Home » Modeling » EMF » [Teneo] No longer need EMFTupelizer override?
[Teneo] No longer need EMFTupelizer override? [message #431256] Mon, 06 July 2009 12:13 Go to next message
I have updated to Teneo 1.1.1 and Galileo. Based on a previous message
here I built an override class for the EMFTupelizer ( I cannot even
remember why now...).
When I upgraded the import
org.eclipse.emf.teneo.hibernate.mapping.internal has gone and with it
the interface used here:
proxyInterfaces.add(TeneoInternalEObject.class);
I could not find the Javadoc for Teneo online. where has
TeneoInternalEObject gone?
Thx.
David
Re: [Teneo] No longer need EMFTupelizer override? [message #431257 is a reply to message #431256] Mon, 06 July 2009 13:08 Go to previous messageGo to next message
Hi David,
It is still there though, see line 218 in the EMFTuplizer. This is related to a very detailed thing:
This interface ensures that the cglib proxyfactory does not encounter a security exception
because the EMF InternalEObject is signed with a different signature.
The TeneoInternalEObject is located in a separate jar file inside of org.eclipse.emf.teneo.hibernate
(org.eclipse.emf.teneo.hibernate.extra.jar). This to prevent it from being signed by the build process.
gr. Martin
David Wynter wrote:
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] No longer need EMFTupelizer override? [message #431268 is a reply to message #431257] Tue, 07 July 2009 04:04 Go to previous messageGo to next message
That jar you mention does not appear to be in the std install of Galileo
with EMF? org.eclipse.emf.teneo.hibernate.extra.jar
Where do I get it from?
Thx.
David
Martin Taal wrote:
> Hi David,
> security exception
> gr. Martin
> David Wynter wrote:
>> Hi,
>> Thx.
>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431269 is a reply to message #431268] Tue, 07 July 2009 04:15 Go to previous messageGo to next message
Hi David,
It is inside the org.eclipse.emf.teneo.hibernate plugin/jar file. Afaics the package
(org.eclipse.emf.teneo.hibernate.mapping.internal) is exported by that plugin.
gr. Martin
David Wynter wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> message here I built an override class for the EMFTupelizer ( I
>>> cannot even remember why now...).
>>> Thx.
>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431270 is a reply to message #431269] Tue, 07 July 2009 04:34 Go to previous messageGo to next message
That explains it. I do not have that plugin in the Galileo install,
org.eclipse.emf.teneo.hibernate.eclipse is there as a plugin but not
org.eclipse.emf.teneo.hibernate. In fact the only plugins listed are
org.eclipse.emf.teneo.hibernate.eclipse.source
org.eclipse.emf.teneo.hibernate.mapper.source
org.eclipse.emf.teneo.hibernate.hibernate.source
I did an update of Teneo Hibernate and it tells me that it is already
installed, I assume it checks all the jars.
Ideas?
David
Martin Taal wrote:
> Hi David,
> the package (org.eclipse.emf.teneo.hibernate.mapping.internal) is
> gr. Martin
> David Wynter wrote:
>> Hi,
>> Galileo with EMF? org.eclipse.emf.teneo.hibernate.extra.jar
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> it the interface used here:
>>>> Thx.
>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431271 is a reply to message #431270] Tue, 07 July 2009 04:45 Go to previous messageGo to next message
I manually added org.eclipse.emf.teneo.hibernate as a plugin dependency
in MANIFEST.MF, it did not complain. But when I show the plugin
dependencies it does not include the
org.eclipse.emf.teneo.hibernate.extra and TeneoInternalEOject still
cannot be resolved to a type. when I click "Find unused dependencies" it
finds org.eclipse.emf.teneo.hibenate?
Thx.
David
David Wynter wrote:
> Ideas?
> David
> Martin Taal wrote:
>> Hi David,
>> Afaics the package (org.eclipse.emf.teneo.hibernate.mapping.internal)
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> Thx.
>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431273 is a reply to message #431271] Tue, 07 July 2009 05:29 Go to previous messageGo to next message
Hi David,
org.eclipse.emf.teneo.hibernate.extra is not a plugin but a jar file in org.eclipse.emf.teneo.hibernate. This package
which contains the TeneoInternalEOject is org.eclipse.emf.teneo.hibernate.mapping.internal. This package is exported by
the org.eclipse.emf.teneo.hibernate plugin. So I would hope that after adding the org.eclipse.emf.teneo.hibernate plugin
to the dependency that you can use the TeneoInternalEObject.... Or can you try import packages with the
org.eclipse.emf.teneo.hibernate.mapping.internal package?
gr. Martin
David Wynter wrote:
> Thx.
> David
> David Wynter wrote:
>> Hi,
>> Ideas?
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> Thx.
>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431275 is a reply to message #431273] Tue, 07 July 2009 06:47 Go to previous messageGo to next message
Hi again,
When I use the auto complete on the import for that
org.eclipse.emf.teneo.hibernate.mapping.internal package it does not
show up.
Only the org.eclipse.emf.teneo.hibernate.mapping.econtainer,
org.eclipse.emf.teneo.hibernate.mapping.elist,
org.eclipse.emf.teneo.hibernate.mapping.identifier and
org.eclipse.emf.teneo.hibernate.mapping.property show up as packages.
So I opened the jar file and there is not internal under mapping! So it
must be in a different jar? I am looking at
org.eclipse.emf.teneo.hibernate_1.1.0.v200906180911.jar
Thx.
David
Martin Taal wrote:
> Hi David,
> org.eclipse.emf.teneo.hibernate. This package which contains the
> This package is exported by the org.eclipse.emf.teneo.hibernate plugin.
> plugin to the dependency that you can use the TeneoInternalEObject....
> gr. Martin
> David Wynter wrote:
>> Hi,
>> dependency in MANIFEST.MF, it did not complain. But when I show the
>> plugin dependencies it does not include the
>> it finds org.eclipse.emf.teneo.hibenate?
>> Thx.
>> David
>> David Wynter wrote:
>>> Hi,
>>> Ideas?
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> Afaics the package
>>>> that plugin.
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> with it the interface used here:
>>>>>>> Thx.
>>>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431276 is a reply to message #431275] Tue, 07 July 2009 06:50 Go to previous messageGo to next message
Hi David,
And do you see the extra jar file in the plugin itself? The TeneoInternalEObject is located in that jar file.
The strange thing is that if I try this with the development projects it works (importing the TeneoInternalEObject in
another class in another plugin is possible).
gr. Martin
David Wynter wrote:
> Hi again,
> show up.
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> in org.eclipse.emf.teneo.hibernate. This package which contains the
>> exported by the org.eclipse.emf.teneo.hibernate plugin. So I would
>> hope that after adding the org.eclipse.emf.teneo.hibernate plugin to
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> Thx.
>>> David
>>> David Wynter wrote:
>>>> Hi,
>>>> already installed, I assume it checks all the jars.
>>>> Ideas?
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> Afaics the package
>>>>> that plugin.
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> Thx.
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> signature.
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> Thx.
>>>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431278 is a reply to message #431276] Tue, 07 July 2009 06:59 Go to previous messageGo to next message
Yes I should have read your response more carefully. It is in the extras
jar file. But it does not seem to be exported, I am on Ubuntu 9.0.4 now
not Windoze as previous, maybe that is a difference?
David
Martin Taal wrote:
> Hi David,
> works (importing the TeneoInternalEObject in another class in another
> gr. Martin
> David Wynter wrote:
>> Hi again,
>> show up.
>> it must be in a different jar? I am looking at
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> dependencies" it finds org.eclipse.emf.teneo.hibenate?
>>>> Thx.
>>>> David
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> not org.eclipse.emf.teneo.hibernate. In fact the only plugins
>>>>> listed are
>>>>> Ideas?
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> Afaics the package
>>>>>> that plugin.
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> signature.
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> Thx.
>>>>>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431279 is a reply to message #431278] Tue, 07 July 2009 07:07 Go to previous messageGo to next message
I am on Ubuntu to :-)
I think the problem is that the TeneoInternalEObject is in a jar inside the plugin and the plugin is not unpacked.
Normally this is not a problem (who wants to get to this terrible object anyway ;-). But now I can see that you are
stuck with this.
Can you unzip the org.eclipse.emf.teneo.hibernate plugin? in the plugins directory (so it becomes a folder)? and then
remove the org.eclipse.emf.teneo.hibernate.jar file (so that only the folder remains), and then restart Eclipse with the
-clean in the eclipse.ini file.
gr. Martin
David Wynter wrote:
> David
> Martin Taal wrote:
>> Hi David,
>> it works (importing the TeneoInternalEObject in another class in
>> gr. Martin
>> David Wynter wrote:
>>> Hi again,
>>> show up.
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> Thx.
>>>>> David
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> install, org.eclipse.emf.teneo.hibernate.eclipse is there as a
>>>>>> plugin but not org.eclipse.emf.teneo.hibernate. In fact the only
>>>>>> plugins listed are
>>>>>> Ideas?
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> Afaics the package
>>>>>>> that plugin.
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> Thx.
>>>>>>>> David
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi David,
>>>>>>>>> signature.
>>>>>>>>> gr. Martin
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I cannot even remember why now...).
>>>>>>>>>> Thx.
>>>>>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431282 is a reply to message #431279] Tue, 07 July 2009 09:44 Go to previous messageGo to next message
I unpacked the whole teneo.hibernate jar and linked to the extras jar as
a variable. But it stopped the plugin working as a plugin.
I also tried unpacking just the extras jar and putting that in the
plugin directory and linking to that as a variable, that worked.
David
> the plugin and the plugin is not unpacked. Normally this is not a
> can see that you are stuck with this.
> directory (so it becomes a folder)? and then remove the
> remains), and then restart Eclipse with the -clean in the eclipse.ini file.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> extras jar file. But it does not seem to be exported, I am on Ubuntu
>> 9.0.4 now not Windoze as previous, maybe that is a difference?
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi again,
>>>> show up.
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> file in org.eclipse.emf.teneo.hibernate. This package which
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> still cannot be resolved to a type. when I click "Find unused
>>>>>> Thx.
>>>>>> David
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> plugins listed are
>>>>>>> Ideas?
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> by that plugin.
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> of Galileo with EMF? org.eclipse.emf.teneo.hibernate.extra.jar
>>>>>>>>> Thx.
>>>>>>>>> David
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi David,
>>>>>>>>>> signature.
>>>>>>>>>> gr. Martin
>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> previous message here I built an override class for the
>>>>>>>>>>> EMFTupelizer ( I cannot even remember why now...).
>>>>>>>>>>> Thx.
>>>>>>>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431288 is a reply to message #431282] Tue, 07 July 2009 11:15 Go to previous messageGo to next message
Hi David,
Hmm, this does not sound like a long-term strategy. I am wondering if there is another way to do this. To understand the
background, for what reason do you extend the EMFTuplizer?
gr. Martin
David Wynter wrote:
> David
>> inside the plugin and the plugin is not unpacked. Normally this is not
>> now I can see that you are stuck with this.
>> plugins directory (so it becomes a folder)? and then remove the
>> file.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> projects it works (importing the TeneoInternalEObject in another
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi again,
>>>>> not show up.
>>>>> So it must be in a different jar? I am looking at
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> Thx.
>>>>>>> David
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> plugins listed are
>>>>>>>> Ideas?
>>>>>>>> David
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi David,
>>>>>>>>> by that plugin.
>>>>>>>>> gr. Martin
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> Thx.
>>>>>>>>>> David
>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>> Hi David,
>>>>>>>>>>> signature.
>>>>>>>>>>> gr. Martin
>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> and with it the interface used here:
>>>>>>>>>>>> Thx.
>>>>>>>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431382 is a reply to message #431288] Wed, 08 July 2009 06:20 Go to previous messageGo to next message
Back in Nov 18th 2008 I added a override class for EMFTuplizer. You
advised this because at the time Teneo was getting a CCE due to taking a
class out of an unordered List of some kind, I cannot find the email. I
searched the Release notes of all Teneo releases since then for the term
EMFTuplizer and could not find it, so am not sure whatever it was that
was wrong is now fixed.
I reverted to not use my override and use EMFTuplizer and I still get
the class not found error at runtime for EMFTuplizer. I have removed the
extras jar and the reference to it, back to a std install of Teneo 1.1.0.
I tried to update to Teneo 1.1.1 SDK but ended up in the usual
dependency hell that p2 is supposed to prevent. It is trying to install
the already install V1.1.0 and the V1.1.1 in the dropins directory at
the same time. Also comparing th eTeneo SDK 1.1.1 with an the EMF
Moidelling plugin?
I reverted to just the Teneo 1.1.1 runtime and the dropins does not get
deployed, I click update and it says nothing to deploy, what a pile of
crap p2 is. Take me back to the old UM, at least it worked.
So at the moment I am stalled.
David
Martin Taal wrote:
> Hi David,
> there is another way to do this. To understand the background, for what
> gr. Martin
> David Wynter wrote:
>> Hi,
>> as a variable. But it stopped the plugin working as a plugin.
>> David
>>> But now I can see that you are stuck with this.
>>> file.
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi again,
>>>>>> not show up.
>>>>>> Thx.
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> Thx.
>>>>>>>> David
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> Ideas?
>>>>>>>>> David
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi David,
>>>>>>>>>> by that plugin.
>>>>>>>>>> gr. Martin
>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> Thx.
>>>>>>>>>>> David
>>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>>> Hi David,
>>>>>>>>>>>> signature.
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> Thx.
>>>>>>>>>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431391 is a reply to message #431382] Wed, 08 July 2009 06:38 Go to previous messageGo to next message
Hi David,
The latest build (5 minutes old) contains an unpacked teneo.hibernate plugin:
http://www.eclipse.org/modeling/emf/downloads/?project=teneo &showAll=1&hlbuild=M200907080536#M200907080536
As a tip, the last few times I installed plugins/features I did not put them in dropins anymore but just directly in the
eclipse installation (so that the files end up in features/plugins). That seemed to work.... (but no guarantees from my
side).
gr. Martin
David Wynter wrote:
> Moidelling plugin?
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> David
>>>> eclipse.ini file.
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> Ubuntu 9.0.4 now not Windoze as previous, maybe that is a difference?
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi again,
>>>>>>> not show up.
>>>>>>> packages.
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> is exported by the org.eclipse.emf.teneo.hibernate plugin. So I
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> the
>>>>>>>>> Thx.
>>>>>>>>> David
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> Ideas?
>>>>>>>>>> David
>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>> Hi David,
>>>>>>>>>>> gr. Martin
>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> install of Galileo with EMF?
>>>>>>>>>>>> Thx.
>>>>>>>>>>>> David
>>>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>>>> Hi David,
>>>>>>>>>>>>> signature.
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> Thx.
>>>>>>>>>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431398 is a reply to message #431382] Wed, 08 July 2009 06:46 Go to previous messageGo to next message
Here is the stack trace using the std EMFTuplizer
2009-07-0811:41:20.804 GMT+0100 14620 [main] ERROR org.mortbay.log -
failed HibernateSessionRequestFilter
org.hibernate.HibernateException: Could not build tuplizer
[org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer]
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping .buildEntityTuplizer(EntityEntityModeToTuplizerMapping.java: 134)
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping . <init>(EntityEntityModeToTuplizerMapping.java:72)
at
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:325)
at
org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:457)
at
org.hibernate.persister.entity.SingleTableEntityPersister.<init >(SingleTableEntityPersister.java:131)
at
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:84)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:261)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1327)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:171)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:83)
at
org.eclipse.emf.teneo.hibernate.HbBaseSessionDataStore.getSe ssionFactory(HbBaseSessionDataStore.java:57)
at com.yambina.secm.dwr.HibernateUtil.init(HibernateUtil.java:1 11)
at
com.yambina.secm.dwr.HibernateUtil.getSessionFactory(Hiberna teUtil.java:30)
at
com.yambina.secm.dwr.HibernateSessionRequestFilter.init(Hibe rnateSessionRequestFilter.java:96)
at org.mortbay.jetty.servlet.FilterHolder.doStart(FilterHolder. java:97)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCy cle.java:39)
at
org.mortbay.jetty.servlet.ServletHandler.initialize(ServletH andler.java:589)
at org.mortbay.jetty.servlet.Context.startContext(Context.java: 139)
at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppCo ntext.java:1220)
at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHand ler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext .java:448)
at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrap per.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at com.yambina.secm.jetty.JettyLauncher.start(JettyLauncher.jav a:194)
at com.yambina.secm.jetty.JettyLauncher.main(JettyLauncher.java :91)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 13)
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping .buildEntityTuplizer(EntityEntityModeToTuplizerMapping.java: 131)
... 26 more
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/emf/teneo/hibernate/mapping/internal/TeneoIntern alEObject
at
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.buildPr oxyFactory(EMFTuplizer.java:185)
at
org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:158)
at
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.<init>(EMFTuplizer.java:77)
... 31 more
Caused by: java.lang.ClassNotFoundException:
org.eclipse.emf.teneo.hibernate.mapping.internal.TeneoIntern alEObject
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
... 34 more
2009-07-0811:41:20.807 GMT+0100 14623 [main] ERROR org.mortbay.log -
Failed startup of context
org.mortbay.jetty.webapp.WebAppContext@5ecd2e33{/secm,/home/david/workspace/GenSec2/./web}
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 26 more
at
at
at
... 31 more
... 34 more
Re: [Teneo] No longer need EMFTupelizer override? [message #431401 is a reply to message #431391] Wed, 08 July 2009 07:02 Go to previous messageGo to next message
Yeah I tried that too, but they never show up as plugins anymore if I
put them directly into the plugins and features directories. So then I
cannot include them as dependencies in my plugin.xml.
Tried with your latest build, but does not deploy from the dropins and
is not recognized as a plugin if I place it directly in the plugins and
features directories. Way to go p2 team!
Might have to do a fresh install of Eclipse and start again.
David
Martin Taal wrote:
> Hi David,
> plugin:
> them in dropins anymore but just directly in the eclipse installation
> (but no guarantees from my side).
> gr. Martin
Re: [Teneo] No longer need EMFTupelizer override? [message #431403 is a reply to message #431401] Wed, 08 July 2009 07:09 Go to previous messageGo to next message
Well good luck that's what I can say....
The build runs all testcases on an eclipse installation with the same plugins installed as the ones which are
downloadable, the testcases all pass.
I hope that having the teneo.hibernate plugin unpacked will solve your class not found exception.
gr. Martin
David Wynter wrote:
> David
> Martin Taal wrote:
>> Hi David,
>> plugin:
>> put them in dropins anymore but just directly in the eclipse
>> seemed to work.... (but no guarantees from my side).
>> gr. Martin
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431418 is a reply to message #431403] Wed, 08 July 2009 12:58 Go to previous messageGo to next message
It seems that publishing the new versions of Teneo without an Update
site is now a waste of time, as according to the guys on Equinox now
that Teneo is a managed set of bundles, dropins don't work.
I did try expanding teneo.hibernate jar for 1.1.0 that comes with
Galileo, but that created a whole new set of exceptions. So I will have
to wait until the next release with an Update Site for download.
David
Martin Taal wrote:
> plugins installed as the ones which are downloadable, the testcases all
> pass.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> and features directories. Way to go p2 team!
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> plugin:
>>> gr. Martin
Re: [Teneo] No longer need EMFTupelizer override? [message #431439 is a reply to message #431418] Thu, 09 July 2009 10:37 Go to previous messageGo to next message
Using dropins works fine in 3.5 if you unzip the teneo SDK into your
dropins folder, then goto 'Check for Updates'. It finds it and updates.
Re: [Teneo] No longer need EMFTupelizer override? [message #431441 is a reply to message #431439] Thu, 09 July 2009 11:52 Go to previous messageGo to next message
Not according to the equinox team. See thread on e.t.equinox. I tried it
several times on Ubuntu 9.0.4 and all it did was screw up my
teneo.hibernate plugin. According to the equinox guy teneo is now a part
of the 'managed' bundles for Galileo and therefore dropins will not
work, which is my experience.
David
Re: [Teneo] No longer need EMFTupelizer override? [message #431446 is a reply to message #431441] Thu, 09 July 2009 13:48 Go to previous messageGo to next message
What Simon Kaegi said on e.t.equinox is correct.
You need to install the latest version of teneo (1.1.0) using the eclipse
update site. (p2 enabled).
Then close eclipse. Manually download 1.1.1.
Then unzip the 1.1.1 release into your dropins folder.
Then fire up eclipse and do 'Check for update'. It will recognise you had
teneo installed via p2 and will see there is a newer version in dropins
and will then install / update it to 1.1.1. Until you do this stage, it
will not override teneo 1.1.0 with the later version (as Simon suggested
since its a manual install).
I am running gentoo linux, with teneo installed in the above manner
without any problems. My partner has just updated using the exact same
method on her vista laptop and had no problems.
Only thing i can suggest if you still have problems is perhaps you need to
use a fresh copy of 3.5. It may have collected some garbage along the way.
Re: [Teneo] No longer need EMFTupelizer override? [message #431447 is a reply to message #431446] Thu, 09 July 2009 13:52 Go to previous message
and to add some possibly unrelated things. In 3.4 when I accidentally left the zip file in the dropins folder (together
with its unzipped content) then 3.4 p2 would not pick up the new stuff in the dropins folder.
Also David, as you want to get to the embedded jar, you should take one of the latest maintenance build (I did one today
to try to get it on an update site which apparently failed again.... :-(.
gr. Martin
> eclipse update site. (p2 enabled).
> had teneo installed via p2 and will see there is a newer version in
> dropins and will then install / update it to 1.1.1. Until you do this
> stage, it will not override teneo 1.1.0 with the later version (as Simon
> suggested since its a manual install).
> to use a fresh copy of 3.5. It may have collected some garbage along the
> way.
The Netherlands
Previous Topic:Inheritance of EOperations
Next Topic:[CDO] data type precisions by annotations
Current Time: Fri Jul 18 19:16:47 EDT 2025
Powered by FUDForum. Page generated in 0.55219 seconds
