Home » Modeling » EMF » Select using BooleanOCLCondition Question!
Select using BooleanOCLCondition Question! [message #431100] Sun, 28 June 2009 06:31 Go to next message
Hi!!!
I'm trying to create a query using EMF Query to get a List with all
classes from one specific package.
But I'm having one error in the Query execution.
One Part of the code:
OCL focl = org.eclipse.ocl.ecore.OCL.newInstance();
try {
fBooleanOCLCondition = new BooleanOCLCondition<EClassifier, EClass,
EObject>(focl.getEnvironment(),"self.oclIsTypeOf(EClass)",null);
} catch (ParserException e) {
e.printStackTrace();
fSelectQuery = new SELECT(new FROM(aPackage), new
WHERE(fBooleanOCLCondition));
The variable aPackage is from the EPackage type.
The Error msg:
Exception in thread "main" java.lang.NoClassDefFoundError:
lpg/lpgjavaruntime/PrsStream
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:675)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:316)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:280 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:374 )
at
org.eclipse.ocl.AbstractEnvironment.lookupLocal(AbstractEnvi ronment.java:550)
at
org.eclipse.ocl.AbstractEnvironment.addElement(AbstractEnvir onment.java:289)
at
org.eclipse.ocl.AbstractEnvironmentFactory.createClassifierC ontext(AbstractEnvironmentFactory.java:134)
at
org.eclipse.ocl.internal.helper.OCLHelperImpl.setContext(OCL HelperImpl.java:119)
at
org.eclipse.emf.query.ocl.conditions.AbstractOCLCondition.ge tOCLQueryRecord(AbstractOCLCondition.java:362)
at
org.eclipse.emf.query.ocl.conditions.AbstractOCLCondition.is Satisfied(AbstractOCLCondition.java:289)
at
org.eclipse.emf.query.ocl.conditions.BooleanOCLCondition.isS atisfied(BooleanOCLCondition.java:230)
at org.eclipse.emf.query.statements.WHERE.matches(WHERE.java:46 )
at org.eclipse.emf.query.statements.SELECT.doResume(SELECT.java :131)
at org.eclipse.emf.query.statements.SELECT.doExecute(SELECT.jav a:95)
at
org.eclipse.emf.query.internal.statements.QueryStatement.exe cute(QueryStatement.java:77)
at org.eclipse.emf.query.statements.SELECT.execute(SELECT.java: 172)
at
parser.ECoreModel2BS_MMParser.QtAbstractClassesPackage(ECore Model2BS_MMParser.java:96)
at
parser.ECoreModel2BS_MMParser.ProcessPackage(ECoreModel2BS_M MParser.java:130)
at parser.ECoreModel2BS_MMParser.<init>(ECoreModel2BS_MMParser.java:149)
at parser.ECoreModel2BS_MMParser.main(ECoreModel2BS_MMParser.ja va:183)
I would like to ask if some of you knows what it could be!
Thanks a lot in advance,
Lucas
Re: Select using BooleanOCLCondition Question! [message #431101 is a reply to message #431100] Sun, 28 June 2009 07:25 Go to previous messageGo to next message
Lucas,
It just sounds like you have libraries missing. I.e., the ones needed
to parse the OCL expression. I'm not sure this stuff even works
stand-alone. Probably you need to run as an OSGi application...
Lucas wrote:
> Hi!!!
> try {
> EClass, EObject>(focl.getEnvironment(),"self.oclIsTypeOf(EClass)",null);
> The Error msg:
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Lucas
Re: Select using BooleanOCLCondition Question! [message #431109 is a reply to message #431101] Mon, 29 June 2009 09:05 Go to previous messageGo to next message
--=-B3Rru4XyA8OIOsU8+qrS
Content-Type: text/plain
Hi, Ed, Lucas,
OCL and the LPG Java Run-time definitely work in a stand-alone
configuration, and the EMF Query code should, too, as it doesn't have
any extension points. I can't guarantee the latter, but it's worth a
try.
In any case, the dependency that Lucas is missing is the
net.sourceforge.lpgjavaruntime_1.1.0.qualifier.jar bundle. It's
included in the MDT OCL distribution.
HTH,
Christian
On Sun, 2009-06-28 at 07:25 -0400, Ed Merks wrote:
> Lucas,
> Lucas wrote:
> > Hi!!!
> > try {
> > The Error msg:
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Lucas
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Ed, Lucas,<BR>
<BR>
OCL and the LPG Java Run-time definitely work in a stand-alone configuration, and the EMF Query code should, too, as it doesn't have any extension points.&nbsp; I can't guarantee the latter, but it's worth a try.<BR>
<BR>
In any case, the dependency that Lucas is missing is the net.sourceforge.lpgjavaruntime_1.1.0.qualifier.jar bundle.&nbsp; It's included in the MDT OCL distribution.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
Lucas,
Lucas wrote:
&gt; Hi!!!
&gt; I'm trying to create a query using EMF Query to get a List with all
&gt; classes from one specific package.
&gt; But I'm having one error in the Query execution.
&gt;
&gt; One Part of the code:
&gt; ------
&gt; OCL focl = org.eclipse.ocl.ecore.OCL.newInstance();
&gt; try {
&gt; fBooleanOCLCondition = new BooleanOCLCondition&lt;EClassifier,
&gt; EClass, EObject&gt;(focl.getEnvironment(),&quot;self.oclIsTy peOf(EClass)&quot;,null);
&gt; } catch (ParserException e) {
&gt; e.printStackTrace();
&gt; }
&gt; fSelectQuery = new SELECT(new FROM(aPackage), new
&gt; WHERE(fBooleanOCLCondition));
&gt; ------
&gt; The variable aPackage is from the EPackage type.
&gt;
&gt; The Error msg:
&gt;
&gt; -----
&gt; Exception in thread &quot;main&quot; java.lang.NoClassDefFoundError:
&gt; lpg/lpgjavaruntime/PrsStream
&gt; at java.lang.ClassLoader.defineClass1(Native Method)
&gt; at java.lang.ClassLoader.defineClass(ClassLoader.java:675)
&gt; at
&gt; java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:124)
&gt; at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
&gt; at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
&gt; at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
&gt; at java.security.AccessController.doPrivileged(Native Method)
&gt; at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
&gt; at java.lang.ClassLoader.loadClass(ClassLoader.java:316)
&gt; at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:280 )
&gt; at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
&gt; at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:374 )
&gt; at
&gt; org.eclipse.ocl.AbstractEnvironment.lookupLocal(AbstractEnvi ronment.java:550)
&gt;
&gt; at
&gt; org.eclipse.ocl.AbstractEnvironment.addElement(AbstractEnvir onment.java:289)
&gt;
&gt; at
&gt; org.eclipse.ocl.AbstractEnvironmentFactory.createClassifierC ontext(AbstractEnvironmentFactory.java:134)
&gt;
&gt; at
&gt; org.eclipse.ocl.internal.helper.OCLHelperImpl.setContext(OCL HelperImpl.java:119)
&gt;
&gt; at
&gt; org.eclipse.emf.query.ocl.conditions.AbstractOCLCondition.ge tOCLQueryRecord(AbstractOCLCondition.java:362)
&gt;
&gt; at
&gt; org.eclipse.emf.query.ocl.conditions.AbstractOCLCondition.is Satisfied(AbstractOCLCondition.java:289)
&gt;
&gt; at
&gt; org.eclipse.emf.query.ocl.conditions.BooleanOCLCondition.isS atisfied(BooleanOCLCondition.java:230)
&gt;
&gt; at org.eclipse.emf.query.statements.WHERE.matches(WHERE.java:46 )
&gt; at org.eclipse.emf.query.statements.SELECT.doResume(SELECT.java :131)
&gt; at org.eclipse.emf.query.statements.SELECT.doExecute(SELECT.jav a:95)
&gt; at
&gt; org.eclipse.emf.query.internal.statements.QueryStatement.exe cute(QueryStatement.java:77)
&gt;
&gt; at org.eclipse.emf.query.statements.SELECT.execute(SELECT.java: 172)
&gt; at
&gt; parser.ECoreModel2BS_MMParser.QtAbstractClassesPackage(ECore Model2BS_MMParser.java:96)
&gt;
&gt; at
&gt; parser.ECoreModel2BS_MMParser.ProcessPackage(ECoreModel2BS_M MParser.java:130)
&gt;
&gt; at
&gt; parser.ECoreModel2BS_MMParser.&lt;init&gt;(ECoreMode l2BS_MMParser.java:149)
&gt; at
&gt; parser.ECoreModel2BS_MMParser.main(ECoreModel2BS_MMParser.ja va:183)
&gt; -----
&gt;
&gt; I would like to ask if some of you knows what it could be!
&gt; Thanks a lot in advance,
&gt;
&gt; Lucas
&gt;
&gt;
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-B3Rru4XyA8OIOsU8+qrS--
Re: Select using BooleanOCLCondition Question! [message #431130 is a reply to message #431109] Mon, 29 June 2009 17:20 Go to previous message
Hey Ed, Christian,
The net.sourceforge.lpgjavaruntime_1.1.0.qualifier.jar bundle was missing!
Now it is working! :)
Thanks a lot for your help! :)
Lucas
Previous Topic:[databinding] convert empty string to null
Next Topic:[EMF Databinding] Properly disposing of observables?
Current Time: Sun Jul 27 15:24:52 EDT 2025
Powered by FUDForum. Page generated in 0.29402 seconds
