Home » Modeling » EMF » [CDO] Listen to passive updates.
[CDO] Listen to passive updates. [message #431025] Wed, 24 June 2009 10:01 Go to next message
Hello.
Is it somehow possible for a view/transaction to listen and get the object that is updated (activ or
passiv)?
I could add a IListener that indeed is called, but it doesn't tell me what object.
A CDOTransactionHandler can only monitor what the transaction does itself.
But how do I get those objects that are passive updated?
I don't want to add an Adapter to every object in my view.
Kai
Re: [CDO] Listen to passive updates. [message #431028 is a reply to message #431025] Wed, 24 June 2009 15:04 Go to previous messageGo to next message
Kai Schlamp wrote:
> Hello.
Hello! :-)
> passiv)?
object.
For the passive you can do the following
http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_reac t_to_remote_changes_to_my_objects.3F
CDOViewInvalidationEvent
- getDirtyObjects and getDetchedObject
private IListener viewListener = new IListener()
public void notifyEvent(IEvent event)
if (event instanceof CDOViewInvalidationEvent)
CDOViewInvalidationEvent e = (CDOViewInvalidationEvent)event;
// Remove detached object from selection, could incur into
unwanted exceptions
e.getDirtyObjects();
Quick note:
CDOViewInvalidationEvent will only include dirtyObjects that you have in
your views.
CDOSessionInvalidationEvent will gives you ALL dirty CDOID that happens
passively.
Is it helping you ?
> Regards,
> Kai
Re: [CDO] Listen to passive updates. [message #431029 is a reply to message #431025] Wed, 24 June 2009 15:05 Go to previous messageGo to next message
Kai,
Maybe you can find the anser in this FAQ entry:
http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_reac t_to_remote_changes_to_my_objects.3F*
Cheers
/Eike
Kai Schlamp schrieb:
> Hello.
> object that is updated (activ or passiv)?
> what object.
> itself.
> Regards,
> Kai
Re: [CDO] Listen to passive updates. [message #431033 is a reply to message #431028] Wed, 24 June 2009 17:05 Go to previous messageGo to next message
Hy Simon,
comment below.
Simon Mc Duff wrote:
> Kai Schlamp wrote:
>> Hello.
> Hello! :-)
>> object
>> passiv)?
>> what
> object.
>> itself.
> unwanted exceptions
> Quick note:
> your views. CDOSessionInvalidationEvent will gives you ALL dirty CDOID
> that happens passively.
> Is it helping you ?
Yes, looks good. The problem is that I don't have the method
CDOView.setInvalidationNotificationEnabled(boolean enabled); available. When I browse the source by
hitting F3 on the class, I see it's there. But when I try to access it in the editor, it tells my
that it is undefined ... strange.
Most probably a setup problem. I will reinstall everything (I only updated for several Milestones
and RCs now) and report back then. It's even a good time for reinstallation ... the new Galileo
release ;-)
Kai
Re: [CDO] Listen to passive updates. [message #431042 is a reply to message #431033] Thu, 25 June 2009 03:04 Go to previous messageGo to next message
--------------070700050902090805040103
Content-Type: text/plain; charset=ISO-8859-15
Kai,
Please use:
view.options().setInvalidationNotificationEnabled(*true*);
Cheers
/Eike
> Hy Simon,
> comment below.
>> Kai Schlamp wrote:
>>> Hello.
>> Hello! :-)
>>> object
>>> passiv)?
>>> me what
>> object.
>>> itself.
>> unwanted exceptions
>> Quick note:
>> in your views. CDOSessionInvalidationEvent will gives you ALL dirty
>> CDOID that happens passively.
>> Is it helping you ?
> available. When I browse the source by hitting F3 on the class, I see
> updated for several Milestones and RCs now) and report back then. It's
> even a good time for reinstallation ... the new Galileo release ;-)
> Regards,
> Kai
<html>
<head>
http-equiv="Content-Type">
</head>
Kai,<br>
<br>
Please use:<br>
<br>
<pre>
Re: [CDO] Listen to passive updates. [message #431045 is a reply to message #431042] Thu, 25 June 2009 03:41 Go to previous messageGo to next message
Hello, Eike ...
> Please use:
Thanks for the hint. I now receive CDOViewInvalidationEvent events.
But how would I get those other events/notifications mentioned in the FAQ
(CDOSessionInvalidationEvent, CDOInvalidationNotification and CDOChangeSubscriptionPolicy)?
For e.g. it is mentioned in the Javadoc comment of CDOInvalidationNotification that
setInvalidationNotificationEnabled(boolean) should lead to a CDOInvalidationNotification.
But I never receive such events (at least when I check with instanceof).
Re: [CDO] Listen to passive updates. [message #431046 is a reply to message #431045] Thu, 25 June 2009 03:46 Go to previous messageGo to next message
> Hello, Eike ...
>> Please use:
> FAQ (CDOSessionInvalidationEvent,
session.addListener(new IListener() {...});
object.eAdapters().add(new AdapterImpl() {...});
These two methods achieve similar things:
- Add listeners to CDOSession or CDOView to receive IEvents
- Attach adapters to EObject to receive Notifications (either with or
without delta information)
Cheers
/Eike
Re: [CDO] Listen to passive updates. [message #431070 is a reply to message #431046] Thu, 25 June 2009 12:21 Go to previous messageGo to next message
Thanks Eike for carifying this. One last question about those listeners.
Is it possible to only listen to passive updates that come from another session?
I am not interested in commits of the transactions of the "local" session. Just in those commits
that other
clients do by using their session.
Kai
>> Hello, Eike ...
>>> Please use:
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] Listen to passive updates. [message #431071 is a reply to message #431070] Thu, 25 June 2009 12:24 Go to previous messageGo to next message
Kai,
The following method only returns null for changes from remote:
org.eclipse.emf.cdo.session.CDOSessionInvalidationEvent.getV iew()
Cheers
/Eike
> another session?
> session. Just in those commits that other
> Regards,
> Kai
>>> Hello, Eike ...
>>>> Please use:
>>> instanceof).
>> Cheers
>> /Eike
Re: [CDO] Listen to passive updates. [message #431076 is a reply to message #431071] Thu, 25 June 2009 14:27 Go to previous messageGo to next message
Eike Stepper wrote:
> Kai,
Thanks Eike. Perhaps a method like CDOSessionInvalidationEvent.isRemote() would be a nice feature to
have a clearer API. What do you think? Bug Report? ;-)
Re: [CDO] Listen to passive updates. [message #431078 is a reply to message #431076] Thu, 25 June 2009 14:41 Go to previous messageGo to next message
> Eike Stepper wrote:
>> Kai,
> CDOSessionInvalidationEvent.isRemote() would be a nice feature to have
Yes, please ;-)
Cheers
/Eike
Re: [CDO] Listen to passive updates. [message #431083 is a reply to message #431078] Thu, 25 June 2009 15:36 Go to previous message
> Yes, please ;-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281566
Previous Topic:[CDO] CDO 2.0 RC2 on the EMF Milestones Update Site
Next Topic:Bug in deresolve URI?
Current Time: Sat Jul 19 02:32:56 EDT 2025
Powered by FUDForum. Page generated in 0.05157 seconds
