Home » Modeling » EMF » Copy of generated model
Copy of generated model [message #431499] Tue, 14 July 2009 06:01 Go to next message
--------------060506030504000206060800
Content-Type: text/plain; charset=ISO-8859-15
I copied a generated model:
| EPackage model1 = (EPackage)EcoreUtil.copy(getModel1Package());|
Can I expect that the resulting EPackage instance is dynamic and
equivalent to directly loading the original model1.ecore file?
There is an EEnum in this EPackage and I discovered that after copying
the package the enum literals return genrated instances from
literal.getInstance(). Is that a bug or a feature?
Cheers
/Eike
<html>
<head>
</head>
Hi,<br>
<br>
I copied a generated model:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff">
Re: Copy of generated model [message #431500 is a reply to message #431499] Tue, 14 July 2009 06:42 Go to previous messageGo to next message
Eike,
Did you change the nsURI of the copied EPackage? If not, you are likely to
run into trouble since anyone resolving the EPackage or the Factory by nsURI
will retrieve the originally registered instance. Maybe this is what happens
with your enum literals.
Achim
Eike Stepper wrote:
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: Copy of generated model [message #431501 is a reply to message #431500] Tue, 14 July 2009 06:45 Go to previous messageGo to next message
Achim Demelt schrieb:
> Eike,
Well, I'm using my own registry but I'll try your hint. Thx ;-)
Cheers
/Eike
> Cheers,
> Achim
> Eike Stepper wrote:
>> Hi,
>> Cheers
>> /Eike
Re: Copy of generated model [message #431508 is a reply to message #431499] Tue, 14 July 2009 10:23 Go to previous message
A bug, according to Ed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283419
Cheers
/Eike
Eike Stepper schrieb:
> Cheers
> /Eike
Previous Topic:passing a hibernate.cfg.xml to teneo
Next Topic:isComposite and isId usage ?
Current Time: Sat Jul 26 23:17:38 EDT 2025
Powered by FUDForum. Page generated in 0.22680 seconds
