Re: Proper namespace generation in document root [message #431154 is a reply to message #431147] |
Tue, 30 June 2009 06:57   |
--------------030200070809050003070806
Guido,
Comments below.
Guido Schnider wrote:
> I have a model that has been generated from an xml schema (Learning
> Object Metadata) (ecore file see
> here:http://www.olat.org/downloads/material/lom.ecore)
> When I save the model to xml I get a namespace section like this:
> <?xml version="1.0" encoding="utf-8"?>
> <lom:Lom xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:lom="http://ltsc.ieee.org/xsd/LOM">
> </lom:Lom>
> But this is wrong, as I need something like this:
> <lom xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns="http://ltsc.ieee.org/xsd/LOM"
> xsi:schemaLocation="http://ltsc.ieee.org/xsd/lomv1.0/lom.xsd">
> </lom>
They're semantically equivalent and your schemaLocation attribute is
invalid.
http://wiki.eclipse.org/index.php/EMF/FAQ#How_can_I_ensure_t hat_an_xsi:schemaLocation_is_serialized_for_my_packages.3F
You can use documentRoot.getXMLNSPrefixMap().put("", LOMPackage.eNS_URI)
to map the null prefix to some non-null target namespace, but keep in
mind that once you do this, the null namespace is no longer available
for nested element, which will result in an invalid serialization if you
need access to unqualified local element declarations.
> I played with several setting of the xmlresource options but nothing
> helped.
> thanks for you time!
> guido
<html>
<head>
http-equiv="Content-Type">
</head>
Guido,<br>
<br>
Comments below.<br>
<br>
<blockquote
cite="mid:0ee027148d986e26d174dadd7738595f$1@www.eclipse.org"
type="cite">I have a model that has been generated from an xml schema
(Learning Object Metadata) (ecore file see
here:<a class="moz-txt-link-freetext" href="http://www.olat.org/downloads/material/lom.ecore">http://www.olat.org/downloads/material/lom.ecore</a>)
<br>
<br>
<br>
<br>
<br>
<lom:Lom xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xmlns:lom=<a class="moz-txt-link-rfc2396E" href="http://ltsc.ieee.org/xsd/LOM">"http://ltsc.ieee.org/xsd/LOM"</a>>
<br>
</lom:Lom>
<br>
<br>
<br>
<br>
<br>
<lom xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xmlns=<a class="moz-txt-link-rfc2396E" href="http://ltsc.ieee.org/xsd/LOM">"http://ltsc.ieee.org/xsd/LOM"</a>
xsi:schemaLocation=<a class="moz-txt-link-rfc2396E" href="http://ltsc.ieee.org/xsd/lomv1.0/lom.xsd">"http://ltsc.ieee.org/xsd/lomv1.0/lom.xsd"</a>>
<br>
</lom>
<br>
</blockquote>
invalid. <br>
<blockquote><a
href=" http://wiki.eclipse.org/index.php/EMF/FAQ#How_can_I_ensure_t hat_an_xsi:schemaLocation_is_serialized_for_my_packages.3F"> http://wiki.eclipse.org/index.php/EMF/FAQ#How_can_I_ensure_t hat_an_xsi:schemaLocation_is_serialized_for_my_packages.3F</a><br>
</blockquote>
LOMPackage.eNS_URI) to map the null prefix to some non-null target
namespace, but keep in mind that once you do this, the null namespace
is no longer available for nested element, which will result in an
invalid serialization if you need access to unqualified local element
declarations.<br>
<blockquote
type="cite"><br>
helped.
<br>
<br>
<br>
<br>
guido
<br>
<br>
</blockquote>
</body>
</html>
--------------030200070809050003070806--
Re: Proper namespace generation in document root [message #431159 is a reply to message #431158] |
Tue, 30 June 2009 09:52  |
Guido,
Comments below.
> Thanks for the response, I thought I understand a bit of XML but with
> this namespace stuff I'm bit confused.
Yes, I've found that despite the common assertion that XML is simple,
very few people understand the rules for prefix qualification very well
because it's relatively complex.
> When you say this both are equivalend why does loading this one with
> my emf modelthrows an error:
> <lom xmlns="http://ltsc.ieee.org/xsd/LOM">
> </lom>
I don't expect differences in behavior for the root element, but I
suspect there is nested stuff (you haven't told me about yet) that will
cause a problem.
What I described works for the Library XML Schema model, for example.
> guido
FUDForum. Page generated in 0.13366 seconds
