Home » Modeling » EMF » [TENEO][EMF] Viewing problems in Linux and Windows
[TENEO][EMF] Viewing problems in Linux and Windows [message #431444] Thu, 09 July 2009 13:07 Go to next message
--------------030205000707090506000309
i had the attached source for my service. My problem is on windows this
service works realy good and my navigation tree is displayed fine.
I work with 2 resources. (resJahr and resPerson) All things that are in
the second resource are not displayed in Linux.
On my navigation tree i use a AdapterFactoryContentProvider. Can this be
the problem?
Can someone take a look at my file. Please have a special look at
resJahr and resAlles.
If i change the things like in the TeneoLibraryPersistenceService2.java
its the same problem.
Thanks Waldi
Content-Type: text/x-java;
name="TeneoLibraryPersistenceService.java"
Content-Disposition: inline;
filename="TeneoLibraryPersistenceService.java"
package de.connection.service.teneo;
import java.io.IOException;
import java.util.Collections;
import java.util.Properties;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.teneo.PersistenceOptions;
import org.eclipse.emf.teneo.hibernate.HbDataStore;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.eclipse.emf.teneo.hibernate.resource.HibernateResource;
import org.eclipse.emf.teneo.hibernate.resource.SessionController;
import org.hibernate.cfg.Environment;
import zlvp.*;
import de.connection.Activator;
import de.connection.service.BaseLibraryPersistenceService;
public abstract class TeneoLibraryPersistenceService extends BaseLibraryPersistenceService {
private Resource resAlles;
private Resource resPerson;
private Resource resAnrede;
private Resource resGeschlecht;
private Resource resJahr;
private SessionController sc;
public String getCategory() {
return "Teneo";
protected Resource doGetResource() {
if( resAlles == null ) {
initHibernate();
initResource();
return resJahr;
protected Resource doGetResourcePerson() {
return resPerson;
protected Resource doGetResourceGeschlecht() {
return resGeschlecht;
protected Resource doGetResourceAnrede() {
return resAnrede;
protected IStatus doSave() {
try {
sc.getSessionWrapper().beginTransaction();
resJahr.save(null);
resPerson.save(null);
sc.getSessionWrapper().commitTransaction();
return Status.OK_STATUS;
} catch (IOException e) {
return new Status(IStatus.ERROR,Activator.PLUGIN_ID,"Saveing failed",e);
// return Status.OK_STATUS;
protected IStatus doSavePerson() {
try {
protected IStatus doSaveAnrede() {
try {
resAnrede.save(null);
protected IStatus doSaveGeschlecht() {
try {
resGeschlecht.save(null);
private void initResource() {
String uriStr1 = "hibernate://?" + HibernateResource.DS_NAME_PARAM + "="
+ "zlvp&query1=FROM Jahr";
String uriStr2 = "hibernate://?" + HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Person";
String uriStr3 = "hibernate://?" + HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Geschlecht";
String uriStr4 = "hibernate://?" + HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Anrede";
String uriStr5 = "hibernate://?" + HibernateResource.SESSION_CONTROLLER_PARAM + "="
+ "testsc&query1=FROM Jahr";
final URI uri1 = URI.createURI(uriStr1);
final URI uri2 = URI.createURI(uriStr2);
final URI uri3 = URI.createURI(uriStr3);
final URI uri4 = URI.createURI(uriStr4);
final URI uri5 = URI.createURI(uriStr5);
try {
resAlles = getResourceSet().createResource(uri1);
resPerson = getResourceSet().createResource(uri2);
resGeschlecht = getResourceSet().createResource(uri3);
resAnrede = getResourceSet().createResource(uri4);
resJahr = getResourceSet().createResource(uri5);
} catch (Exception e) {
e.printStackTrace();
if (resAlles != null) {
// load the resource domain
try {
resAlles.load(Collections.EMPTY_MAP);
resPerson.load(Collections.EMPTY_MAP);
resJahr.load(Collections.EMPTY_MAP);
// if (resPerson != null) {
// // load the resource domain
// try {
// resPerson.load(Collections.EMPTY_MAP);
// } catch (IOException e) {
// e.printStackTrace();
if (resAnrede != null) {
try {
resAnrede.load(Collections.EMPTY_MAP);
if (resGeschlecht != null) {
try {
resGeschlecht.load(Collections.EMPTY_MAP);
private void initHibernate() {
sc = new SessionController();
// Set the database information, Environment is
// org.hibernate.cfg.Environment
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, doGetDriver());
props.setProperty(Environment.USER, doGetUser());
props.setProperty(Environment.PASS, doGetPassword());
props.setProperty(Environment.URL, doGetUrl());
props.setProperty(Environment.DIALECT, doGetDialect());
props.setProperty(Environment.SHOW_SQL, "true");
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "SINGLE_TABLE");
// HibernateResource
HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore("zlvp");
// when creating a SessionController you have to pass your HbDataStore instance
sc.setHbDataStore(hbds);
// register the SessionController, the name is used in the uri of the resource
SessionController.registerSessionController("testsc", sc);
// sets its epackages stored in this datastore
hbds.setEPackages(new EPackage[] { ZlvpPackage.eINSTANCE });
// set the relational database to use and other properties
hbds.setProperties(props);
// initialize, also creates the database tables
hbds.initialize();
// System.out.println(hbds.getMappingXML());
protected abstract String doGetDriver();
protected abstract String doGetUser();
protected abstract String doGetPassword();
protected abstract String doGetUrl();
protected abstract String doGetDialect();
name="TeneoLibraryPersistenceService2.java"
filename="TeneoLibraryPersistenceService2.java"
import zlvp.*;
return "Teneo";
initHibernate();
initResource();
return resAlles;
return resPerson;
return resAnrede;
try {
resAlles.save(null);
try {
try {
try {
try {
try {
// try {
try {
try {
hbds.initialize();
--------------030205000707090506000309--
Re: [TENEO][EMF] Viewing problems in Linux and Windows [message #431445 is a reply to message #431444] Thu, 09 July 2009 13:35 Go to previous messageGo to next message
Hi Waldi,
You say not-displayed, but did you debug down into the resPerson resource in case of linux? Is the resource contents
empty? Or is it more an issue on the UI side you think?
gr. Martin
Waldi Waldemar wrote:
> the problem?
> Thanks Waldi
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO][EMF] Viewing problems in Linux and Windows [message #431448 is a reply to message #431445] Thu, 09 July 2009 14:46 Go to previous messageGo to next message
Ok sorry. It was my faul. I check out a wrong version of the Model from
the SVN SORRY. It is boring. Forget it. Embarrassing (Red Head).
Hmm ok.... Now, if it no problem for you, I would ask another question:
I try this:
private void removeTeilnehmer(zlvp.Gruppe gruppe, Person teilnehmer){
Command cmdRemove = RemoveCommand.create(p.getEditingDomain(), gruppe,
ZlvpPackage.Literals.GRUPPE__TEILNEHMER, teilnehmer);
Command cmdAdd = new
AddCommand(p.getEditingDomain(),p.getResourcePerson().getCon tents(),teilnehmer);
if (cmdRemove.canExecute()) {
if (cmdAdd.canExecute())
p.getEditingDomain().getCommandStack().execute(cmdRemove);
p.getEditingDomain().getCommandStack().execute(cmdAdd);
}else{
System.out.println("Hat ned geklappt");
1Gruppe-N Persons (I had change my model)
But all my Persons get deleted in the database. But I would only delete
the association. How can I do it?
With a 1Group:NLeiter:1Persons the command work realy fine.
Sorry again for the circumstances.....
Martin Taal schrieb:
> Hi Waldi,
> resource in case of linux? Is the resource contents empty? Or is it more
> gr. Martin
>> Hi,
>> in the second resource are not displayed in Linux.
>> be the problem?
>> TeneoLibraryPersistenceService2.java its the same problem.
>> Thanks Waldi
Re: [TENEO][EMF] Viewing problems in Linux and Windows [message #431454 is a reply to message #431448] Sat, 11 July 2009 01:57 Go to previous message
Hi Waldi,
Sorry, I am not sure why but I had not yet answered your post....
I am not sure but I think Leiter-Person is a containment relation? Then Teneo will automatically map this as a delete
and orphan-delete cascade setting. You can see the hibernate mapping to check this.
If you don't want this then there are two options:
- set a OneToMany annotation with the specific cascade you want
- set the PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT (this is currently set to ALL, mening also orphan-delete)
This last option influences all containment relations.
gr. Martin
> I try this:
> gruppe, ZlvpPackage.Literals.GRUPPE__TEILNEHMER, teilnehmer);
> }else{
>> Hi Waldi,
>> gr. Martin
>>> Hi,
>>> be the problem?
>>> Thanks Waldi
The Netherlands
Previous Topic:Re: EMF Migration - EDataType error
Next Topic:how to create a stand alone plugin foom EMF model
Current Time: Sat Jul 26 03:54:25 EDT 2025
Powered by FUDForum. Page generated in 0.06233 seconds
