Home » Modeling » EMF » OneToMany not working as expected...
OneToMany not working as expected... [message #431224] |
Thu, 02 July 2009 18:45  |
Hi again!
I have a problem with a OneToMany relationship that isn't behaving as I
expect it.
I have two tables, it's a unidirectional one-to-many relationship where
the join happens on a column that is NOT the primary column of the 'one'
side. I'm annotating this as:
@OneToMany(fetch=FetchType.LAZY, indexed=false)
@JoinColumn(name="GRP_ID", referencedColumnName="CLI_ID")
When the query to retrieve the "many" is run, the column of the "many"
is correct, but the bound parameter turns out to be the primary key of
the "one" instead of the CLI_ID that I expect, so I get NO results.
Roberto Leibman
Here're the xsds, edited for brevity:
<xsd:complexType name="Foo">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Entity @Table( name="FOO_TABLE"
)</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:element name="BagOfBars" type="Bar" minOccurs="0"
maxOccurs="unbounded">
<xsd:annotation>
<xsd:appinfo source='teneo.jpa'>
</xsd:appinfo>
<xsd:documentation></xsd:documentation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
<xsd:attribute name="dnmSK" type="xsd:int" default='0'>
<xsd:annotation>
@Id @Column(name="DNM_SK", nullable="false",insertable = true,
updatable = false)
@GeneratedValue(strategy=SEQUENCE,generator="excludeClientSequence ")
</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
<xsd:attribute default="" name="clientId" type="xsd:string">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Column(name="CLI_ID",
length="8")</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
<xsd:complexType name='Bar'>
<xsd:annotation>
<xsd:appinfo source='teneo.jpa'>@Entity
@Table(name="BAR_TABLE")</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:element name='barKey'
type='BarKey'>
<xsd:annotation>
@Embedded @AttributeOverrides({@AttributeOverride(name="groupId",
column=@Column(name="GRP_ID")),@AttributeOverride(name="classId ",
column=@Column(name="CLAS_ID"))})
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name='BarKey'>
<xsd:annotation>
<xsd:appinfo source='teneo.jpa'>@Embeddable</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
</xsd:sequence>
<xsd:attribute name='groupId' type='xsd:string' >
<xsd:annotation>
<xsd:appinfo source='teneo.jpa'>@Column(name="GRP_ID",
nullable=false)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
<xsd:attribute name='classId' type='xsd:string' >
<xsd:annotation>
<xsd:appinfo source='teneo.jpa'>@Column(name="CLAS_ID",
</xsd:annotation>
</xsd:attribute>
</xsd:complexType>
And the mapping that I get (note the total absence of cli_id anywhere in
the 'bag')
<class name="FooImpl" entity-name="Foo" abstract="false" lazy="false"
table="FOO_TABLE">
<meta attribute="eclassName">Foo</meta>
<id name="dnmSK" type="int" unsaved-value="0">
<column not-null="true" unique="false" name="dnm_sk"/>
<generator class="sequence">
<param name="sequence">PRDS0001</param>
<param name="initialValue">1</param>
<param name="allocationSize">50</param>
</generator>
</id>
<bag name="statusLogEntries" inverse="true" lazy="true"
cascade="all,delete-orphan">
<key update="true" foreign-key="foo_bagofbars">
<column name="grp_id" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="StatusLog"/>
</bag>
</class>
Re: OneToMany not working as expected... [message #431226 is a reply to message #431224] |
Fri, 03 July 2009 03:01   |
Hi Roberto,
Yes the key misses a property-ref.
Can you enter a bugzilla with this example model attached? Then I will take care of this.
gr. Martin
Roberto Leibman wrote:
> Hi again!
> expect it.
> Roberto Leibman
> <xsd:annotation>
> )</xsd:appinfo>
> </xsd:annotation>
> <xsd:sequence>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> <xsd:annotation>
> updatable = false)
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> type='BarKey'>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> the 'bag')
> table="FOO_TABLE">
> </generator>
> </id>
> </key>
> </bag>
> </class>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Current Time: Sat Jul 26 17:04:28 EDT 2025
Powered by FUDForum. Page generated in 0.03547 seconds
