Home » Modeling » EMF » [TENEO][EMF] Viewing problems in Linux and Windows
[TENEO][EMF] Viewing problems in Linux and Windows [message #431444] |
Thu, 09 July 2009 13:07  |
--------------030205000707090506000309
i had the attached source for my service. My problem is on windows this
service works realy good and my navigation tree is displayed fine.
I work with 2 resources. (resJahr and resPerson) All things that are in
the second resource are not displayed in Linux.
On my navigation tree i use a AdapterFactoryContentProvider. Can this be
the problem?
Can someone take a look at my file. Please have a special look at
resJahr and resAlles.
If i change the things like in the TeneoLibraryPersistenceService2.java
its the same problem.
Thanks Waldi
Content-Type: text/x-java;
name="TeneoLibraryPersistenceService.java"
Content-Disposition: inline;
filename="TeneoLibraryPersistenceService.java"
package de.connection.service.teneo;
import java.io.IOException;
import java.util.Collections;
import java.util.Properties;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.teneo.PersistenceOptions;
import org.eclipse.emf.teneo.hibernate.HbDataStore;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.eclipse.emf.teneo.hibernate.resource.HibernateResource;
import org.eclipse.emf.teneo.hibernate.resource.SessionController;
import org.hibernate.cfg.Environment;
import zlvp.*;
import de.connection.Activator;
import de.connection.service.BaseLibraryPersistenceService;
public abstract class TeneoLibraryPersistenceService extends BaseLibraryPersistenceService {
private Resource resAlles;
private Resource resPerson;
private Resource resAnrede;
private Resource resGeschlecht;
private Resource resJahr;
private SessionController sc;
public String getCategory() {
return "Teneo";
protected Resource doGetResource() {
if( resAlles == null ) {
initHibernate();
initResource();
return resJahr;
protected Resource doGetResourcePerson() {
return resPerson;
protected Resource doGetResourceGeschlecht() {
return resGeschlecht;
protected Resource doGetResourceAnrede() {
return resAnrede;
protected IStatus doSave() {
try {
sc.getSessionWrapper().beginTransaction();
resJahr.save(null);
resPerson.save(null);
sc.getSessionWrapper().commitTransaction();
return Status.OK_STATUS;
} catch (IOException e) {
return new Status(IStatus.ERROR,Activator.PLUGIN_ID,"Saveing failed",e);
// return Status.OK_STATUS;
protected IStatus doSavePerson() {
try {
protected IStatus doSaveAnrede() {
try {
resAnrede.save(null);
protected IStatus doSaveGeschlecht() {
try {
resGeschlecht.save(null);
private void initResource() {
String uriStr1 = "hibernate://?" + HibernateResource.DS_NAME_PARAM + "="
+ "zlvp&query1=FROM Jahr";
String uriStr2 = "hibernate://?" + HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Person";
String uriStr3 = "hibernate://?" + HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Geschlecht";
String uriStr4 = "hibernate://?" + HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Anrede";
String uriStr5 = "hibernate://?" + HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Jahr";
final URI uri1 = URI.createURI(uriStr1);
final URI uri2 = URI.createURI(uriStr2);
final URI uri3 = URI.createURI(uriStr3);
final URI uri4 = URI.createURI(uriStr4);
final URI uri5 = URI.createURI(uriStr5);
try {
resAlles = getResourceSet().createResource(uri1);
resPerson = getResourceSet().createResource(uri2);
resGeschlecht = getResourceSet().createResource(uri3);
resAnrede = getResourceSet().createResource(uri4);
resJahr = getResourceSet().createResource(uri5);
} catch (Exception e) {
e.printStackTrace();
if (resAlles != null) {
// load the resource domain
try {
resAlles.load(Collections.EMPTY_MAP);
resPerson.load(Collections.EMPTY_MAP);
resJahr.load(Collections.EMPTY_MAP);
// if (resPerson != null) {
// // load the resource domain
// try {
// resPerson.load(Collections.EMPTY_MAP);
// } catch (IOException e) {
// e.printStackTrace();
if (resAnrede != null) {
try {
resAnrede.load(Collections.EMPTY_MAP);
if (resGeschlecht != null) {
try {
resGeschlecht.load(Collections.EMPTY_MAP);
private void initHibernate() {
sc = new SessionController();
// Set the database information, Environment is
// org.hibernate.cfg.Environment
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, doGetDriver());
props.setProperty(Environment.USER, doGetUser());
props.setProperty(Environment.PASS, doGetPassword());
props.setProperty(Environment.URL, doGetUrl());
props.setProperty(Environment.DIALECT, doGetDialect());
props.setProperty(Environment.SHOW_SQL, "true");
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "SINGLE_TABLE");
// HibernateResource
HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore("zlvp");
// when creating a SessionController you have to pass your HbDataStore instance
sc.setHbDataStore(hbds);
// register the SessionController, the name is used in the uri of the resource
SessionController.registerSessionController("testsc", sc);
// sets its epackages stored in this datastore
hbds.setEPackages(new EPackage[] { ZlvpPackage.eINSTANCE });
// set the relational database to use and other properties
hbds.setProperties(props);
// initialize, also creates the database tables
hbds.initialize();
// System.out.println(hbds.getMappingXML());
protected abstract String doGetDriver();
protected abstract String doGetUser();
protected abstract String doGetPassword();
protected abstract String doGetUrl();
protected abstract String doGetDialect();
name="TeneoLibraryPersistenceService2.java"
filename="TeneoLibraryPersistenceService2.java"
import zlvp.*;
return "Teneo";
initHibernate();
initResource();
return resAlles;
return resPerson;
return resAnrede;
try {
resAlles.save(null);
try {
try {
try {
try {
try {
// try {
try {
try {
hbds.initialize();
--------------030205000707090506000309--
Re: [TENEO][EMF] Viewing problems in Linux and Windows [message #431448 is a reply to message #431445] |
Thu, 09 July 2009 14:46   |
Ok sorry. It was my faul. I check out a wrong version of the Model from
the SVN SORRY. It is boring. Forget it. Embarrassing (Red Head).
Hmm ok.... Now, if it no problem for you, I would ask another question:
I try this:
private void removeTeilnehmer(zlvp.Gruppe gruppe, Person teilnehmer){
Command cmdRemove = RemoveCommand.create(p.getEditingDomain(), gruppe,
ZlvpPackage.Literals.GRUPPE__TEILNEHMER, teilnehmer);
Command cmdAdd = new
AddCommand(p.getEditingDomain(),p.getResourcePerson().getCon tents(),teilnehmer);
if (cmdRemove.canExecute()) {
if (cmdAdd.canExecute())
p.getEditingDomain().getCommandStack().execute(cmdRemove);
p.getEditingDomain().getCommandStack().execute(cmdAdd);
}else{
System.out.println("Hat ned geklappt");
1Gruppe-N Persons (I had change my model)
But all my Persons get deleted in the database. But I would only delete
the association. How can I do it?
With a 1Group:NLeiter:1Persons the command work realy fine.
Sorry again for the circumstances.....
Martin Taal schrieb:
> Hi Waldi,
> You say not-displayed, but did you debug down into the resPerson
> resource in case of linux? Is the resource contents empty? Or is it more
> an issue on the UI side you think?
> gr. Martin
> Waldi Waldemar wrote:
>> Hi,
>> in the second resource are not displayed in Linux.
>> be the problem?
>> TeneoLibraryPersistenceService2.java its the same problem.
>> Thanks Waldi
Re: [TENEO][EMF] Viewing problems in Linux and Windows [message #431454 is a reply to message #431448] |
Sat, 11 July 2009 01:57  |
Hi Waldi,
Sorry, I am not sure why but I had not yet answered your post....
I am not sure but I think Leiter-Person is a containment relation? Then Teneo will automatically map this as a delete
and orphan-delete cascade setting. You can see the hibernate mapping to check this.
If you don't want this then there are two options:
- set a OneToMany annotation with the specific cascade you want
- set the PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT (this is currently set to ALL, mening also orphan-delete)
This last option influences all containment relations.
gr. Martin
> I try this:
> gruppe, ZlvpPackage.Literals.GRUPPE__TEILNEHMER, teilnehmer);
> }else{
>> Hi Waldi,
>> more an issue on the UI side you think?
>> gr. Martin
>>> Hi,
>>> be the problem?
>>> Thanks Waldi
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Current Time: Sat Jul 26 13:20:30 EDT 2025
Powered by FUDForum. Page generated in 0.11303 seconds
