Emf libraries to Central Maven Repository [message #431294] |
Tue, 07 July 2009 15:05  |
My question: Is it possible for the Emf team to deploy the recently
released org.eclipse.emf.* libraries to the Central Maven Repository?
A lot of our Java projects are using Maven as a buildframework. For their
continuous integration needs, it must be possible to build these projects
by Maven outside of Eclipse.
Earlier versions of org.eclipse.emf.ecore already were deployed to Central
Maven Repository, see:
http://repo2.maven.org/maven2/org/eclipse/emf/ecore/2.3.0-v2 00706262000
Because of the growing success of Emf we probably we will use future
versions also, it would be nice if the deployment of the Emf libraries to
the Central Maven Repository could get a place in the release process of
Emf.
Johan.
Re: Emf libraries to Central Maven Repository [message #431377 is a reply to message #431311] |
Wed, 08 July 2009 05:31   |
Johan,
Comments below.
Johan Vogelzang wrote:
> Well, I would like to step up, but don't know were to begin...
Welcome to my world. :-P
> The ideal solution, for as well Eclipse projects as for the Java
> projects that uses them is as follows:
> 1- Setup a central Maven repository within the walls of the
> org.eclipse environment. Only Eclipse projects (org.eclipse.*) are
> allowed to deploy to this repository. Lets name it the Eclipse Maven
> Repository.
> 2- Let the Eclipse Maven Repository automatically synchronize with the
> Central Maven Repository. This is the preferred way by Maven, see for
> more details:
> http://maven.apache.org/guides/mini/guide-central-repository -upload.html
> 3- For individual Eclipse projects (for which its appropriate) its
> only necessary to deploy their released libraries to the Eclipse Maven
> Repository. The automatic synchronization process will take care of
> the rest. Maven has support for this step, see:
> http://maven.apache.org/plugins/maven-eclipse-plugin/to-mave n-mojo.html
That sounds very sensible.
> I suppose point 1- and 2- go beyond the scope of the EMF project. But
> I know that there are more Eclipse projects that have to wrestle this
> same problem. For instance the org.eclipse.xtext project deploys to a
> third party Maven repository. But Java projects in general don't want
> to rely on third party repositories. The only Maven repositories they
> can trust are the Central Maven Repository or mirrors of it.
It would be good to have a sensible strategy around this stuff. What
if, for example, a p2 repository could be automatically converted to a
maven repository and vice versa...
> I hope I made a bit clear that this is a common problem for Eclipse
> projects that want to publish their libraries as Maven artifacts to
> the world. The described solution provides a standard way to deal with
> it, so each Eclipse project could benefit from it.
There are two Maven projects at Eclipse. I'll take the opportunity at
the Architecture Council meeting tomorrow to ask about support for Maven...
> Regards,
> Johan.
Re: Emf libraries to Central Maven Repository [message #431534 is a reply to message #431512] |
Wed, 15 July 2009 09:38  |
--------------070209040908040404050602
Johan,
There should be information in the minutes:
http://wiki.eclipse.org/Architecture_Council/Meetings
E.g., the July 9 minutes are there already.
> Ed,
> Thanks for taking the initiative. What can I do to keep me informed of
> the outcome of the next moth meeting? If more input about this issue
> is needed, let me know.
> Regards,
> Johan.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Johan,<br>
<br>
FUDForum. Page generated in 0.08606 seconds
