Home » Modeling » EMF » EReference on a default ID
EReference on a default ID [message #431116] Mon, 29 June 2009 12:26 Go to next message
Originally posted by: guillaume.surrel.scalagent.com
Hi all,
I'm new to emf and I'm currently stuck on something.
Here is my problem :
I've made an EClass 'B' which has an EReference 'link' on an EClass 'A'.
'A' has an EAttribute 'id' with the ID attribute set to true.
The problem is that I have something like this in the resulting XML :
<A id="default">
<B link="//@A.0">
instead of
<A id="default">
<B link="default">
when the id on A is not set and has the default value. Everything is as
expected when I explicitly set the id value of class A using the
properties view.
Thank you.
Re: EReference on a default ID [message #431119 is a reply to message #431116] Mon, 29 June 2009 12:32 Go to previous messageGo to next message
Guillaume,
The ID must be set to used. Are you suggesting you made "default" the
default value for the id attribute? That's not a good idea, because if
there is more than one 'A' they will have the same ID value, which is
invalid, and so you'll still have to set it.
Guillaume Surrel wrote:
> Hi all,
> <A id="default">
> <B link="//@A.0">
> instead of
> <A id="default">
> <B link="default">
> as expected when I explicitly set the id value of class A using the
> properties view.
> Thank you.
Re: EReference on a default ID [message #431144 is a reply to message #431119] Tue, 30 June 2009 05:23 Go to previous messageGo to next message
Thanks Ed for the quick reply.
Ed Merks a écrit :
> Guillaume,
I'm not sure what you mean by this. Is this about eIsSet method
returning true ? Because modifying the generated code to do it seems to
do exactly what I'm expecting.
Exactly.
Of course, but the purpose is to save a little time when keeping default
id value.
>> Hi all,
>> <A id="default">
>> <B link="//@A.0">
>> instead of
>> <A id="default">
>> <B link="default">
>> properties view.
>> Thank you.
Re: EReference on a default ID [message #431146 is a reply to message #431144] Tue, 30 June 2009 05:28 Go to previous messageGo to next message
--------------040600060109050106010909
Guillaume,
Comments below.
> Ed Merks a
Re: EReference on a default ID [message #431156 is a reply to message #431146] Tue, 30 June 2009 07:19 Go to previous message
Ed Merks a écrit :
> Yes because it's implemented like this in EcoreUtil
> public static String getID(EObject eObject)
> EClass eClass = eObject.eClass();
> EAttribute eIDAttribute = eClass.getEIDAttribute();
> return eIDAttribute == null || !eObject.eIsSet(eIDAttribute) ?
> null : convertToString(
> eIDAttribute.getEAttributeType(),
> eObject.eGet(eIDAttribute));
Ok, thanks for pointing this out.
>>> That's not a good idea, because if there is more than one 'A' they
>>> will have the same ID value, which is invalid, and so you'll still
>>> have to set it.
>> default id value.
> It's common for there to be only one A in the resource?
Yes, there will be more likely a very small number of A.
Previous Topic:Regarding XPand template file
Next Topic:Proper namespace generation in document root
Current Time: Wed Jul 23 20:22:50 EDT 2025
Powered by FUDForum. Page generated in 0.04796 seconds
