createRepositoryStructure() works fine,
but then it crashes with the following exception:
[ERROR] EOFException
java.io.EOFException
at java.io.DataInputStream.readBoolean(DataInputStream.java:227 )
at
org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readB oolean(ExtendedDataInput.java:55)
at
org.eclipse.emf.cdo.internal.common.io.CDODataInputImpl.read CDORevision(CDODataInputImpl.java:214)
at
org.eclipse.emf.internal.cdo.net4j.protocol.LoadRevisionRequ est.confirming(LoadRevisionRequest.java:116)
at
org.eclipse.emf.internal.cdo.net4j.protocol.LoadRevisionRequ est.confirming(LoadRevisionRequest.java:1)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientRequest .confirming(CDOClientRequest.java:77)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestWithConfirmation.java:123)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:103)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:66)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
at
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:421)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doSend(Requ estWithConfirmation.java:87)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtoco l.send(CDOClientProtocol.java:286)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtoco l.send(CDOClientProtocol.java:319)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtoco l.loadRevisions(CDOClientProtocol.java:110)
at
org.eclipse.emf.internal.cdo.session.CDORevisionManagerImpl. loadRevisions(CDORevisionManagerImpl.java:124)
at
org.eclipse.emf.internal.cdo.session.CDORevisionManagerImpl. loadRevision(CDORevisionManagerImpl.java:106)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevision(CDORevisionResolverImpl.java:155)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevision(CDORevisionResolverImpl.java:1)
at
org.eclipse.emf.internal.cdo.view.CDOViewImpl.getRevision(CD OViewImpl.java:682)
at
org.eclipse.emf.internal.cdo.view.CDOViewImpl.getLocalRevisi on(CDOViewImpl.java:561)
at
org.eclipse.emf.internal.cdo.view.CDOViewImpl.getResourceNod eID(CDOViewImpl.java:508)
at
org.eclipse.emf.internal.cdo.view.CDOViewImpl.getResourceNod eIDChecked(CDOViewImpl.java:447)
at
org.eclipse.emf.internal.cdo.view.CDOViewImpl.getResourceNod eID(CDOViewImpl.java:435)
at
org.eclipse.emf.internal.cdo.view.CDOViewImpl.hasResource(CD OViewImpl.java:376)
at
de.hpi.sam.mdcm.cmdb.repository.Repository.createRepositoryS tructure(Repository.java:49)
at de.hpi.sam.mdcm.cmdb.repository.Repository.<init>(Repository.java:31)
at
de.hpi.sam.mdcm.cmdb.server.internal.CMDBServer.createReposi tory(CMDBServer.java:138)
at de.hpi.sam.mdcm.cmdb.server.internal.Activator.start(Activat or.java:38)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:257)
at
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:257)
at
at
at
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:150)
at
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:302)
at
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:287)
at
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:223)
at java.lang.Thread.run(Thread.java:619)
!ENTRY org.eclipse.net4j 4 0 2009-07-15 12:09:16.179
!MESSAGE EOFException
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
what am I missing?
cheers,
steven
Eike Stepper wrote:
> Steven,
> Cheers
> /Eike
> steven schrieb:
>> eike,
>> comments below ..
>> Eike Stepper wrote:
>>> Steven,
>> restart?
>> cheers,
>> steven
>>> Cheers
>>> /Eike
>>> steven schrieb:
>>>> hi folks,
>>>> 1. start server
>>>> 3. shutdown server
>>>> 4. restart server
>>>> 5. open "repo1"
>>>> repositoryName);
>>>> //create repo
>>>> }else{
>>>> //use existing repo
>>>> cheers,
>>>> steven
Re: [CDO] query server for existing repository [message #431550 is a reply to message #431545] Thu, 16 July 2009 00:59 Go to previous messageGo to next message
Steven,
Neither CDOResources nor CDOResourceFolders should be created manually
by you. You should never use EresourceFactory directly.
CDOResources are created automatically, either with
ResourceSet.createResource(uri), CDOTransaction.createResource(path) or
CDOTransaction.getOrCreateResource(path). CDOResourceFolders are created
implicitely when you create a CDOResource with slashes in its path.
Please try this:
CDOTransaction transaction = session.openTransaction();
transaction.getOrCreateResource(SOL_ARCH_FOLDER_NAME +
"/SolArchResource");
Or this, if you need access to the folder:
CDOResource solArchResource =
transaction.getOrCreateResource(SOL_ARCH_FOLDER_NAME + "/SolArchResource");
CDOResourceFolder solArchFolder = solArchResource.getFolder();
solArchFolder.xyz();
Does this help?
Cheers
/Eike
steven schrieb:
> eike,
> at the end.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> what am I missing?
> cheers,
> steven
> Eike Stepper wrote:
>> Steven,
>> Cheers
>> /Eike
>> steven schrieb:
>>> eike,
>>> comments below ..
>>> Eike Stepper wrote:
>>>> Steven,
>>>> them
>>> restart?
>>> cheers,
>>> steven
>>>> does
>>>> have to
>>>> Cheers
>>>> /Eike
>>>> steven schrieb:
>>>>> hi folks,
>>>>> 1. start server
>>>>> 3. shutdown server
>>>>> 4. restart server
>>>>> 5. open "repo1"
>>>>> repositoryName);
>>>>> //create repo
>>>>> }else{
>>>>> //use existing repo
>>>>> not
>>>>> cheers,
>>>>> steven
Re: [CDO] query server for existing repository [message #431559 is a reply to message #431550] Thu, 16 July 2009 10:56 Go to previous messageGo to next message
eike,
it helped!
but .. I am having a different problem:
I can store some models on the server properly, but
after some (the concrete number is not deterministic) models
have been inserted I get the following exception:
[ERROR] Rollback in DBStore: org.eclipse.net4j.db.DBException: SQL
Exception: A lock could not be obtained within the time requested
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ob jectTypeCache.putObjectType(ObjectTypeCache.java:137)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalMappingStrategy.putObjectType(AbstractHorizo ntalMappingStrategy.java:69)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping.writeRevision(AbstractHorizonta lClassMapping.java:326)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write Revision(DBStoreAccessor.java:355)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write Revisions(DBStoreAccessor.java:337)
at
org.eclipse.emf.cdo.spi.server.StoreAccessor.write(StoreAcce ssor.java:142)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.acces s$4(DBStoreAccessor.java:1)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:80)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:1)
at
org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr ogressDistributor.java:96)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write (DBStoreAccessor.java:294)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext Impl.write(TransactionCommitContextImpl.java:269)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication$1.runLoop(CommitTransactionIndication.java:73)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication$1.runLoop(CommitTransactionIndication.java:1)
at
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicatingCommit(CommitTransactionIndication.ja va:325)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:198 )
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:140 )
at
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:885)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
Caused by: SQL Exception: A lock could not be obtained within the time
requested
at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unkno wn Source)
at
org.apache.derby.impl.jdbc.TransactionResourceImpl.wrapInSQL Exception(Unknown
Source)
at
org.apache.derby.impl.jdbc.TransactionResourceImpl.handleExc eption(Unknown
Source)
at org.apache.derby.impl.jdbc.EmbedConnection.handleException(U nknown
Source)
at org.apache.derby.impl.jdbc.ConnectionChild.handleException(U nknown
Source)
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(U nknown
Source)
at
org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeSta tement(Unknown
Source)
at
org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpd ate(Unknown
Source)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ob jectTypeCache.putObjectType(ObjectTypeCache.java:128)
... 27 more
why the lock not be obtained, although some models could be stored?
cheers,
steven
Eike Stepper wrote:
> Steven,
> Please try this:
> Does this help?
> Cheers
> /Eike
> steven schrieb:
>> eike,
>> at the end.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> what am I missing?
>> cheers,
>> steven
>> Eike Stepper wrote:
>>> Steven,
>>> Cheers
>>> /Eike
>>> steven schrieb:
>>>> eike,
>>>> comments below ..
>>>> Eike Stepper wrote:
>>>>> Steven,
>>>>> them
>>>> restart?
>>>> cheers,
>>>> steven
>>>>> does
>>>>> have to
>>>>> Cheers
>>>>> /Eike
>>>>> steven schrieb:
>>>>>> hi folks,
>>>>>> 1. start server
>>>>>> 3. shutdown server
>>>>>> 4. restart server
>>>>>> 5. open "repo1"
>>>>>> repositoryName);
>>>>>> //create repo
>>>>>> }else{
>>>>>> //use existing repo
>>>>>> not
>>>>>> cheers,
>>>>>> steven
Re: [CDO] query server for existing repository [message #431564 is a reply to message #431559] Thu, 16 July 2009 13:03 Go to previous messageGo to next message
Steven,
I avguely remember a similar problem in our Derby based tests but I
can't remember the reason anymore. Stefan?
Have you considered using H2 instead of Derby? Additional benefit would
be performance boost of factor 2 to 10:
http://markmail.org/message/7zrgefmi7gi24t7d
http://www.encorewiki.org/display/encore/Open+Source+Databas es+Comparison
steven schrieb:
> eike,
> it helped!
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> requested
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 27 more
> cheers,
> steven
> Eike Stepper wrote:
>> Steven,
>> Please try this:
>> Does this help?
>> Cheers
>> /Eike
>> steven schrieb:
>>> eike,
>>> at the end.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> what am I missing?
>>> cheers,
>>> steven
>>> Eike Stepper wrote:
>>>> Steven,
>>>> executed.
>>>> Cheers
>>>> /Eike
>>>> steven schrieb:
>>>>> eike,
>>>>> comments below ..
>>>>> Eike Stepper wrote:
>>>>>> Steven,
>>>>>> them
>>>>>> themselves so
>>>>> respectively,
>>>>> restart?
>>>>> cheers,
>>>>> steven
>>>>>> IManagedContainer
>>>>>> does
>>>>>> have to
>>>>>> Cheers
>>>>>> /Eike
>>>>>> steven schrieb:
>>>>>>> hi folks,
>>>>>>> 1. start server
>>>>>>> 3. shutdown server
>>>>>>> 4. restart server
>>>>>>> 5. open "repo1"
>>>>>>> repositoryName);
>>>>>>> //create repo
>>>>>>> }else{
>>>>>>> //use existing repo
>>>>>>> not
>>>>>>> cheers,
>>>>>>> steven
Re: [CDO] query server for existing repository [message #431572 is a reply to message #431559] Fri, 17 July 2009 04:29 Go to previous messageGo to next message
Hi steven,
that SQL Exception has occurred a few months ago - see Bug 276926:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=276926
Are you using Gallileo or an earlier Version?
If you are using galileo, can you describe the context a bit more?
Do you run a single-user application or are there other concurrent users?
The line in the stack trace does a "INSERT IGNORE INTO cdo_objects VALUES
(cdoid, class_metaId).
The Derby documentation states that insert will acquire a row lock for
the new row.
I currently don't understand why acquiring such a lock could cause a
deadlock. :-(
The only thing which could be possible would be:
"Derby locks single rows for INSERT statements, holding each row until
the transaction is committed. (If there is an index associated with the
table, the previous key is also locked.)"
[ http://db.apache.org/derby/docs/10.0/manuals/develop/develop 74.html]
So the previous key (cdo_id) is also locked. If that key is not locked
as part of the current transaction, but as part of another transaction,
the current transaction waits for the other transaction to finish. If
this times out (derby standard is 10s, AFAIK), you get the said Exception.
So, do you think this case is possible? Do you do huge transactions in
parallel?
Also, in order to analyse the problem, you could set the properties
derby.locks.monitor=true and *derby.language.logStatementText=true*
*then information about acquired locks and locks causing the deadlock
are written to derby.log.*
*Cheers,*
*Stefan*
steven schrieb:
> eike,
> it helped!
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> requested
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 27 more
> cheers,
> steven
> Eike Stepper wrote:
>> Steven,
>> Please try this:
>> Does this help?
>> Cheers
>> /Eike
>> steven schrieb:
>>> eike,
>>> at the end.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> what am I missing?
>>> cheers,
>>> steven
>>> Eike Stepper wrote:
>>>> Steven,
>>>> executed.
>>>> Cheers
>>>> /Eike
>>>> steven schrieb:
>>>>> eike,
>>>>> comments below ..
>>>>> Eike Stepper wrote:
>>>>>> Steven,
>>>>>> them
>>>>>> themselves so
>>>>> respectively,
>>>>> restart?
>>>>> cheers,
>>>>> steven
>>>>>> IManagedContainer
>>>>>> does
>>>>>> have to
>>>>>> Cheers
>>>>>> /Eike
>>>>>> steven schrieb:
>>>>>>> hi folks,
>>>>>>> 1. start server
>>>>>>> 3. shutdown server
>>>>>>> 4. restart server
>>>>>>> 5. open "repo1"
>>>>>>> repositoryName);
>>>>>>> //create repo
>>>>>>> }else{
>>>>>>> //use existing repo
>>>>>>> not
>>>>>>> cheers,
>>>>>>> steven
Re: [CDO] query server for existing repository [message #431573 is a reply to message #431564] Fri, 17 July 2009 04:36 Go to previous messageGo to next message
eike,
now, I am using H2 and it works!
but, I could not find the H2Adapter in the latest net4j sdk.
instead, I took it from here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.net4j/plugins/org.eclipse.net4j.db.h2/src/org/e clipse/net4j/db/h2/H2Adapter.java?root=Modeling_Project& view=co
, and added it to my workspace.
Why isn't it in the release?
cheers,
steven
Eike Stepper wrote:
> Steven,
> steven schrieb:
>> eike,
>> it helped!
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> requested
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> ... 27 more
>> cheers,
>> steven
>> Eike Stepper wrote:
>>> Steven,
>>> Please try this:
>>> Does this help?
>>> Cheers
>>> /Eike
>>> steven schrieb:
>>>> eike,
>>>> at the end.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> what am I missing?
>>>> cheers,
>>>> steven
>>>> Eike Stepper wrote:
>>>>> Steven,
>>>>> executed.
>>>>> Cheers
>>>>> /Eike
>>>>> steven schrieb:
>>>>>> eike,
>>>>>> comments below ..
>>>>>> Eike Stepper wrote:
>>>>>>> Steven,
>>>>>>> them
>>>>>>> themselves so
>>>>>> respectively,
>>>>>> restart?
>>>>>> cheers,
>>>>>> steven
>>>>>>> IManagedContainer
>>>>>>> does
>>>>>>> have to
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>> steven schrieb:
>>>>>>>> hi folks,
>>>>>>>> 1. start server
>>>>>>>> 3. shutdown server
>>>>>>>> 4. restart server
>>>>>>>> 5. open "repo1"
>>>>>>>> repositoryName);
>>>>>>>> //create repo
>>>>>>>> }else{
>>>>>>>> //use existing repo
>>>>>>>> not
>>>>>>>> cheers,
>>>>>>>> steven
Re: [CDO] query server for existing repository [message #431574 is a reply to message #431573] Fri, 17 July 2009 04:45 Go to previous messageGo to next message
steven schrieb:
> eike,
Great ;-)
Because our build system currently does not support inclusion of bundles
with unsaturated (non-optional) dependencies ;-(
We're working on that. In the meantime you'll find all DBAdapter bundles
and their 3rd party deps here: http://net4j.sourceforge.net/update/ (a
p2 update site!!)
Cheers
/Eike
> cheers,
> steven
> Eike Stepper wrote:
>> Steven,
>> steven schrieb:
>>> eike,
>>> it helped!
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> requested
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> ... 27 more
>>> cheers,
>>> steven
>>> Eike Stepper wrote:
>>>> Steven,
>>>> created
>>>> Please try this:
>>>> Does this help?
>>>> Cheers
>>>> /Eike
>>>> steven schrieb:
>>>>> eike,
>>>>> appended
>>>>> at the end.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> what am I missing?
>>>>> cheers,
>>>>> steven
>>>>> Eike Stepper wrote:
>>>>>> Steven,
>>>>>> executed.
>>>>>> Cheers
>>>>>> /Eike
>>>>>> steven schrieb:
>>>>>>> eike,
>>>>>>> comments below ..
>>>>>>> Eike Stepper wrote:
>>>>>>>> Steven,
>>>>>>>> them
>>>>>>>> themselves so
>>>>>>>> you
>>>>>>> respectively,
>>>>>>> server
>>>>>>> restart?
>>>>>>> cheers,
>>>>>>> steven
>>>>>>>> IManagedContainer
>>>>>>>> does
>>>>>>>> have to
>>>>>>>> application
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>> steven schrieb:
>>>>>>>>> hi folks,
>>>>>>>>> 1. start server
>>>>>>>>> 3. shutdown server
>>>>>>>>> 4. restart server
>>>>>>>>> 5. open "repo1"
>>>>>>>>> repositoryName);
>>>>>>>>> //create repo
>>>>>>>>> }else{
>>>>>>>>> //use existing repo
>>>>>>>>> Factory
>>>>>>>>> not
>>>>>>>>> cheers,
>>>>>>>>> steven
Re: [CDO] query server for existing repository [message #431575 is a reply to message #431572] Fri, 17 July 2009 05:16 Go to previous messageGo to next message
hi stefan,
comments below ..
Stefan Winkler wrote:
> Hi steven,
I am using ganymede.
> the new row.
> deadlock. :-(
> parallel?
No huge transaction. Currently, I am only testing with a small workload:
insert around 5 models and having registered adapters listening for
notifications.
The weird thing is, that if I create a fresh derby database, everything
works fine. I can constantly insert models without a deadlock. if the
server is stopped, and then restarted using the existing database, the
lock-exception occurs (sometimes) at the insertion of the first model.
but, as I wrote in the other mail, I am using H2, now; and this is fine
for me!
thx for your support eike & stefan!!
cheers,
steven
> *Cheers,*
> *Stefan*
> steven schrieb:
>> eike,
>> it helped!
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> requested
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> ... 27 more
>> cheers,
>> steven
>> Eike Stepper wrote:
>>> Steven,
>>> Please try this:
>>> Does this help?
>>> Cheers
>>> /Eike
>>> steven schrieb:
>>>> eike,
>>>> at the end.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> what am I missing?
>>>> cheers,
>>>> steven
>>>> Eike Stepper wrote:
>>>>> Steven,
>>>>> executed.
>>>>> Cheers
>>>>> /Eike
>>>>> steven schrieb:
>>>>>> eike,
>>>>>> comments below ..
>>>>>> Eike Stepper wrote:
>>>>>>> Steven,
>>>>>>> them
>>>>>>> themselves so
>>>>>> respectively,
>>>>>> restart?
>>>>>> cheers,
>>>>>> steven
>>>>>>> IManagedContainer
>>>>>>> does
>>>>>>> have to
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>> steven schrieb:
>>>>>>>> hi folks,
>>>>>>>> 1. start server
>>>>>>>> 3. shutdown server
>>>>>>>> 4. restart server
>>>>>>>> 5. open "repo1"
>>>>>>>> repositoryName);
>>>>>>>> //create repo
>>>>>>>> }else{
>>>>>>>> //use existing repo
>>>>>>>> not
>>>>>>>> cheers,
>>>>>>>> steven
Re: [CDO] query server for existing repository [message #431580 is a reply to message #431575] Fri, 17 July 2009 07:36 Go to previous message
Hi Steven,
That may be the problem as the bug you describe (lock exception after
restart) is actually exactly the one, we fixed in Bug 276926:
So, if you encounter related issues again in the future, I suggest
updating to Gallileo.
Stefan
>> users?
>> the new row.
>> deadlock. :-(
>> Exception.
>> parallel?
> workload: insert around 5 models and having registered adapters
> listening for notifications.
> everything works fine. I can constantly insert models without a
> deadlock. if the server is stopped, and then restarted using the
> existing database, the lock-exception occurs (sometimes) at the
> for me!
> cheers,
> steven
>> *Cheers,*
>> *Stefan*
>> steven schrieb:
>>> eike,
>>> it helped!
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> requested
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> ... 27 more
>>> cheers,
>>> steven
>>> Eike Stepper wrote:
>>>> Steven,
>>>> created
>>>> Please try this:
>>>> Does this help?
>>>> Cheers
>>>> /Eike
>>>> steven schrieb:
>>>>> eike,
>>>>> appended
>>>>> at the end.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> what am I missing?
>>>>> cheers,
>>>>> steven
>>>>> Eike Stepper wrote:
>>>>>> Steven,
>>>>>> executed.
>>>>>> Cheers
>>>>>> /Eike
>>>>>> steven schrieb:
>>>>>>> eike,
>>>>>>> comments below ..
>>>>>>> Eike Stepper wrote:
>>>>>>>> Steven,
>>>>>>>> them
>>>>>>>> themselves so
>>>>>>>> you
>>>>>>> respectively,
>>>>>>> server
>>>>>>> restart?
>>>>>>> cheers,
>>>>>>> steven
>>>>>>>> IManagedContainer
>>>>>>>> does
>>>>>>>> have to
>>>>>>>> application
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>> steven schrieb:
>>>>>>>>> hi folks,
>>>>>>>>> 1. start server
>>>>>>>>> 3. shutdown server
>>>>>>>>> 4. restart server
>>>>>>>>> 5. open "repo1"
>>>>>>>>> repositoryName);
>>>>>>>>> //create repo
>>>>>>>>> }else{
>>>>>>>>> //use existing repo
>>>>>>>>> Factory
>>>>>>>>> not
>>>>>>>>> cheers,
>>>>>>>>> steven
Previous Topic:edit FeatureMap Text feature from text field in a form
Next Topic:No packages listed when importing from annotated java
Current Time: Sun Jul 27 12:58:21 EDT 2025
Powered by FUDForum. Page generated in 0.06118 seconds
