Home » Modeling » EMF » [CDO] Question about CDO notification and RevisionManage
[CDO] Question about CDO notification and RevisionManage [message #430918] Wed, 17 June 2009 12:51 Go to next message
Originally posted by: adomas.greicius.nomagic.com
I would like to ask same questions about RevisionManager. Is there any
documentation of RevisionManager?
While handling remove object notification, I do not get old object. If I
try to get Object from revisionManager using version from notification,
got null. . If I decrease version by one and then try to get revision it is
ok. Is it a bug?
public void notifyChanged(Notification msg) {
if (msg instanceof CDODeltaNotification) {
CDODeltaNotification cdoDeltaNotification = (CDODeltaNotification) msg;
int version = cdoDeltaNotification.getRevisionDelta().getOriginVersion();
CDORevision revision =
cTransaction.getSession().getRevisionManager().getRevisionBy Version(
locksContainer.cdoID(), 0, version - 1);
Object o = revision.data().get(XXXX.Literals.XXXX, msg.getPosition());
Same times I get exception IndexOutOfBoundsException, when I try to get
data from revision. Should I decrease position?
java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
If I handle removed object notification in remote client, I do not get
oldObject (It is null). What is the best way to get OldObject?
Re: [CDO] Question about CDO notification and RevisionManage [message #430929 is a reply to message #430918] Wed, 17 June 2009 21:06 Go to previous messageGo to next message
Hi Adomas,
Adomas Greicius wrote:
> Hello,
> ok. Is it a bug?
Don't know yet! :-)
Why you take locksCOntainer.cdoID ? Why not
cdoDeltaNotification.getRevisionDelta().getID() ? (Since I don't know
whichs objects it is... I'm not sure where locksCOntainer came from).
Is it a one-to-many relationship ? or one to one ? (Not related to the
problem... just a question)
Why you don't use EStructuralFeature feature =
(EStructuralFeature)cdoDeltaNotification .getFeature();
Since you don't know which feature changed... how can you use the
msg.getPosition ?
Be careful when you play with position... you can use it in the old
revision only if it is not a ADD (Like in Standard EMF).
Ex:
object.getElements().size(); // size == 4
object.getElements().add(newObject); //
The notification received would be :
msg.getPosition() == 4
It will not make sense for ADD notification to go to the previous
version and do the following:
object.getElements().get(4); // INDEX OUT OF BOUND
But if you are saying it was a Remove... then you can do it. It really
depends of the kind of notification.. and you should add a test in your
adapter.
I did a small case
- I used .getOriginVersion() and notification.getFeature().
if (notification instanceof CDODeltaNotification)
(CDODeltaNotification)notification;
int version =
tx2.getSession().getRevisionManager().getRevisionByVersion(
cdoDeltaNotification.getRevisionDelta().getID(), 0, version);
(EStructuralFeature)notification.getFeature();
Object o = revision.data().get(feature,
notification.getPosition());
System.out.println(o);
All worked very nicely.
By the way which Back-end are you using? (Mysql? MEM ? Others? )
Simon
Re: [CDO] Question about CDO notification and RevisionManage [message #430952 is a reply to message #430929] Fri, 19 June 2009 10:24 Go to previous messageGo to next message
Thanks Simon for your example. It helped a lot.
We are using DBStore. Same times we use with MySQL and same time with Derby.
"Simon McDuff" <smcduff@hotmail.com> wrote in message
news:h1c3qq$iig$1@build.eclipse.org...
> Hi Adomas,
>> Hello,
>> is ok. Is it a bug?
> Don't know yet! :-)
> msg.getPosition ?
> Ex:
> It will not make sense for ADD notification to go to the previous version
> adapter.
> I did a small case
> int version =
> version);
> Simon
Re: [CDO] Question about CDO notification and RevisionManage [message #430953 is a reply to message #430952] Fri, 19 June 2009 10:39 Go to previous message
You are welcome.
Let me know if you still think it doesn`t behave correctly.
Simon
Previous Topic:Loading unique reference
Next Topic:Get domain model file in RPC Editor
Current Time: Sat Jul 19 00:35:26 EDT 2025
Powered by FUDForum. Page generated in 0.03619 seconds
