Home » Modeling » EMF » [CDO] commit ends in NullPointerException
[CDO] commit ends in NullPointerException [message #431516] Tue, 14 July 2009 17:28 Go to next message
Originally posted by: AM-81.web.de
--------------060004000804030005040604
I have the following problem. For better understanding I made a little
test case and attached my projects for import. I work with the
downloaded package eclipse-modeling-galileo-incubation-win32.
Well, there are two simple ecore models. One has three classes c1,c2 and
c3, while c1 is superclass of c2 and every class has one attribute.
In the second model is only one class c4 which has c2 from the first
model as superclass.
Now I try to persist class c4 with an CDO server. I use the server as an
eclipse app and the standard config I found in the wiki, just change the
databaseName.
I open the CDO Session View, open a session, register the package from
the second model, open a transaction, create a resource, add a c4
object as a new root, fill something in the attributes and commit the
transaction.
Till now everything works without errors. Now the problem. If I change
the attribute a2 or a4 and try to commit, I get an protocol problem in
CDOSession with an NullPointerException:
org.eclipse.net4j.signal.RemoteException: java.lang.NullPointerException
at
org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteEx ception(RequestWithConfirmation.java:128)
at
org.eclipse.net4j.signal.SignalProtocol.handleRemoteExceptio n(SignalProtocol.java:491)
at
org.eclipse.net4j.signal.RemoteExceptionIndication.indicatin g(RemoteExceptionIndication.java:53)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indicati on.java:55)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
at org.eclipse.net4j.signal.Indication.execute(Indication.java: 49)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at
org.eclipse.emf.ecore.util.FeatureMapUtil.isFeatureMap(Featu reMapUtil.java:150)
at
org.eclipse.emf.cdo.internal.common.revision.delta.CDOSingle ValueFeatureDeltaImpl. <init>(CDOSingleValueFeatureDeltaImpl.java:51)
at
org.eclipse.emf.cdo.internal.common.revision.delta.CDOSetFea tureDeltaImpl. <init>(CDOSetFeatureDeltaImpl.java:38)
at
org.eclipse.emf.cdo.internal.common.io.CDODataInputImpl.read CDOFeatureDelta(CDODataInputImpl.java:308)
at
org.eclipse.emf.cdo.internal.common.revision.delta.CDORevisi onDeltaImpl. <init>(CDORevisionDeltaImpl.java:109)
at
org.eclipse.emf.cdo.internal.common.io.CDODataInputImpl.read CDORevisionDelta(CDODataInputImpl.java:295)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicatingCommit(CommitTransactionIndication.ja va:301)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:197 )
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:140 )
at
org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
... 5 more
Changing attribute a1 and commit is no problem, but the others fails.
Now the other thing. When I close the session, open a new one and load
the resource which I stored before, there is class c4 in it, but has
only the attribute a4. Where are the others?
So, I hope someone can told me if it is my mistake or is it not possible
to persist such a data structure with CDO.
Many thanks,
Andr
Re: [CDO] commit ends in NullPointerException [message #431521 is a reply to message #431516] Wed, 15 July 2009 05:30 Go to previous messageGo to next message
--------------030806010404010004040306
Andr
Re: [CDO] commit ends in NullPointerException [message #431656 is a reply to message #431521] Mon, 20 July 2009 19:07 Go to previous messageGo to next message
Hi Eike,
sorry for my late reply and thanks for your help.
Well it seems to work now. The JRE was not important but the thing
with the automatic registering. If I export my plugins to the dropins
folder everythings works.
Is there a reason why it doesn't work by manually registering them from
the workspace?
André
Eike Stepper schrieb:
> André,
> I tried your example in both HEAD and R2_0_maintenance and it works
> without problems. I attached the client log from running the HEAD client.
> But I changed the following:
> 1) In your model plugins I used J2SE-1.5 instead of JavaSE-1.6
> 2) I used the automatic package registry (the default) instead of
> manually registering your models
> Can you try that, too?
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> André Müller schrieb:
>> Hi,
>> and c3, while c1 is superclass of c2 and every class has one attribute.
>> an eclipse app and the standard config I found in the wiki, just
>> change the
>> databaseName.
>> transaction.
>> at
>> at
>> at
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 5 more
>> possible to persist such a data structure with CDO.
>> Many thanks,
>> André
Re: [CDO] commit ends in NullPointerException [message #431657 is a reply to message #431656] Tue, 21 July 2009 00:34 Go to previous messageGo to next message
> Hi Eike,
That's good ;-)
> from the workspace?
Since it's a while back I can't remember all the details of what you've
done. What exactly do you mean by "manually registering them from the
workspace"? Does that mean you registered EPackages that were
dynamically loaded from the .ecore files in the workspace? Or does that
mean you included the plugin projects of the models into a launch
config, i.e. generated models from the host workspace?
Cheers
/Eike
> Regards,
> André
>> André,
>> client.
>> Cheers
>> /Eike
>>> Hi,
>>> change the
>>> databaseName.
>>> transaction.
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 5 more
>>> Many thanks,
>>> André
Re: [CDO] commit ends in NullPointerException [message #431695 is a reply to message #431657] Tue, 21 July 2009 19:25 Go to previous messageGo to next message
>> Hi Eike,
> That's good ;-)
>> from the workspace?
Well, I'm not really sure if thats what I do, but I think I register
EPackages that were dynamically loaded from the .ecore files.
(I create the ecore model, generate the model code and open a Session in
the CDO UI and register the packages over the "Register Workspace
Packages..." item in the context menu of Session.)
André
> Cheers
> /Eike
>> Regards,
>> André
>>> André,
>>> client.
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> change the
>>>> databaseName.
>>>> transaction.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 5 more
>>>> Many thanks,
>>>> André
Re: [CDO] commit ends in NullPointerException [message #431696 is a reply to message #431695] Wed, 22 July 2009 00:09 Go to previous message
> in the CDO UI and register the packages over the "Register Workspace
I need to better understand your deployment scenario. Is the CDO UI
deployed into your host IDE or are you launching a runtime workbench
from there (or an RCP app)?
The point is that if you generate Java code from an Ecore model this
Java code usually must be deployed to a runnable Eclipse instance. That
is what happens when you launch a runtime workbench. By deploying the
generated model plugins the generated packages automatically get
registered with the global package registry of EMF.
When you open a CDOSession through the CDO UI (in your runtime
workbench!) there's an option "Automatic Package Registry" which is on
by default. That means that the package registry of that new CDOSession
will be (unidirectionally) synchronized with the EMF global package
registry, which already knows your packages. In short: If you do
everything right all your models should automagically end up being
accessible from your CDOSession.
Please let me know if anything in this description does not match your
setup ;-)
Cheers
/Eike
Previous Topic:[TENEO]Store Resource problem
Next Topic:[Net4j]HeartBeatProtocol can't be used
Current Time: Sat Jul 26 19:17:30 EDT 2025
Powered by FUDForum. Page generated in 0.04329 seconds
