Home » Modeling » EMF » [databinding] convert empty string to null
[databinding] convert empty string to null [message #430734] Fri, 05 June 2009 20:18 Go to next message
I'm binding a Text widget to a BigDecimal attribute. The
EMFUpdateValueStrategy throws a NumberFormatException when the text box is
cleared. Instead, I'd like to set the attribute to null. I can do it with
my own UpdateValueStrategy, but just wondering if there are other better
options.
I noticed https://bugs.eclipse.org/bugs/show_bug.cgi?id=203492 which looks
cool but seems to have stalled.
-Will
Re: [databinding] convert empty string to null [message #430735 is a reply to message #430734] Fri, 05 June 2009 20:30 Go to previous messageGo to next message
No naturally you can write your own UpdateValueStrategy which sets the
null-converter by default. The other IMHO better option is to delegate
the creation of UpdateValueStrategy to a Factory which makes the code
more readable and easier to maintain.
-----------8<------------
ctx.bindValue(
textProp.observe(t),
mprop.observe(committership),
UpdateStrategyFactory.stringToDate(
"Can't convert end date value into a valid date"),
UpdateStrategyFactory.dateToString()
ctx.bindValue(textProp.observe(t), mprop.observe(committership),
UpdateStrategyFactory.stringToDateNotNull(
"Can't convert start date value into a valid date",
"The start date can not be null"),
The source code is available from EMF-CVS
(org.eclipse.emf.examples.databinding.project.*) and hence all code
provided is available under EPL.
Tom
> is cleared. Instead, I'd like to set the attribute to null. I can do
> it with my own UpdateValueStrategy, but just wondering if there are
> other better options.
> looks cool but seems to have stalled.
> -Will
Re: [databinding] convert empty string to null [message #430739 is a reply to message #430735] Sat, 06 June 2009 13:51 Go to previous messageGo to next message
Thanks for the pointer to that very interesting example application. By the
way, I had to modify three files to run it on Windows:
ProjectAdminViewPart.java
- String path = getViewSite().getSecondaryId().replaceFirst("_", ":");
+ String path = getViewSite().getSecondaryId().replaceAll("_", ":");
OpenXMIHandler.java
- path = path.replaceFirst(":", "_");
+ path = path.replaceAll(":", "_");
NewXMIHandler.java
....since windows has more than one colon in a path, e.g. file://c:/abc.xmi
For my update value strategy, I end up with is this:
static UpdateValueStrategy convertEmptyStringToNull() {
return new EMFUpdateValueStrategy() {
protected IConverter createConverter(Object fromType, Object
toType) {
// get the default EMF converter for these types
final IConverter defaultConverter = super.createConverter(
fromType, toType);
return new Converter(fromType, toType) {
public Object convert(Object fromObject) {
// delegate to the default converter, but replace
empty string
// with null first
if (fromObject instanceof String
&& ((String) fromObject).isEmpty()) {
fromObject = null;
return defaultConverter.convert(fromObject);
It works, but just seems like a lot for a conceptually simple task.
By the way,
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:h0cdam$mrn$1@build.eclipse.org...
> ctx.bindValue(
> Tom
>> -Will
Re: [databinding] convert empty string to null [message #430740 is a reply to message #430739] Sat, 06 June 2009 17:03 Go to previous messageGo to next message
Hi Will,
Well why are you not setting the convert on the newly created
EMFUpdateValueStrategy?
Thanks for the feedback on the win32 problem - I'll fix the bugs ASAP.
The first blog entries about the application and the new API are out
since a few minutes [1].
Tom
[1]http://tomsondev.bestsolution.at/
> the way, I had to modify three files to run it on Windows:
> OpenXMIHandler.java
> NewXMIHandler.java
> @Override
> toType) {
> fromType, toType);
> @Override
> empty string
> // with null first
> fromObject = null;
> By the way,
>> Hi,
>> ctx.bindValue(
>> Tom
>>> -Will
Re: [databinding] convert empty string to null [message #430741 is a reply to message #430740] Sat, 06 June 2009 19:09 Go to previous messageGo to next message
news:h0elic$a3o$1@build.eclipse.org...
EMFUpdateValueStrategy by default can convert a String to any EAttribute
(using the data type, EFactory, etc). If I set my own converter, then I
have to know the fromType and toType and it is no longer generic to use on
different model observable types.
>> @Override
>> toType) {
>> fromType, toType);
>> @Override
>> empty string
>> // with null first
>> fromObject = null;
Re: [databinding] convert empty string to null [message #431125 is a reply to message #430740] Mon, 29 June 2009 13:18 Go to previous messageGo to next message
I noticed you made a change to the EMF Databinding sample code about the bug
I mentioned. I tried it again and there is still one small bug on windows.
NewXMIHandler.java still does
path = path.replaceFirst(":", "#_#");
instead of
path = path.replaceAll(":", "#_#");
OpenXMIHandler works fine now.
Best,
Will
Re: [databinding] convert empty string to null [message #431129 is a reply to message #431125] Mon, 29 June 2009 17:04 Go to previous message
It was in the NewXMIHandler right? Thanks for the feedback - much
appreciated and fixed :-)
Tom
> bug I mentioned. I tried it again and there is still one small bug on
> windows. NewXMIHandler.java still does
> instead of
> Best,
> Will
Previous Topic:problem with prefix
Next Topic:Select using BooleanOCLCondition Question!
Current Time: Wed Nov 05 07:31:26 EST 2025
Powered by FUDForum. Page generated in 0.03723 seconds
