Home » Modeling » EMF » EMF Databinding with EMFObservables and Editing Domain
EMF Databinding with EMFObservables and Editing Domain [message #430698] Thu, 04 June 2009 09:00 Go to next message
Normaly I do the Databinding in the same way like Tom's EMF Databinding
example:
IWidgetValueProperty textProp;
IWidgetValueProperty dateProp;
textProp = WidgetProperties.text();
dateProp = WidgetProperties.selection();
IEMFEditValueProperty prop = EMFEditProperties.value(p.getEditingDomain(),
ZlvpPackage.Literals.LAGER__THEMA);
IObservableValue uObs = prop.observeDetail(viewerSelection);
dbc.bindValue(SWTObservables.observeDelayedValue(400,
(ISWTObservableValue) textProp.observe(tThema)), uObs);
Now, I use a new eclipse Version because the new JFace Version kann bind
SWT.DateTime. Now, IEMFEdit is no longer available.can you help me and give
me a short example how I can do it without IEMFEdit???
Re: EMF Databinding with EMFObservables and Editing Domain [message #430700 is a reply to message #430698] Thu, 04 June 2009 09:27 Go to previous messageGo to next message
Which version of EMF are you using? You need to use 2.5 RC2 or RC3. The
versions before don't have support for Databinding-Properties.
I've worked on an example in last weeks and there's going to be a
blog-series about it in the next weeks.
The example source code is already available from CVS if you are interested.
Tom
> example:
Re: EMF Databinding with EMFObservables and Editing Domain [message #430701 is a reply to message #430700] Thu, 04 June 2009 09:36 Go to previous messageGo to next message
Thanks a lot for your answer. I will look aft RC2 or 3 One short question
for you: EMFObservables.observeResourceContents(doGetResource()); How is the
new way observe resources? Is it fixed in RC2 to?
"Tom Schindl" <tom.schindl@bestsolution.at> schrieb im Newsbeitrag
news:h08i4d$6en$1@build.eclipse.org...
> interested.
> Tom
>> example:
>> give
Re: EMF Databinding with EMFObservables and Editing Domain [message #430702 is a reply to message #430701] Thu, 04 June 2009 09:58 Go to previous messageGo to next message
Hi Waldi,
Yes but this might change in 2.6 if we manage to come up with a
properties implementation for the resource-content.
This would make the EMFObservables-Class and others unneeded and we
would deprecate and probably even remove them if we manage to add this
support say for M1 or M2.
If you want get more background information you can take a look at
262160 which holds the implementation history of this support.
Tom
>> Hi,
>> interested.
>> Tom
>>> example:
>>> give
Re: EMF Databinding with EMFObservables and Editing Domain [message #430703 is a reply to message #430702] Thu, 04 June 2009 11:14 Go to previous messageGo to next message
Okay all is running fine, only one short problem: If I change a text, the
treeViewer doesn't reakt and the domain doesnt become dirty. I've changed
nothing, only the DateTimes. Is it sure there isn't a bug?
Another question: What is this for a number? 262160.
Can you give me a tip how I can find the example from which you talk?
Here is my Code again to observe the EditingDomain
tThema = new Text(composite2, SWT.NONE);
tThema.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
news:h08jtc$pri$1@build.eclipse.org...
> Hi Waldi,
> Tom
>> the
>>> Hi,
>>> interested.
>>> Tom
>>>> example:
>>>> bind
>>>> give
Re: EMF Databinding with EMFObservables and Editing Domain [message #430704 is a reply to message #430703] Thu, 04 June 2009 11:35 Go to previous messageGo to next message
It's a bug id.
I have no idea. My wild guess is that because you are not setting any
converters the default ones are used and then you need to use a
ISO-Format for input which is yyyy-mm-dd.
Please also note you'll have to use an EMFDatabindingContext because
EMF-Databinding returns the EStructuralFeature as type from the observables.
You can check out my example project from CVS and reuse the converters
I've written there.
Because we are at it and you are using dates in a master-detail scenario
I have to point you to a nasty bug [1] which failed the inclusion in 3.5!
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=278301
Re: EMF Databinding with EMFObservables and Editing Domain [message #430717 is a reply to message #430704] Thu, 04 June 2009 15:05 Go to previous messageGo to next message
Ok, fine, now all is running. It works like a charm. It was my fault I
forgot to set the date attribute to date.... I'm a newbie....
The example project from which you speak is it the library example? I
work with it... It is realy good. A big compliment to you.
I know the bug but what can I do? waiting ;-) It's ok... I have time.
> It's a bug id.
> I've written there.
> Tom
Re: EMF Databinding with EMFObservables and Editing Domain [message #430719 is a reply to message #430717] Thu, 04 June 2009 19:12 Go to previous message
Hi Waldi,
Well it depends the Libary example is the one I worked on for my
EclipseCon presentation. The one I talked about in this mail is the one
you can fetch from EMF-CVS
(cvsroot/org.eclipse.emf/org.eclipse.emf/examples/org.eclips e.emf.examples.databinding.*).
It's a completely running RCP-Application showing the complete
EMF-Databinding API.
In the next few days/weeks I'm going to run a blog series [1] about
EMF-Databinding which might give you a jump start into the whole topic.
The bug I referenced is *NOT* going to be fixed in 3.5.0 and because the
code part it is in is a really dangerous it might not get fixed in 3.5.x.
We are currently working on documenting an work around using the public
API but we haven't come to a final conclusion what we are going to
propose to our customers.
The regression I talked about in the is there since 2007 and nobody came
across it (until I came across :-) though I think the use case I
described is not that unusual.
To get informed about solutions I'd suggest that you subscribe to the
bug report so that you see what's going on.
Tom
[1]http://tomsondev.bestsolution.at
>>> the treeViewer doesn't reakt and the domain doesnt become dirty. I've
>>> changed nothing, only the DateTimes. Is it sure there isn't a bug?
>> It's a bug id.
>> observables.
>> I've written there.
>> Tom
Previous Topic:Add another model to an exist EMF project
Next Topic:WSDL model listener
Current Time: Tue Oct 21 21:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.06825 seconds
