EStructuralFeature.isNullable() [message #431283] |
Tue, 07 July 2009 09:49  |
how can I find out whether a certain feature can be set to null?
For example if I have a feature of type EInt I get a classcastexception,
because under the hood the code trys to autobox null to an int.
Are there any flags, which could give me a hint?
Sven
Re: EStructuralFeature.isNullable() [message #431284 is a reply to message #431283] |
Tue, 07 July 2009 10:06   |
Sven,
Comments below.
Sven Efftinge wrote:
Perhaps you should consider unsetting the feature, i.e., eUnset(feature)
rather eSet(feature, null). Certainly null isn't going to be valid for
an isMany feature, nor will it be valid for a single-valued feature if
EDataType.getInstanceClass().isPrimitive() is true because null is not
in the value space for primitives. There's also
EClassifier.getDefaultValue() which is null except for primitives.
> classcastexception, because under the hood the code trys to autobox
> null to an int.
Maybe I should ask specifically what you're trying to do because eUnset
might be better, or setting to the feature's type's default value might
be better, but there's a subtle difference of course because an
unsettable feature will be set after you call eSet...
> Cheers,
> Sven
Re: EStructuralFeature.isNullable() [message #431285 is a reply to message #431284] |
Tue, 07 July 2009 10:28  |
Hi Ed,
"EDataType.getInstanceClass().isPrimitive()" is what I was asking for.
I was just stumbling over a bug in Xtext
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=280873) and was curious
about how to find this out reflectively.
Sven
Ed Merks schrieb:
> Sven,
> Comments below.
>> Hi,
>> null to an int.
>> Cheers,
>> Sven
FUDForum. Page generated in 0.16208 seconds
