Question about EFeatureMap [message #431167] |
Wed, 01 July 2009 05:58  |
quick question about FeatureMaps:
Let an EClass have several EStructuralFeatures (e.g. preferredOrders,
standardOrders to stick with the common example, but also an additional
many-valued-EReference to, lets say Address).
Additionally the EClass has the orders-EFeatureMap.
Do I understand correctly that the link between the orders EFeatureMap
and the EStructuralFeatures preferredOrders and standardOrders is only
by implementation of the derived features preferredOrders and
standardOrders?
So there is, i.e., no modelwise-declared constraint which would prevent
something like orders.add(addressStructuralFeature, addressObject)?
Or is there and I have missed it?
Or to put it more generally: does an EFeatureMap allow to get any item
added as long as the EStructuralFeature of the FeatureMap.Entry is a
feature of the containing class? Or can the features of the items be
somehow limited by declaration?
Stefan
Re: Question about EFeatureMap [message #431169 is a reply to message #431167] |
Wed, 01 July 2009 06:12   |
Stefan,
Comments below.
Stefan Winkler wrote:
> standardOrders?
Yes.
FeatureMapUtil.getValidator is used to ensure that only
sensible/allowed/meaningful things are added to the feature map.
No.
Yes, the extended meta data annotations limit what's allowed.
> Cheers,
> Stefan
Re: Question about EFeatureMap [message #431199 is a reply to message #431196] |
Thu, 02 July 2009 06:46  |
--------------060003040106030004030608
Stefan,
In general, a feature map could allow features from the DocumentRoot
class of other packages, i.e., for a feature map that corresponds to a
substitution group or wildcard. In that case, the set of features
allowed is effectively unbounded, much like the set of subclasses is
unbounded.
> Hi Ed,
> thanks for the answer. Follow-up question below.
>>> Or can the features of the items be somehow limited by declaration?
> Ok, I had a look at ExtendedMetaData and also came to the
> FeatureMapUtil.BasicValidator.
> So, if I want to decide (for the CDO store implementation) which values
> are possible for a FeatureMap, I would use a
> List<EStructuralFeature> includedFeatures = ...;
> validator = new FeatureMapUtil.BasicValidator(myContainingClass,
> myFeatureMapFeature);
> for(EStructuralFeature feature : eClass.getEAllStructuralFeatures()) {
> if(validator.isIncluded(feature) {
> includedFeatures.add(feature);
> Is this correct?
> Or is there an easier way to determine that set?
> Thanks!
> Stefan
<html>
<head>
http-equiv="Content-Type">
</head>
Stefan,<br>
<br>
FUDForum. Page generated in 0.67365 seconds
